Turn Signal Flasher Led Mod - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 11-03-2007, 02:55 PM   #1
Djmike2485
Registered User
Fan#: 3230
What I Drive: Silver 2000 Ford Focus Zetec 4 Dr.
FF Reputation: 6 Djmike2485 Good Standing Member
I am considering changing my rear turn and stop tail lights from bulbs to LEDs. I have found the bulbs and determined that to keep the turn signals from going to hyper mode, I will need to change the flasher out for a lower resistance flasher or wire in some resistors. What I need to know is where the flasher module is in the car. I have searched online forums, here, and through my owner's manual to no avail. I have heard that they operate through the hazard flasher but I cannot locate where that is either.
Any suggestions? Has anyone else done the same?
Djmike2485 is offline
Old 11-03-2007, 04:57 PM   #2
DaveCombs
DaveCombs's Avatar
Fan#: 50626
What I Drive: 05 Mazda3s 5dr
FF Reputation: 4 DaveCombs Good Standing Member
I wasn't aware of flasher relays with different resistance.
Usually what you need to do is put a load resistor in line with the turn signal bulb wire. They can typically be found anywhere you would buy the LED lamps.
Asshattery knows no bounds...
DaveCombs is offline
Old 11-03-2007, 10:30 PM   #3
Djmike2485
Registered User
Fan#: 3230
That's what my thought was. I will probably order them at the same time I get the bulbs. Thanks.
Old 11-03-2007, 10:57 PM   #4
DaveCombs
DaveCombs's Avatar
Fan#: 50626
N/P. When you get them, they should have a couple of very long wire leads on the ends, and this is to give you more choices of where to mount them. You should try to mount them onto a metal surface, like by using self-tapping screws. Avoid plastic, or trying to mount them with two-sided tape or zip ties (unless you zip tie around the wires, and not the resistor body) because they can get HOT if the flashers are on for any long amount of time.
Here's a place to look: http://jlevistreetwerks.com/store/<b>Universal-Products</b>-Exterior-Lighting/c115_116/index.html?osCsid=42330d0e2f725eb7658a8b797f4ce2ab
Also, www.superbrightleds.com
And to revise/rescind my earlier post, apparently there ARE "LED-compatible" flasher relays. Who knew?
Similar Threads
turn signal on crack... Adzar1207 General Technical Chat 1 10-27-2007 01:53 AM
HELP!....Turn signal sound madlion222 MK1 Interior Mods & Upgrades 8 09-20-2006 01:30 AM
Need help with some Headlight and turn signal ideas.. Saber63 General Technical Chat 6 07-13-2006 01:31 AM
Left Turn Signal Blinks Twice As Fast SexConker General Technical Chat 15 06-29-2006 02:01 PM
Turn signal cancel mechanism focus777 General Technical Chat 4 07-01-2005 07:51 AM
