'00 - '03 Ford Focus Fan Wiring - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-01-2007, 05:40 PM   #1
Durango_Boy
Durango_Boy's Avatar
Fan#: 51300
What I Drive: 1998 Dodge Durango 360
FF Reputation: 1 Durango_Boy Good Standing Member
I need some help.
Can someone give me details about the cooling fan set used in the '00 - '03 Ford Focus? Pic below for reference.
I would like general information. Amperage draw per fan, and CFM rating per fan. Are they one speed, two speed, variable speed? What's the factory control like?
The other question I have stems from the wiring I see in the picture. It seems the wiring from both fans meets at a junction of some kind. Is this just a junction for the two sets of power wires or is this a built in controller or relay of some kind?
I will be using this fan in a custom application on a '77 Vette, and am needing to know how the fans are controlled so I can possible incorporate that into my plans and how I had originally designed my system for a different dual fan.
Thanks for the help.
Durango_Boy is offline
Old 11-01-2007, 08:18 PM   #2
Durango_Boy
Fan#: 51300
According to a Mustang owner who installed a Focus fan, that junction I see is a resistor of some kind for the high power fan. I guess it's prone to failure?
Old 11-02-2007, 06:08 AM   #3
guitarseth
Fan#: 7887
What I Drive: 2003 French Blue Metallic ZX3
FF Reputation: 3 guitarseth Good Standing Member
Yeah, I believe that's the thermister pack. They have a tendency to go out. However, I must confess that I've only seen a handful of actual cases of that occuring in my browsing of several Focus boards.
guitarseth is offline
Old 11-02-2007, 10:30 PM   #4
foci3
Fan#: 38952
What I Drive: 2001 WH 4DR
Points 442, Level 8
Points: 442, Level: 8 Points: 442, Level: 8 Points: 442, Level: 8
Level Up 84% Completed
FF Reputation: 3 foci3 Good Standing Member
The resistor is used to get low speed. Be sure to use large enough wire and relay able to handle current draw. Not sure of the exact draw but they do use a 50 amp fuse so it could be 25 to 30 amps. Connector failures at the resistor are common mostly due to close proximity to the exhaust manifold.
foci3 is offline
Old 11-03-2007, 09:08 AM   #5
Durango_Boy
Fan#: 51300
Curious, is that a 50 amp relay for both fans, or per? The way I have it set up each fan has it's own separate control and will have a 30 amp relay. I will upgrade those to 40 amp relays, and it's all fused through a custom fuse box I installed under the hood for 12V constant and IGN sources for accessories.
Old 11-03-2007, 11:49 AM   #6
foci3
Fan#: 38952
Points 442, Level 8
Fuse is one 50 amp for both fans so 30 amp relay one for each fan will be fine.
foci3 is offline
Old 11-03-2007, 01:42 PM   #7
Durango_Boy
Fan#: 51300
Sweet, thanks.
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
2004 Ford Focus Factory Wiring Diagrams Book N2O Focus Archive 6 05-21-2007 08:26 PM
WHY does Ford Suck!!!!!!!!1 cruzstyle Ford Focus & General Car Chat 38 10-12-2006 04:26 PM
Ford will have a reality show igor Ford Focus & General Car Chat 4 04-27-2006 12:47 PM
