Breather filter. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2007, 11:16 PM   #1
MooZX3
MooZX3's Avatar
Fan#: 22871
What I Drive: 2000, Pitch Black ZX3
FF Reputation: 1 MooZX3 Good Standing Member
Buy-Sell-Trade Rating: (6)
Breather filter.
So I've seen a few of these around. I know that from the factory the breather tube runs into the airbox. But I always seem to get some amount though slight oil in my filter.
But there is a type of cone filter that you can just put right up to where the breather tube connects to the engine.
Doesn't this create heat soak?
Although from the times I've paid attention it doesn't seem as though the thing really moves any significant amount of air.
So what's the opinion on these?
If so I would like to just put that cone filter on. And run another Ice-Man clone to the Airbox.
Every time I "fix" something, I end up with extra screws.
Zetec Crew #193
MooZX3 is offline
Old 10-31-2007, 10:54 PM   #2
MooZX3
MooZX3's Avatar
Fan#: 22871
22 views, and no one knows or has ANY ideas on this?
I just thought using the second hole in the air box would give me a chance to make more air available to the TB and such.....
Zetec Crew #193
MooZX3 is offline
Old 10-31-2007, 11:00 PM   #3
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,733, Level 53
Points: 6,733, Level: 53 Points: 6,733, Level: 53 Points: 6,733, Level: 53
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 4 ChrisRobin Good Standing Member
There was a post somewhere around here... I tried looking for it before and couldn't find it. Someone had attached a cone filter directly to the MAF of the stock zetec and then added a little breather filter. I've read up on it, well mostly google'd, and it looks like it doesn't really do anything for performance. I'm going to try it just for the fun of it once I'm done with my intake plans.
ChrisRobin is offline
Old 10-31-2007, 11:17 PM   #4
Kevin Johnson
Fan#: 51284
What I Drive: 1986 Mercedes 300 SDL
FF Reputation: 1 Kevin Johnson Good Standing Member
If you are talking about an aftermarket filter for the crankcase breather there are at least a couple things to keep in mind: 1) if the filter gets wetted out with oil it will increase the resistance to gas flow. In some other forced induction engines this has lead to increased windage effects to the extent that the oil light was triggered; 2) related to 1, a catch can should be used prior to the filter.
Kevin Johnson is offline
Old 10-31-2007, 11:20 PM   #5
MooZX3
MooZX3's Avatar
Fan#: 22871
Yeah, I'm not real sure about that. And the whole MAF thing.
I just wanted to know if adding a small breather straight to the crankcase as you said would cause adverse effects, in any effects at all.
Zetec Crew #193
MooZX3 is offline
Old 10-31-2007, 11:25 PM   #6
Kevin Johnson
Fan#: 51284
If you want to do something to increase the performance, add a metered vacuum valve to that opening and draw vacuum from another area on the engine. Keep the depression to about 10". You need the filter in that reverse flow app to avoid drawing in dirty air to the engine.
Of course, this is all emissions illegal. In older engines what was called a draft tube was run down the side of the block. I have a 1960s Triumph straight six block with one sitting here.
Old 10-31-2007, 11:27 PM   #7
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
^great posts, might even be rep worthy...
anyway, you will not get heat soak from a 3/8" diameter hole...
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 10-31-2007, 11:40 PM   #8
MooZX3
MooZX3's Avatar
Fan#: 22871
I'll 2nd that. Makes sense, but where would do I get that kind of valve? And where would I draw vacuum?
Zetec Crew #193
MooZX3 is offline
Old 10-31-2007, 11:44 PM   #9
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
well it depends how much vac you need, but if it was up to me I would splice into the brake booster.
SUV this!
illinipo is offline
Old 10-31-2007, 11:55 PM   #10
MooZX3
MooZX3's Avatar
Fan#: 22871
which, is....where? Wow..haha mabey this is something I shouldn't attempt myself. This seems like a more "experienced" type job.
What type of benefits would this yield performance wise??
**edit: I guess I takes awhile for REP to show up? That or I screwed it up...
Zetec Crew #193
MooZX3 is offline
Similar Threads
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
Valve Cover Breather Filter?? 02SVTscreamin SVT Performance (2002-2004) 5 09-03-2005 08:42 PM
Help Please!!! I tore my I.t.G Breather filter Dbelle18 General Technical Chat 3 08-05-2004 02:34 AM
Breather filter help blackandgold ZETEC Performance (2000-2004) 1 07-18-2004 05:24 PM
Breather filter function?? blackandgold ZETEC Performance (2000-2004) 14 12-10-2003 06:57 PM
