Spec Focus Build - what does it cost - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 11-08-2007, 11:35 AM   #11
06Roush
Fan#: 45862
What I Drive: Frankenstien
FF Reputation: 60 06Roush Excellent Standing Member
ok would u be able to run in the spec focus if u were running a different kinda shocks? say agx's or something of that nature?
06Roush is offline
Old 11-08-2007, 11:42 AM   #12
LCR
FF Affiliate
Fan#: 36358
What I Drive: 2002 Gray Sedan
FF Reputation: 5 LCR Good Standing Member
You would have to run in PT or HPDE at the NASA event. The Spec Car is for the vehicle built with the spec parts per the NASA rules.
Ford Racing Performance Parts
http://www.capaldiracing.com/
" Quitters Never Win "
LCR is offline
Old 11-28-2007, 02:44 AM   #13
walshka07
Fan#: 48052
What I Drive: 2004 Subaru WRX
FF Reputation: 1 walshka07 Good Standing Member
i used to have a focus... now ive got a wrx, but that doesnt really matter, i want another focus and its going to be a spec focus car, however, it will be a spec focus race car, fun weekend car, HPDE car, and hopefully eventually start a following in texas. anyways here is my question, i ask it because i dont want to have just a spec focus car because NASA events only have 2 races a weekend, i want to be able to run in SCCA too, so im wondering at what class it would run in, honestly im not worried about the car being competitive right now in SCCA, but what class would the car slot into? the car i want would be a 2005 ZX3 and depending on the money i have to work with, i would either build the 2.0 to spec or swap in a 2.3. what are your thoughts on my plans and what class in SCCA would the car slot into? thanks
Matt
walshka07 is offline
Old 11-28-2007, 09:29 AM   #14
MattMarks
Fan#: 46203
What I Drive: 2005 ZX 4 ST Spec Focus
FF Reputation: 1 MattMarks Good Standing Member
First - welcome to the Spec Focus brotherhood - have some of our cool-aid!
Love your plans - here are my thoughts on the Spec Focus build. The nice thing about the 2.3 motor is that you won't run into a lot of costs once the swap is complete - no internal motor work is allowed. It's plug and play. With the Zetec, you're really going to need the Ford Racing Head/Cams and intake manifold sooner rather than later. If you feel comfortable doing that work yourself, that may not be a bad way to go. However, I think you'll really like the 2.3 motor a lot better - more torque and less install headaches. Not sure what they run for around your area, but there are running examples in the Wash DC area here for around $700 or so. Cheap Cheap!
You have two choices in SCCA. You can run SSC (Showroom Stock), which requires a full interior, stock suspension, and a bunch of other stock pieces. Or, depending on the year of the car, you can run Improved Touring (ITS). As I understand it, the Focus is uncompetive in SSC - you'll be running against mini coopers, etc. and your build costs will be siginificantly higher to be even remotely competitive.
Your other choice is ITS. ITs cars have to be (I think) at least 5 years old, but a car built to Spec Focus specs can be reasonably competitive. Where you'd still be lagging would be in the suspension department, as ITS allows adjustable suspensions and higher spring rates than Spec, but you could expect to run mid-pack (depending on skill) after a year or two in ITS with a car that is 100% Spec legal. See www.improvedtouring.com for rules and other ITS information. This would mean that your car might not be ITS legal until next year - but you could spend this year getting it built and running spec and D.E.'s this year and run both next year. FWIW, I'm in the same boat with my 2005.
ANother option might be to check out ITE - which in the DC area is the "Catch all" class that allows just about any car. Most of these are big 400hp turbo cars, but you're on the track and qualify/run with the whole field, so you're still racing with the same cars you would be if you ran with ITS or SSC. Check with your local region on what the requirements are.
If you have other questions, feel free to ask or PM, and I'll be happy to talk to you.
Matt
2007 Spec Focus NASA National Championships - 4th place
2007 NASA Mid-Atlantic Spec Focus Champion
2006 NASA Mid-Atlantic 944 Supercup Champion
Spec Focus Advisory Board - Have a Spec Focus Question? Ask me!
MattMarks is offline
Old 11-28-2007, 12:09 PM   #15
walshka07
Fan#: 48052
i would perferably want to use a 2005 ZX3 just like the one i used to have, i loved that car, so it would be between either building the 2.0 duratec or the headache of swapping in a 2.3, i should be able to get a 2.3 for about 500-600, there are a bunch of junkyards in houston, i am a very competent mechinic and i feel totally comfortable doing the cams, valves, springs, intake manifold, and all thats needed on a 2.0. but to make the motor competitive it seems like ill have to put another 2 grand in it, but if i could sell my 2.0 and recoup the cost of the 2.3 and then just do the small amount of mods to the 2.3 i could build the car for less, the only problem would be that whole motor swap. what are your thoughts? how hard is the swap?
Matt
Old 11-28-2007, 03:53 PM   #16
walshka07
Fan#: 48052
how different are the wiring harnesses from the 2.3 to the 2.0? i figured the swap would be straight forward, but you talk about the wiring like its hell... how much of the 2.0s harness could i use? also would i have to change ECU's or could i just flash the engine to run a 2.3? also tuning is allowed, do you need a flasher of some sort? like my WRX you can just flash the stock ECU without a tuner/flasher... can you do the same with the foucs ECU? i have a bunch of questions if you can tell... ive got a lot more if you dont mind
Matt
Old 11-28-2007, 06:53 PM   #17
NikiterZTS
NikiterZTS's Avatar
Fan#: 28234
What I Drive: 2002 Gun Grey ZTS
FF Reputation: 5 NikiterZTS Good Standing Member
i wanna know what this thing is pushing
http://capaldiracing.com/page6/files...1010-full.html
I'm here to raise that BS flag.Ford Focus ZTS 125whp/129wtq
Subaru Impreza WRX Stage 2 Protuned On Mustang Dyno 207whp/273wtq
I have 5 points on this site :-/
NikiterZTS is offline
Old 11-28-2007, 07:13 PM   #18
MattMarks
Fan#: 46203
I'd bet 250 or so. However, that's Leo's World Challenge car - definately NOT a spec Focus. May want to ask on his forum - he's a site sponsor.
Old 11-28-2007, 07:14 PM   #19
LCR
FF Affiliate
Fan#: 36358
Matt
The 2.0 Duratec and the 2.3 Duratec harnesses are interchangable. I have been going 2.0 to 2.3 back and forth all year in the same car. I keep 2 ecu's 1 2.3 and 2.0
LCR is offline
Old 11-28-2007, 07:17 PM   #20
MattMarks
Fan#: 46203
^^^^^ The man himself speaks
Similar Threads
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 08:04 PM
Australia gets the new Focus next month Kneel Ford Focus & General Car Chat 27 11-26-2007 09:17 PM
Body/Lip Kit Companies S2 MK1 Focus 1 12-04-2004 05:20 PM
Focus 1.8L Zetec UK spec Michael306D-Turbo ZETEC Performance (2000-2004) 4 09-01-2004 04:06 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
