Horn Fuse keeps Blowing! Help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2007, 03:19 PM   #1
Jimmy Turismo
Fan#: 32113
What I Drive: 2002 Silver SVT
FF Reputation: 1 Jimmy Turismo Good Standing Member
OK, so I've replaced the horns, but the fuse keeps blowing. I can't figure out which relay is for the horns though. Anyone come across this, any help is greatly appreciated.
[IMG]http://i50.photobucket.com/albums/f327/02svt/PICT0112.jpg[/IMG]
Jimmy Turismo is offline
Old 10-30-2007, 03:27 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Have you checked your owner's manual?
If you do not have one, you can download one for free from http://www.fleet.ford.com
penguin is offline
Old 07-04-2014, 12:31 AM   #3
pjanda1
Fan#: 170218
What I Drive: 2002 Blue SVT
FF Reputation: 1 pjanda1 Good Standing Member
I know this is an old thread, but it doesn't seem like this is a common problem. Did you ever figure it out? My fuse blows instantly without using the horn. The horn doesn't sound. Must be a short somewhere, but I don't know where to start.
Paul
pjanda1 is offline
Old 07-04-2014, 05:08 PM   #4
FocusKnot
FocusKnot's Avatar
Fan#: 117505
What I Drive: 2004 Red SE Wagon 2.0 Zetec Auto
Points 1,686, Level 23
Points: 1,686, Level: 23 Points: 1,686, Level: 23 Points: 1,686, Level: 23
Level Up 86% Completed
FF Reputation: 3 FocusKnot Good Standing Member
If you pull the horn relay, and the fuse doesn't blow, then the problem is in the horn circuit wiring between the relay and the horn(s), or the horn(s) themselves have shorted out.
I would start by pulling the horn relay. If you pull the horn relay and the fuse still blows, then the problem in the the fuse panel itself because the fuse feeds the relay. If the fuse doesn't blow, then disconnect the horns and put the relay back in. If the fuse doesn't blow after doing that, then one of the horns is shorted out. If the fuse does blow with the horns disconnected, then the short is in the wiring between the relay and the horns.
FocusKnot is offline
Old 07-05-2014, 01:08 PM   #5
garythewolf
Fan#: 84182
What I Drive: 2001 2003 sedan and stationwagon
Points 10, Level 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Level Up 19% Completed
FF Reputation: 1 garythewolf Good Standing Member
go back and re-check what yu had done,,,99 % its something yu did if it worked fine be-fore,,,,,check all wiring closly and you should find it,,,l thought focus has only one horn
garythewolf is offline
Similar Threads
HID Blowing Fuse???? Raziel510 MK1 Focus 3 07-22-2007 11:20 PM
My A/C fuse keeps blowing! SVTORNG General Technical Chat 4 05-15-2007 04:43 PM
Power Point Fuse Keeps Blowing!!! FocusNewGuy General Technical Chat 5 04-08-2006 08:21 PM
Arghh! keep blowing fuse # 50! EuroZX3 Car Audio, SYNC, MyFord Touch & Electronics 7 11-16-2004 02:05 PM
Power locks..fuse keeps blowing solkp General Technical Chat 8 07-21-2004 12:20 PM
