anyone know alot about alignments?? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2007, 04:06 PM   #11
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
[QUOTE=illinipo;1818354]Well I think you can get camber tools at harbor freight [QUOTE]
If it wort for Harbor Freight I wouldnt have half the tools I needed to take my head off of my engine..... Harbor Freight Works for Hard to find Tools... I love Chinese Tools haha
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
Old 10-30-2007, 04:25 PM   #12
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
In the November issue of Sport Compact Car they did a product review (page 113) of the the SPC FasTrax alignment kit. They did the alignment in their shop with the kit and then put it on a laser alignment rack. They were within one tenth of a degree or less on all settings. Pretty damn accurate if you ask me. The MSRP (per the article) is $164.91 for the camber/caster kit and $58.25 for the toe kit. Good article to read even if you're not going to buy one.
Geezer is offline
Old 10-30-2007, 06:05 PM   #13
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Theoretically, you can perform your own alignments.
As Geezer indicates, there are kits available. With access to the base hobby shop, you should be able to access the tools you need to make the adjustments. For the most part, they are hand tools.
If you decide not to go with the kit, then you can use string and a tape measure.
See next post for the "How to"
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 10-30-2007, 06:11 PM   #14
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
DISCLAIMER -
This is a LOT of effort, especially the first time. So, you need to ask yourself how much is your time worth?
I've done it a couple of times at the track, but with a pre-built camber gauge. So, keep that in mind.
I did not write this, but the methodology is sound....
Many people consider suspension alignments to be some sort of black magic, but the concepts are simple and something that any performance enthusiast should understand.
It should only cost you about $20 to perform an alignment at home.
What you need:
.. ~15′ of clear vinyl tubing about 5/16″ diameter $3.00
.. 2 12″ rulers - swipe from office supply at work $0.00
.. ~10-20 pieces of fairly stiff floor tiles 12X12 (left over from the last time you replaced kitchen floor) $2.00
.. 16″ bubble level from Walmart on sale $3.00
.. Piece of wood long enough to span one wheel from lip to lip $0.00
.. 6″ machinists ruler with 1/32″ or better markings $4.00
.. Carpenters Plumbob on sale at Sears $2.00
.. Some kind of fixture for measuring Caster $????
.. Fishing line - about 40 feet $1.00
.. 4 jack stands - should already have $0.00
.. Magnetic base carpenters Protractor $4.00
I didn’t miss the $20 guess by much.
There are some other tools that may help. A “Smart Level” or Lucas digital protractor are very useful tools that will make this an easier process. If I were to spend much money on any one tool it would be one of these. I think they are about $90, but if anything is worth the money, they are. They will just make the job much easier.
First make sure your tires all have proper air pressures. Believe it or not Air pressure can make a difference, so even if you take your car to an alignment shop this should be your first step (don’t expect the mechanic at the alignment shop to do this). You will need to find a level spot in your garage or driveway. For this I use clear tape and attach the two rulers to the ends of the clear vinyl tubing. You can then fill the tubing with water. I usually use the tubing like a straw and draw the water up into the tubing. You need two people to use this as a water level. The idea is the water will be level at both ends of the tubing when the tubing is held upright. You can then stand one ruler where one wheel will be and the other ruler where another tire will be and if the water is at the same level on the two rulers then those two spots are level. You can then adjust the “pads” where the tires will be by making stacks of tile. Each tile is usually about 1/8″ thick so it takes a few tiles to bring up all the low spots up to the highest spot. In your garage you may want to mark these spots and take notes of how many tiles each place needs.
Next you need to find out how true your rims are. I jack up each wheel and sit the jack stand next to the wheel and sit the machinist’s ruler on the jack stand with it extending just to the rim. Then rotate the wheel one turn and see how much runout you have. On most alloy wheels they will have less than 1/32″ which is just fine. On factory steel wheels some wheels may have as much as 1/4″ which will ruin your measurements. Find 2 places on your wheel that are about 180 degrees apart and have the same runout measurement. On almost all wheels there are 2 places you can use to measure, though you may have to search for the spot. I then mark the spots with a pencil or magic marker.
Alternatively you can check the tire for trueness and use the tire for measuring. You can make chalk marks around the tire on the edge of the tread and use a nail or something sharp to make a scribe line around the tread surface near the outside and make all measurements to the scribe line. To do this jack the wheel up so it can spin freely and drive a nail through a piece of wood. Lay the piece of wood on the floor so that the point of the nail just touches the tire tread. When the tire is spun around you will have a true line scratched around the tire. I have found this method of measuring to not be as convenient as using the rim, so use the rim if it is possible. If your rims are true you can assume them to always be true unless you run over a curb or something. This means you don’t have to check them every time you align your car.
Next I like to find the centerline of my car. I do this by using the plumbob draped over my inner suspension mounting points and measuring half way between them. This of course does not work on all cars. Some cars don’t have suspensions that are mirrors of each other, but most do. I will drop the plumbob to the floor and make pencil marks on the floor. Then I will measure on the floor. I found a friend’s Corvette to have a perfectly straight frame, but to body of the car was about 1/2″ crooked on the frame. You can’t go by the center of the bumper or anything like this. Once you have found the C/L carry the mark up to the chassis or body. I made a fine white line on the front of the frame and the rear of the body under the bumper on my Mustang GT with a paint marker. Now I measure from the centerline for all measurements.
Now put the car on the leveled pads. It is best to have rolled the car back and forth a few times to get the suspension settled. Also I should mention that I have made pads out of one square foot cuts of 2″X12″ boards with small angled ramps on the fronts of them. This lifts the car up 2″ making suspension parts easier to get to. I then level with the tiles on top of these pads. It works fairly well making the suspension parts easier to reach.
First I like to check the castor. I seldom make any changes to this adjustment. It is also not that critical to have exactly to some spec, but it is important to have each side even. For this I use the magnetic base protractor. It is accurate to .5 degrees, which I think is adequate for castor measurement. On a Strut car I simply place it on the strut and measure the angle of the strut. This may be off slightly from the spec books, bit the error is correct from side to side and it is fairly close. If you have a car with upper ball joints, first check your spindles for a machined flat spot that is parallel with the ball joint axis. If this exists then you can simply place the protractor on this surface and measure castor. Many cars have this machined surface for various reasons. If it doesn’t then all is not lost. You will need to make some sort of fixture that will “reach in” to the ball joints. You will need a vertical flat surface with two “arms” extending to the ball joints. A 2X4 with 2 long bolts through it may work. You want a vertical surface parallel with the ball joint axis. You can measure this with the surface with the protractor again. You can also measure this in a similar method to how I will measure camber later for more accuracy. This is of course only necessary if your car has some way to adjust castor, which many do not.
Next I like to measure camber. This is the most important measurement in autocrossing in most people’s opinion. I use the short level attached to a piece of wood and the machinist’s ruler for this. I cut the piece of wood so that it will span across from the top wheel lip to the bottom one. I then attach the level to the piece of wood. I use the wood for a couple of reasons. First I can shim between the wood and the level to correct for errors that may occur in the cheap level. I have found most of them to have some small inaccuracies. Also you may need to notch the wood to clear the wheel in the center for the hub. I also have different lengths of wood for the different wheel diameters I work with. To correct for errors I use the plumbob. It will hang vertical. I then shim between the wood and the level until it is indicating level when the board is completely vertical.
Now you must have the two places on your wheel you found to be true to each other, vertical (straight up and down). If your entire wheel is true then it is a great benefit at this point. Take the piece of wood and the level and span across your rim with the level vertical. Now use the bubble and pull out from the top of the wheel until you are holding the level vertical. Now measure from the piece of wood to the top of your rim. It will be a distance of about 1/4″ or so (assuming your car has negative camber). Take this measurement with the machinist’s ruler. Be as accurate as possible. Then you need to take that distance and divide it by the span distance of the piece of wood. For a 15″ wheel you can just use 15″ and a 16″ wheel 16″ etc. Then look up this number in your the trig table in your old high school trigonometry book. You will need to find the arc tangent of the number you have. The degrees of this will be the camber angle.
I have a 10 line basic program that will print a chart for converting these angles I have included in the end of this article. I have also included a chart that will convert this measurement without dividing and looking up the measurement. I now prefer to keep my measurements in inches of gap at the top of the wheel rather than converting them to degrees. I keep my logbooks in this measurement rather than degrees for each car. It only causes a problem if I change the rim diameters of any one car I am working with.
For toe in measurement I need to reference the centerline of the car. First you need to get the measuring points on your wheels at 9 and 3 o’clock. This is again where it is helpful to have true wheels, then you don’t have to move the car. You will need the jack stands and fishing line for this, plus the machinist’s ruler. You want to set up the fishing line outside the sides of the car an equal distance from the centerline of the car. I tie the fishing line to the jackstands so that the line when stretched will be about equal height to the center of the wheel hubs. This does not have to be exact, but close to the wheel hub center. Measure out from the centerline to about 3″ outside the wheels. The setup will look like this when viewed from above:
jack stands –> X——————————————–X
Car —> | |
| Wheels |
| V |
X———————————————X
Fishing line/
It is important to get the fishing line parallel to the centerline of the car. You can’t measure to the rocker panel or the wheel hubs or anything initially because they may or may not be parallel to the centerline. So the first time measure from the centerline that you found before. Now it is good to then measure from the bottom corners of the door or the rocker panel or something and record the measurement in your logbook. It will make the setup much faster if you want to change your toe quickly at an event. It should be noted that a perfectly level pad is not necessary for toe setting. It is good to get the car on a fairly level spot but exactly level is not important.
Then to measure the toe, measure at the front edge of the rim and the rear edge of the rim and subtract the difference. That will give you the toe measurement. Obviously for toe-in the measurement at the rear of the wheel (from the fishing line to the edge of the rim) will be less than the measurement at the front of the wheel. The reverse is true for toe-out and the two measurements will be equal for zero toe. The measurements you will be working with will actually be less than what is usually referenced in spec books, because the diameter you are working with is the rim diameter. The measurement most cars use is taken at the tread surface, so you may need to make some conversions depending on the specs for your car. Find out how the specs you are working with are measured. Some cars give angles of toe in degrees, some are inches of toe on each side, and some are total toe added together between the sides. Make sure you are working with apples and apples not apples and oranges.
Each time you make a toe adjustment recheck your steering wheel if you have not locked it. When you adjust one side the steering wheel usually moves and must be re-centered before you take new measurements. Locking the wheel some way will make the job easier.
As you are making changes take a note of what one shim here and one turn of the tie rod there changes and how much. You will notice that a camber change changes the toe drastically, but as toe change does very little to the camber, etc. When you get used to these things, changing your toe settings as you are changing tires at an autocross is a rather simple matter and changing it back to the original toe setting when it is time to drive home is easy if you have made a few marks. On my Mustang GT I have marked the strut tops as to what change is what camber and have 2 marks on each tie rod end. I used to change the camber and toe at each event, but I now leave the negative camber in and dial in a little extra toe-out before an event and can feel confident about resetting it correctly before I drive home. I check it occasionally just to make sure the frame hasn’t changed.
It takes a couple of hours the first time you do an alignment. But once you have done this a couple of times you can do a complete check of your alignment in a couple of minutes in your garage and at an event you can locate a flat spot and check a car completely before you run. It is really fairly easy to do once you get used to it.
Here is the chart I promised. It goes up to 6 degrees of negative camber. The way you use it is to look up the gap between the level and the rim at the top on the diameter rim you are using and look on the left column and find the number of degrees. I have included the tangent of the angle just for good measure.
deg | tan 17″ 16″ 15″ 14″ 13″
0.1 | .0017 0.0297 0.0279 0.0262 0.0244 0.0227
0.2 | .0035 0.0593 0.0559 0.0524 0.0489 0.0454
0.3 | .0052 0.0890 0.0838 0.0785 0.0733 0.0681
0.4 | .0070 0.1187 0.1117 0.1047 0.0977 0.0908
0.5 | .0087 0.1484 0.1396 0.1309 0.1222 0.1134
0.6 | .0105 0.1780 0.1676 0.1571 0.1466 0.1361
0.7 | .0122 0.2077 0.1955 0.1833 0.1711 0.1588
0.8 | .0140 0.2374 0.2234 0.2095 0.1955 0.1815
0.9 | .0157 0.2671 0.2513 0.2356 0.2199 0.2042
1.0 | .0175 0.2967 0.2793 0.2618 0.2444 0.2269
1.1 | .0192 0.3264 0.3072 0.2880 0.2688 0.2496
1.2 | .0209 0.3561 0.3352 0.3142 0.2933 0.2723
1.3 | .0227 0.3858 0.3631 0.3404 0.3177 0.2950
1.4 | .0244 0.4155 0.3910 0.3666 0.3422 0.3177
1.5 | .0262 0.4452 0.4190 0.3928 0.3666 0.3404
1.6 | .0279 0.4749 0.4469 0.4190 0.3911 0.3631
1.7 | .0297 0.5045 0.4749 0.4452 0.4155 0.3858
1.8 | .0314 0.5342 0.5028 0.4714 0.4400 0.4085
1.9 | .0332 0.5639 0.5308 0.4976 0.4644 0.4313
2.0 | .0349 0.5937 0.5587 0.5238 0.4889 0.4540
2.1 | .0367 0.6234 0.5867 0.5500 0.5134 0.4767
2.2 | .0384 0.6531 0.6147 0.5762 0.5378 0.4994
2.3 | .0402 0.6828 0.6426 0.6025 0.5623 0.5221
2.4 | .0419 0.7125 0.6706 0.6287 0.5868 0.5449
2.5 | .0437 0.7422 0.6986 0.6549 0.6113 0.5676
2.6 | .0454 0.7720 0.7266 0.6811 0.6357 0.5903
2.7 | .0472 0.8017 0.7545 0.7074 0.6602 0.6131
2.8 | .0489 0.8314 0.7825 0.7336 0.6847 0.6358
2.9 | .0507 0.8612 0.8105 0.7599 0.7092 0.6586
3.0 | .0524 0.8909 0.8385 0.7861 0.7337 0.6813
3.1 | .0542 0.9207 0.8665 0.8124 0.7582 0.7041
3.2 | .0559 0.9504 0.8945 0.8386 0.7827 0.7268
3.3 | .0577 0.9802 0.9226 0.8649 0.8072 0.7496
3.4 | .0594 1.0100 0.9506 0.8912 0.8318 0.7723
3.5 | .0612 1.0398 0.9786 0.9174 0.8563 0.7951
3.6 | .0629 1.0695 1.0066 0.9437 0.8808 0.8179
3.7 | .0647 1.0993 1.0347 0.9700 0.9053 0.8407
3.8 | .0664 1.1291 1.0627 0.9963 0.9299 0.8635
3.9 | .0682 1.1589 1.0908 1.0226 0.9544 0.8863
4.0 | .0699 1.1888 1.1188 1.0489 0.9790 0.9090
4.1 | .0717 1.2186 1.1469 1.0752 1.0035 0.9319
4.2 | .0734 1.2484 1.1750 1.1015 1.0281 0.9547
4.3 | .0752 1.2782 1.2030 1.1279 1.0527 0.9775
4.4 | .0769 1.3081 1.2311 1.1542 1.0772 1.0003
4.5 | .0787 1.3379 1.2592 1.1805 1.1018 1.0231
4.6 | .0805 1.3678 1.2873 1.2069 1.1264 1.0460
4.7 | .0822 1.3977 1.3154 1.2332 1.1510 1.0688
4.8 | .0840 1.4275 1.3436 1.2596 1.1756 1.0916
4.9 | .0857 1.4574 1.3717 1.2860 1.2002 1.1145
5.0 | .0875 1.4873 1.3998 1.3123 1.2248 1.1374
5.1 | .0892 1.5172 1.4280 1.3387 1.2495 1.1602
5.2 | .0910 1.5471 1.4561 1.3651 1.2741 1.1831
5.3 | .0928 1.5770 1.4843 1.3915 1.2987 1.2060
5.4 | .0945 1.6070 1.5124 1.4179 1.3234 1.2289
5.5 | .0963 1.6369 1.5406 1.4443 1.3480 1.2518
5.6 | .0981 1.6669 1.5688 1.4708 1.3727 1.2747
5.7 | .0998 1.6968 1.5970 1.4972 1.3974 1.2976
5.8 | .1016 1.7268 1.6252 1.5236 1.4221 1.3205
5.9 | .1033 1.7568 1.6534 1.5501 1.4468 1.3434
6.0 | .1051 1.7868 1.6817 1.5766 1.4715 1.3664
This is a hard process to explain without hands on aids. I taught a seminar for our sports car club on how to do this and everyone thought it was easy after they did it a few times. I got several phone calls the day after the seminar as everyone went home to do an alignment for the first time themselves, but they were all able to align their own cars correctly.
It is really easy to do and it gives you a great deal of confidence in how your car was setup. I will try to answer all questions. I’m sure I was not as clear as I would have hoped to be in some places.
WeeAsp is offline
Old 10-30-2007, 06:54 PM   #15
blackturbohatch46
blackturbohatch46's Avatar
Fan#: 31359
What I Drive: 2003 Pitch Black ZX3
Points 1,602, Level 23
Points: 1,602, Level: 23 Points: 1,602, Level: 23 Points: 1,602, Level: 23
Level Up 2% Completed
FF Reputation: 1 blackturbohatch46 Good Standing Member
wow thats pretty involved. i think i need to get a house with a garage. i will still try this before i take it to a shop though. thanks for all of the good advice.
Never Trust a Helicopter Under 40.
Focus Central Short Shifter, Roush Turbo Kit, Focus Sport UPD, SVT Brake Kit, RT Cat, Focus Central Cam Gears, Focus Sport Plugs and Wires, Focus Sport Front and Rear Stress Bars, Focus Central 65mm TB, Borla Exhaust, Greddy Turbo Timer, Greddy e-01 Computer, OZ Superleggeras, H&R Coilovers, ACT Clutch, Focus Sport Flywheel, Greddy Gauges.
blackturbohatch46 is offline
Old 10-30-2007, 07:02 PM   #16
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
W H O A ! ! ! ! ! ! ! ! ! !
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 10-31-2007, 08:37 AM   #17
pat247
pat247's Avatar
Fan#: 27781
What I Drive: Focus SVT
FF Reputation: 19 pat247 Great Standing Member
Buy-Sell-Trade Rating: (17)
WeeAsp, you made my head hurt.
2003 ZX5 SVT, Pitch Black, JRSC/BBK Sold
pat247 is offline
Old 10-31-2007, 08:42 AM   #18
DFv2
WWTPD?
DFv2's Avatar
Fan#: 42684
What I Drive: 2008 Lightning Red STi
FF Reputation: 31 DFv2 Great Standing Member
And so we realize that the $85 bucks is TOTALLY worth not having to align your own wheels.
DFv2 is offline
Old 10-31-2007, 12:59 PM   #19
Geezer
Fan#: 1427
The method that WeeAsp posted is old school. While there are still people who do that, they are few and far between. The gauges/kits mentioned eliminate the painful calculations (a little math still has to be done for toe settings but that's it). The kits are really good for autocrossers and road racers who what to make quick accurate adjustments at the track. For the guy who does one alignment a year, they don't make much sense economically.
Geezer is offline
Old 10-31-2007, 01:25 PM   #20
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Ah gees, I guess I am "old school"...LOL!
I can set up the strings, and do 2 complete measure/adjust-measure/adjust settings in well under an hour.
I did have the pleasure of borrowing one of these:
http://www.racerpartswholesale.com/art1.htm
Worked great, but the setup time took longer than it takes me to pull out a 24" level, 1/32" graduated scale, and a calculator.
Thanks for the mega write-up WeeAsp!
There's a few variations on a theme so to speak as far as how I perform my own alignments,
but the majority of what's written will get the job done and then some.
^^^Oh, that can be SO true! I laughed pretty hard when I read that.
WD40 is offline
Similar Threads
shifter moves alot! crobro24 ZETEC Performance (2000-2004) 12 09-14-2007 07:49 PM
Alot Of Stuff Cheap!!! PizZel Archive 36 11-09-2003 01:24 PM
