Problem when power bleeding brakes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-23-2007, 11:29 PM   #1
tt460
Fan#: 50779
What I Drive: 2003 Metallic Blue ZTW
FF Reputation: 1 tt460 Good Standing Member
I just did a SVT brake kit upgrade on my '03 Focus SE Wagon with ABS and bled the brakes with a Motive Products power bleeder.
I've bled other cars using this power bleeder, but the Focus did something strange after I made it all the way around bleeding the brakes. I did the rear brakes first, then front brakes. Everything seemed fine. I went back to the rear brakes to make sure I got all of the air from the system and couldn't get anything to come out of the rear passenger side brake caliper or the driver's side front caliper. The system is pumped up to 25psi and has plenty of fluid in the reservoir and pressure tank... Nothing comes out when I crack the bleeders on those two brake calipers.
Has anyone else had a problem like this when bleeding their Focus brakes? Does the ABS unit have to be bled at all? What about the M/C, are their bleeders on it that need to be bled?
Thanks for any info you can share.
tt460 is offline
Old 10-23-2007, 11:48 PM   #2
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
Points 5,927, Level 49
Points: 5,927, Level: 49 Points: 5,927, Level: 49 Points: 5,927, Level: 49
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 17 wickedgreyzx3 Great Standing Member
are the bleeders plugged?
Also you shouldn't need to open the abs to bleed but it may need to be actuated by a scan tool once it's bled or you will never have a brake pedal.
I'd suggest grabbing a friend and doing it the West Virginia way.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 10-23-2007, 11:50 PM   #3
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Could be the bleeders are plugged...did you try removing them completely? When I installed my SVT rear discs one of the bleeders wouldn't flow so I just loosened it until the fluid came out around the bottom of the bleeder.
SkaAddict is offline
Old 10-23-2007, 11:55 PM   #4
wickedgreyzx3
Fan#: 34204
When I first started working on cars my boss was bleeding with me and it wouldn't go and he said pull it out and blow on it to see if it was plugged.
Needlessly to say he fell out of a crown vic 2 feet in the air laughing at me.
Old 10-24-2007, 01:20 AM   #5
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Have you tried the old school way...with an assistant pumping the pedal? I have a complete brake fluid exchanger but its fairly close to your motive bleeder in design. But I will tell you the exchanger is great for replacing fluid, very easy to use and quick, however its not great for removing air. It will take out a little but not much. When removing air it will go much faster and much easier with an assistant. I just pulled the calipers off my svt to put on cross drilled rotors and paint the calipers and had to air bleed the system with an assistant and not the exchanger. Hope this helps buddy
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 10-24-2007, 01:41 AM   #6
SkaAddict
Fan#: 1690
A power bleeder puts positive pressure on the fluid in the reservior, so as soon as one of the bleeders opens fluid is going to start running out. I've bled my brakes and clutch several times with my power bleeder and have never had a problem with it pushing air out, its either a plugged bleeder or a problem with the ABS package.
Old 10-24-2007, 02:06 AM   #7
duc450
duc450's Avatar
Fan#: 10651
ordinarily I would agree with ya bud but I used both of these methods just this weekend and if the bleeder was plugged then pressing the brake pedal wouldnt work neither but it did. I'm wondering if the secondary piston in the mc is blocking fluid flow unless the brake pedal is actually depressed. That would explain why the fronts are flowing and the rears aren't. But give it a try bud and see if she works and hey if not my apologies for being wrong.
duc450 is offline
Old 10-24-2007, 02:07 AM   #8
SkaAddict
Fan#: 1690
Check his post again, the calipers that won't bleed are on opposite corners (driver/front and passenger/left.)
Old 10-24-2007, 06:54 AM   #9
tt460
Fan#: 50779
I have a 1-man bleeder bottle and hooked that up and pumped the brakes a few times, I also had the power bleeder hooked up at the same time. Got the same results with nothing or very little fluid coming out of the same two calipers (drivers front, passenger rear). To me that's about as good as the buddy system.
I pulled both bleeders out completely and no fluid flowed out of the calipers. I'm pretty confused at this point. I'll try to see if something is clogging the hole that feeds the bleeders when I get home from work tonight.
Thanks for the feedback guys!
tt460 is offline
Old 10-24-2007, 09:24 PM   #10
tt460
Fan#: 50779
Well, I tried bleeding the brakes again and guess what: everything worked the way it is supposed to!
Must've been a bubble in the M/C or something that wasn't letting the fluid through. After sitting over night it's working fine and I bled the two brakes that gave me problems and fluid flowed fine. One pump of the pedal and it pumped right up and got hard the way it should.
Thanks for all the info. You guys are great.
tt460 is offline
Similar Threads
Problem...i think brakes!!! DrkKnight614 Brakes, Suspension & Body Chassis 8 04-12-2006 08:26 PM
clutch bleeding problem chetn20 DURATEC Performance (2003-2007) 4 03-29-2006 01:12 AM
Power steering problem on an 04? Toolman00 SVT Performance (2002-2004) 6 11-27-2005 11:02 PM
Power Brakes failure Arlan General Technical Chat 4 06-10-2005 01:41 PM
Engine Power Loss Problem? RB SVT Performance (2002-2004) 9 05-12-2005 12:55 PM
