Thermostat housing leak - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-22-2007, 03:41 PM   #1
02_zxFIVE
Fan#: 33790
What I Drive: 2002 Liquid Grey ZX5
FF Reputation: 2 02_zxFIVE Good Standing Member
I sprung the famous thermostat housing leak. luckily I am the type to research instead of just post shit up.
So when my car started overheating, I did my normal checkout, found out my fluid was leaking, I ruled out BHG just because the signs weren't there. After researching, I found that the thermostat housing likes to go out, in my case due to an oil leak from shitty valve cover gaskets letting the hot oil drip on the cheap plastic housing.
Yesterday i ventured to my local auto parts store(s), and it appears, the only thing i can get for the thermostat housing is the water outlet and gaskets... which isn't leaking. I pick up the water outlet, all the gaskets i need, a new thermostat for shits and giggles (hell, im gonna have it open, might as well swap it with something new).
Now, am I going to need a new thermostat housing (the actual housing, not the water outlet), or should the gasket only fix my problem. I went to Auto Zone, Advance Auto and Car Quest, none had the actual housing, just that outlet. If i only replace the gasket, would i be safe? I'm still waiting for my valve cover gasket to come in, i do not want to jump into this project if i need something else, obviously if i do, once i loosen that first bolt my car is inoperable.
2002 Focus ZX5 -Stock - FUTURE PLANS: Get rid of it and buy an SVT... if it'll make it back to Cali
02_zxFIVE is offline
Old 10-22-2007, 03:45 PM   #2
IcEMage
IcEMage's Avatar
Fan#: 34864
What I Drive: 2010 Tacoma X-Runner
FF Reputation: 3 IcEMage Good Standing Member
If the housing is cracked or broken then you deff should get a new one (that was the case with mine when I had the ZTS) If they dont have them they should be able to order them or just go to your local ford dealer :)
IcEMage is offline
Old 10-22-2007, 03:46 PM   #3
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
What I Drive: 2003 SVT Focus
Points 9,623, Level 65
Points: 9,623, Level: 65 Points: 9,623, Level: 65 Points: 9,623, Level: 65
Level Up 91% Completed
Forum Activity 2%
FF Reputation: 21 egman2005 Great Standing Member
Buy-Sell-Trade Rating: (7)
From what i have heard you are going to need the housing. It comes with a new gasket and that will fix your problem
egman2005 is online now
Old 10-22-2007, 04:21 PM   #4
02_zxFIVE
Fan#: 33790
the whole thing is finding the part :( every place i went, when searching for thermostat housing, the only thing that comes up is that water outlet.... i hope i dont have to go to a dealership for it.
Old 10-22-2007, 05:37 PM   #5
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
It's a dealer part. Check sponsors. Alot cheaper than going to local dealer.
TerryB is offline
Old 10-22-2007, 05:43 PM   #6
02_zxFIVE
Fan#: 33790
that sucks
Old 10-22-2007, 08:31 PM   #7
jdaddona
Fan#: 44467
What I Drive: black '02 zx3
FF Reputation: 1 jdaddona Good Standing Member
puttin my new housing in tomorrow...haha, you said they have the water outlet at auto zones? and the thermo HOUSING gasket? not the thermostat gasket, my actual thermo gaskets fine the housing gasket was shredded tho. the housing was on fordparts.com for only 20 something
-Jay Dee
jdaddona is offline
Old 10-22-2007, 10:34 PM   #8
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Considering the work involved, and the low relative cost of gaskets, it is generally considered a good idea to replace all the gaskets, even if they look fine.
penguin is offline
Old 10-23-2007, 12:50 AM   #9
NintendoSkater
NintendoSkater's Avatar
Fan#: 43536
What I Drive: '07 Scion tc coupe
Points 2,975, Level 33
Points: 2,975, Level: 33 Points: 2,975, Level: 33 Points: 2,975, Level: 33
Level Up 50% Completed
FF Reputation: 1 NintendoSkater Good Standing Member
Ugh, thermostat housing is kind of a pain to replace (just that large back bolt), you'll be done around the time your fingers go numb.
2007 Scion TC coupe
NintendoSkater is offline
Old 10-23-2007, 11:02 AM   #10
andr3wg
andr3wg's Avatar
Fan#: 48134
What I Drive: 2000 Silver ZX3
FF Reputation: 1 andr3wg Good Standing Member
if your valve gaskets leaking that probably caused the thermostat housing to crack.
andr3wg is offline
Similar Threads
Need someone in Portland, Oregon to fix thermostat housing leak 1badassfoci North West Fanatics 0 08-09-2007 03:44 AM
Quick Way to stop leak by housing of the thermostat benokona ZETEC Performance (2000-2004) 8 01-10-2007 09:39 AM
thermostat housing leak? vito313 General Technical Chat 10 11-23-2006 04:24 PM
Thermostat Housing leak and Warrenty.. klepto General Technical Chat 5 09-08-2006 03:12 PM
:: Cracked Thermostat Housing Assembly :: ..:: sleestak ::.. General Technical Chat 8 08-11-2006 09:35 AM
