Rear sway bar install problems.. PLEASE HELP! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-21-2007, 09:21 PM   #1
focusonthis420
focusonthis420's Avatar
Fan#: 30951
What I Drive: SGM 2012 5dr
FF Reputation: 17 focusonthis420 Great Standing Member
Buy-Sell-Trade Rating: (26)
Angry Rear sway bar install problems.. PLEASE HELP!
Alright so i decide to finally install my progress rear sway bar that i bought a month ago. ok, so i unbolted the endlink assemblies on either end then moved on to the U brackets. Right side... nice and easy, both bolts came out fine. On to the left side... bottom bolt came out easily. Moved on the top bolt and wouldnt you know it, the stationary nut or whatever that is welded to the car (that the bolt threads through) snaps free from its weld. Fantastic! So i spent the next hour trying to figure out how to get a wrench or something on that nut so i could unscrew the bolt. After an hour or so and after stripping the hex head of that crappy bolt i finally gave up. Bolted everything back up and left the stock bar on. Only problem now, i have a somewhat loose top bolt holding the left U-bracket. Anyone know of a (easy) way to get to that bolt out?
Sterling Gray Metallic 2012 5dr Titanium w/ MS3 RMM
focusonthis420 is offline
Old 10-21-2007, 10:32 PM   #2
cayres
cayres's Avatar
Fan#: 35184
What I Drive: 03 Comp Orange EAP SVT, 06 ZX3 SES
FF Reputation: 8 cayres Good Standing Member
a cut off wheel or sawzaw
cayres is offline
Old 10-22-2007, 09:07 PM   #3
focusonthis420
Fan#: 30951
ok ill try a "sawzall" cuz i know i wont be able to get a cut-off wheel in the small space i have to work with
Old 10-22-2007, 09:27 PM   #4
grahama
grahama's Avatar
Fan#: 20127
What I Drive: 2003 Black ZTW
FF Reputation: 1 grahama Good Standing Member
what about using locking pliers to clamp on and remove the crappy bolt?
I did that when my oil drain bolt stripped
grahama is offline
Old 10-22-2007, 09:30 PM   #5
stivo
Hiyadoin'
Fan#: 48389
What I Drive: 2004 Infrared SVT, EAP #1440
FF Reputation: 9 stivo Good Standing Member
Buy-Sell-Trade Rating: (6)
use vise grips and liquid wrench if the bolt is frozen. try not to destroy the "nut" in the process, maybe you can get a welder to put it back together for you.
stivo is offline
Old 10-22-2007, 11:13 PM   #6
focusonthis420
Fan#: 30951
trust me, with the location of this nut, the only access is from the top. you cant get a wrench or vice grips or anything on this thing. i guess a sawzall is my only choice. the exhaust passes right over the top of it, look at your left sway bar U-bracket and you will know what i am talking about
it looks like the picture i have below. i tried to draw a diagram of it the best i can. the nut sits inside that grey opening and you can only get to it from the top since the lower nut blocks any access from the bottom. they both were stationary nuts, but the one broke free from its welds. now the bolt is backed off out of the nut like 1/4 inch or so
Old 10-23-2007, 12:30 PM   #7
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
I'd take it to a muffler shop (if you don't have access to a welder and have that nut welded/tacked back on while its still in the correct location. May prevent a lot of problems later on.
Geezer is offline
Old 10-23-2007, 12:56 PM   #8
cayres
cayres's Avatar
Fan#: 35184
You could do what geezer said but i wouldnt go threw the trouble. Bolts that are welded dont really need to be welded, they do that for ease of removal..look at the rear LCA bolt (The outside one) that is welded, if you go to ford and ask what to do if its broken they sell you nut and bolt combo for like 15 dollars. I would save time and cash and just go to the hardware store and get a nut and bolt, same size and strength grade and put her on. If your worried bout the welded bolt and such get a lock washer, or after you put then new bolt on the just get it tacked. I would agree with everyone else on trying to salvage it but chances are if it broke the weld trying to take it off its prolly seized badly.
cayres is offline
Similar Threads
Review of rear H&R 24mm Sway Bar Oni Brakes, Suspension & Body Chassis 10 06-29-2013 10:22 PM
Urethane rear sway bar bushings Polk Wheels & Tires 4 02-28-2008 01:16 PM
F.S. : Eibach Rear sway bar with mounts to fit 05 - 06 focus without factory rear bar kiwanoron Archive 0 04-04-2006 01:47 AM
race in stock with rear sway bar? petehouk Autocross Racing 3 03-14-2006 01:00 PM
