Magnetic Oil Drain Plug - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-17-2007, 11:07 PM   #1
fhg959
SE HABLA ESPAÑOL
fhg959's Avatar
Fan#: 50640
What I Drive: 06 Big-Egg Rally
Points 11,602, Level 70
Points: 11,602, Level: 70 Points: 11,602, Level: 70 Points: 11,602, Level: 70
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 52 fhg959 Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Has any one try these magnetic plugs that supposedly prolong engine life??
I got this from a description on ebay.
Prolong the life of the engine and it's performance level by installing a magnetic oil drain plug. Metal particals produced by normal wear and tear could cause more damages to the engine. Replace the original drain plug with this MAGNETIC OIL DRAIN PLUG will attract and remove harmful metal particles that are floating within the motor oil and prevent them from causing harmful damages.
The MAGNETIC OIL DRAIN PLUG is a great investment and it keeps the metal particals from causing further damages between oil changes. The installation is very easy. Simple remove the original plug during your next oil change and replace it with the magnetic unit, there is no modification needed. After that, to maintain the performance level of the plug, simply wipe off the particles that are attracted on the plug during each oil change before you install it back on the the vehicle.
Is it a waste of money and time, or does it really help the engine to run cleaner??
fhg959 is online now
Old 10-17-2007, 11:20 PM   #2
TKE_Quailman
FF God of South FL
TKE_Quailman's Avatar
Fan#: 44442
What I Drive: 07 Pitch Black ZX3
FF Reputation: 35 TKE_Quailman Great Standing Member
well the throey is solid but im not to sure
02 Black ZX5 R.I.P.
07 Black ZX3 Work in progress
Last of the Hatches #1
XBOX LIVE:TKE428
GIVE REP POINTS IF IM HELPFUL
TKE_Quailman is offline
Old 10-17-2007, 11:22 PM   #3
Hillyard
Supercharged
Hillyard's Avatar
Fan#: 10982
What I Drive: 2002 ZX3 SVT, 2004 Ford Ranger 4x4
Points 13,364, Level 75
Points: 13,364, Level: 75 Points: 13,364, Level: 75 Points: 13,364, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 2 Hillyard Good Standing Member
Buy-Sell-Trade Rating: (27)
They use them on the Ranger manual transmissions from the factory.
#3788 InfraRed SVT
Hill <><
Hillyard is offline
Old 10-17-2007, 11:41 PM   #4
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
generally speaking yes they work, but... they will just get caught in the oil filter, now if you go a billion miles between oil changes then yes they could work
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 10-18-2007, 12:18 AM   #5
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
A magnetized plug is going to do very little, if anything, to catch metal out of oil or transmission fluid, regardless of how strong it is due to its small surface area. Its just a gimmick, not to be confused with the relatively large rectangular magnets put in manual transmissions (which have no filter) to catch filings.
If you take the pan off and install a big magnet inside you could say it would do something, but a little plug that's less than a half-inch across? Take the money you'd spend on the plug and buy a better filter.
SkaAddict is offline
Old 10-18-2007, 12:28 AM   #6
tomthewdwrkr
Fan#: 38956
What I Drive: 2006,liquid grey,zx5, ses, sap
FF Reputation: 2 tomthewdwrkr Good Standing Member
http://filtermag.com/
tomthewdwrkr is offline
Old 10-18-2007, 12:31 AM   #7
Xetchx
Xetchx's Avatar
Fan#: 49113
What I Drive: 03 Silver SVT
FF Reputation: 23 Xetchx Great Standing Member
I thought they always made drain plugs magnetic?? do they not do that anymore??
and as for saving the engine there really isn't that much magnetic surface area from just the plug, but it helps alittle
the gimic thing I always wanna try is the Magnet wrap for the oil filter, anybody tried one of those?
"If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way"
Originally Posted by Trav-E2.0 View Post
I'm not hard, I'm fluffy...lol
#2846
Xetchx is offline
Old 10-18-2007, 02:14 AM   #8
SkaAddict
Fan#: 1690
There was someone on here a while ago who had one and we had a long, drawn-out discussion about it. What it boiled down to (for me) was they claim it catches small metallic particles that are too small to be caught by the oil filter...however, if a piece of metal is small enough to pass through the filter media unhindered, its not very likely to cause significant engine damage. Odds are you could run two identical cars for the same number of miles, with the only difference being one has the "Filtermag" and the other doesn't, and at the end there wouldn't be any appreciable difference.
Old 10-18-2007, 02:23 AM   #9
CleanZX3
Fan#: 4970
What I Drive: 2007 CD Silver ZX4 ST S.A.P
FF Reputation: 12 CleanZX3 Great Standing Member
I work on fleet vehicles for a living, and can tell you magnetic drain plugs DO catch metal shavings. The metal shavings sink to the bottom of the oil pan, where the drain plug is located.
Transmissions come from the factory with magnets to catch metal shavings.
I say its worth the few bucks to buy the drain plug. You can also buy these at your local auto parts store.
CleanZX3 is offline
Old 10-18-2007, 03:19 AM   #10
fhg959
SE HABLA ESPAÑOL
fhg959's Avatar
Fan#: 50640
So then is worth to get the Filtermag and the magnetic drain plug?
Similar Threads
SVT Stage II Cams? topherdopher SVT Performance (2002-2004) 36 03-19-2007 03:26 PM
Wrench size for MTX-75 drain plug? Walipala General Technical Chat 10 01-25-2007 10:48 AM
Drain Plug Issue nstiesi Ford Focus & General Car Chat 4 06-07-2006 09:01 AM
stripped torx oil plug on back of block... joene2004 General Forced Induction 6 01-08-2006 03:44 PM
Magnetic Oil Drain Plug? svtfocusmansvt General Technical Chat 5 03-17-2005 11:03 PM
