Idle Air Control Valve? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2009, 11:31 PM   #21
SKPISTE
Fan#: 68422
What I Drive: 1987 VW Vanagon Syncro / Zetec DOHC
FF Reputation: 1 SKPISTE Good Standing Member
IACV fixed mine. Check your speed sensor as well.
PM
PDX
USA
2.0 DOHC ZETEC / 87 VW Syncro
SKPISTE is offline
Old 08-18-2009, 05:37 PM   #22
jeangreyfan
Fan#: 66356
What I Drive: 2000 Blue Focus SE
FF Reputation: 1 jeangreyfan Good Standing Member
i had to have a new one put on when i got a new motor...my car was throwing IAC codes and it still has a funny idle. it idles too high (around 2000 and stays there)when i have the a/c off and have the clutch pressed in to change gears (as long as i have the clutch pushed in, it will not idle down...). it doesn't do it when the a/c is on which i think is strange...
jeangreyfan is offline
Old 06-03-2012, 08:54 PM   #23
minaxue
minaxue's Avatar
Fan#: 98036
What I Drive: 2002 Silver ZX3
FF Reputation: 1 minaxue Good Standing Member
Mine does that! Sorry I'm rehasing an old thread, but this has been helpful! I just inherited my focus and experience this. The battery light comes on randomly, and when I came to stop it stalled and died. I've read IAC vavle might be the issue so I'm check it first, esp after this thread!
minaxue is offline
Old 06-04-2012, 07:46 AM   #24
TrixAreForKidss
Fan#: 33924
What I Drive: 2001 Midnight Blue ZX3
FF Reputation: 1 TrixAreForKidss Good Standing Member
Originally Posted by NintendoSkater View Post
Hm thats weird, my check engine light isn't on, but the battery one is. To keep it from stalling at stoplights and stuff I have to put it in neutral, put on the e-brake and keep my foot on the gas. I must be gettting like 16mpg now
If I can't find the IAC valve by friday its going to the dealership.
It's not your IAC, its your alternator/dead battery. Check the battery voltage, and if its good check your alternator. The connector on the alternator might be damaged, or it could just be dying. If you replace it, check the grounding wire from the battery for corrosion, had the same problem with mine, the entire wire was corroded through inside the ring terminal.
2001 Midnight Blue ZX3 - owned for 7 years.
TrixAreForKidss is offline
Old 08-27-2012, 08:54 PM   #25
dpottle8
Fan#: 103138
What I Drive: 2002 Silver zts
FF Reputation: 1 dpottle8 Good Standing Member
Did it work
My 02 Zts focus is doing the same thing.... when I come to a stop it shuts down if I do not keep my foot on the brake, I changed the EGR valve (I think thats what it is called) and it worked for a little but it still is shutting down and doesn't idle without having my foot on the gas.... did cleaning the Idle Air Control Valve make your car idle normal?
dpottle8 is offline
Old 09-12-2012, 06:40 PM   #26
micsachek
Fan#: 103604
What I Drive: 2001 green ford focus zx3
FF Reputation: 1 micsachek Good Standing Member
ok i have a 2001 ford focus zx3 dohc. my car is throwing 3 codes at me. 1. mass air flow sensor 2. o2 sensor and 3. iac
i changed out the mass air flow sensor and the o2 sensor so i just need the iac but i cant seem to find it, anyone help me on where this thing is? i dont know anything about cars so please be patient with me if i seem to not know what your talking about but you help would be greatly appreciated!
also after i change this iac, my check engine light should go off as long as its not throwing any more codes correct?
micsachek is offline
Old 09-13-2012, 12:50 AM   #27
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
yes, cleaning or replacing the IAC fixed the warm-stall problem that many of us encountered.
Your IAC is most easily accessed from underneath the car, as if you are replacing the oil filter. See this post for photos:
http://www.focusfanatics.com/forum/s...=262990&page=2
Many of us who have had dirty/faulty IAC's did not throw a code, so I can't comment on whether a new one will clear your code, but it seems reasonable that it will.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-25-2013, 09:52 AM   #28
bobby2113
Fan#: 110408
What I Drive: 2001 grey lx
FF Reputation: 1 bobby2113 Good Standing Member
Thumbs up
I just replaced the IAC on my 2001 Focus lx with the SOHC (Single overhead valve) engine. It was a piece of cake! The car was experiencing sporatic stall problems after warm-up. I had no check engine light or 'pending' codes. Previously, I also replaced the MAF sensor.
The IAC is located at the rear center of the engine, just under the TPC (Throttle Position Control sensor), which is at the end of the large black hose/ tube that comes from the air cleaner. NOTHING needs to be removed to access the IAC. It MAY be helpful to remove the TPC sensor (attached by 2 philips head screws). It may also be helpful to "un-snap" a fuel line from a plastic holding clamp on the rear firewall, so you can manuver your tools around. It is suggested that the negative battery cable be removed to 'reset' any computer faults, as you replace this part/ parts. I disagree that this will reset the computer faults/ codes... on this year car, that needs to be done with a code reader. But it is safer to disconnect the battery cable, just clean it and the post before re-installing it.
The IAC is removed by using a 1/4" drive ratchet, a short extension, and a 8mm socket. After it's removed from the throttle body/ block, the electrical connector can be removed. The night before, I used RTV silicone to apply the gasket to the new IAC. That way I would not have to fight the gasket as I was installing the IAC on the engine. I didn't bother to silicone the gasket to the engine.
I decided to replace the TPC sensor at the same time. This sensor has a round 'boss' that fits into the throttle body. To install this sensor, you need to open the throttle with your right hand, as you fit the TPC in place. Open the throttle by using the 'wheel' that is at the end of the throttle/ gas pedal cable. Don't stick anything down the throttle body air inlet to hold it open, and don't force the 'tang' that the TPS mates with (inside the throttle body). While holding the throttle open, loosely install 1 (philips head) screw. It may be necessary to keep the throttle open to install the 2nd screw. Now tighten both screws. This particular sensor, unlike previuos years, is not adjustable... it simply get bolted in place.
The whole job of replacing both parts took less than 40 mins., and the car is running fine... after test driving it all week-end long.
Another helpful piece of advice: A lot of parts stores have websites that you can go on. You will need to punch-in your vehicle information, then do a search for the part you are looking for. Most of the time, the website will have an actual photo of the part. I find this very helpful when I'm 'scoping-out' the job to see what's involved ahead of time. It gives you a great reference point as to what you are looking for when you're crawling around the engine compartment looking for a particular part!
bobby2113 is offline
Old 02-27-2013, 01:33 AM   #29
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Yes. That is a great thread. The last post (by me!) also has a video of it:
- http://www.focusfanatics.com/forum/s...2&postcount=40
I briefly explain how to remove it, where the screws are (I touch them), and how to reinstall it.
Oblivion is offline
Old 02-27-2013, 12:13 PM   #30
2000ktm
Fan#: 107853
What I Drive: 2000 gray ford focus se
FF Reputation: 1 2000ktm Good Standing Member
I found the vacuum hose right next to the IAC was collapsed on my 2000 SE, I cut it and put it back together with a piece of plastic tube and now it runs fine, but battery light is still on/off so I will check the negative cable . thanks for the help!
2000ktm is offline
Similar Threads
High Idle at Start! Plz Help!! ponyhustler General Technical Chat 21 08-18-2009 05:49 PM
Fried PCM!? On my SVT 02_SonicBluSVT SVT Performance (2002-2004) 31 06-12-2007 10:48 AM
(Hanging Revs)Fast Forward SVT Idle Air Restrictor focusfab SVT Performance (2002-2004) 33 06-27-2006 08:22 PM
Strange Air Relief Valve Noise wiggieworld DURATEC Performance (2003-2007) 7 08-09-2005 09:13 AM
For Sale: AEM Cold Air Intake W/ Air bypass valve. ZeeXthree Archive 2 11-12-2004 02:23 PM
