Need help with Fuel Pump - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-13-2007, 05:51 PM   #1
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Okay, so we replaced my fuel pump and fuel filter on Wednesday. The fuel filter is a Motorcraft and I must admit, the pump was one of those damn cheapies from Advanced Auto Zone for like 63 bucks. The strainer that came with it would not fit into the pump housing so we cleaned off the original and used that instead. It started running like crap after five minutes of idle and then eventually died. We pulled everything apart again and inspected.
It runs now but still like crap. The only way I can accelerate is to baby the throttle. If I stomp on it while in drive, it's starts to bog, buck and surge. However, if it's in park or neutral it'll let me red line the rpms without issue.
I've had the EGR blocked off for about a year now due to a bad DPFE. I plan on getting an EGR delete. Don't know if that has anything to do with it. Tomorrow I'm going to check the spark plugs and replace the wires with my stock (i'm broke right now).
The reason for replacing the fuel pump is I had the usual symptoms of a failing fuel pump but my car is not under the recall (had Mike look it up for me). It started running like absolute crap this past week so that's what prompted me to replace it. I may pony up the bucks and get the actual pump from Mike.
Is there anything else someone can give me pointers to check or troubleshoot?
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 10-13-2007, 06:12 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Your whole problem might've been spark plug wires to begin with, but that's all water under the bridge now.
If you purchase Lifetime Warranty plug wires at parts stores, then the next time you purchase the wires, you put the old ones back in the box and get your money back. Don't skimp on the price if you can get Lifetime warranty wires.
First off, pull the spark plugs. Google "Spark Plug Deposits" and look for a site with pictures. Then compare your plugs to the pictures to see if you can figure out what's going on inside the engine. That's the first step in diagnosing engine problems. Before you put the plugs back in- use a gap gauge- about $1- to check and see if the gap is correct.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-13-2007, 06:18 PM   #3
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
^^Thanks
I'm definitely checking all that tomorrow.
In case I have to replace the fuel pump again, I just looked them up on CFM and noticed they have an 03-04 fuel pump that states the following:
"This pump is used on the 2003 to 2004 Ford Focus Models. This pump will out flow the stock 2000 to 2002 Ford Focus pumps. The flow numbers for this pump is shown below.
217lph @ 40psi
185lph @ 60 psi
143lph @ 80psi"
I'm not sure what they mean by "out flow", does that mean it will flow too hard or too much? I'm just thinking worst case here.
Old 10-13-2007, 06:28 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
Flow shouldn't matter with this SFI design, the computer regulates the fuel pressure by reducing voltage to the pump. A higher flowing pump would just run at a lower voltage.
The worst thing I can think of that could be wrong would be the fuel pressure/temp sender. The only way to test it is to cut your fuel line and put a manual fuel pressure tester in line- or throw the part at the car and see if it fixes it. It's not a cheap part to throw at the car either- so that would be a last resort!
Be eclectic.
Old 10-20-2007, 08:11 PM   #5
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
So I replaced the fuel pump with the one from CFM and my car hasn't ran better since I've bought it. AWESOME!!!!!!! I'm just glad that's all it is.
Thanks for your help! +1 for sure.
Old 01-08-2008, 01:15 PM   #6
dhardison
Fan#: 50880
What I Drive: '06 SS Trailblazer (LS2 pwrd)
FF Reputation: 2 dhardison Good Standing Member
Buy-Sell-Trade Rating: (4)
Dan,
You have a PM on this subject.
Thanks,
Dan
dhardison is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Ford Said 'what Fuel Pump Recall' dodger22 General Technical Chat 18 05-10-2006 10:17 PM
Is This a SVT Focus Fuel Pump? Bark General Forced Induction 3 05-28-2005 10:48 PM
Fuel Pump SinCityZX3 General Technical Chat 9 05-19-2005 07:37 PM
