Power steering fluid level is below the minimum? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2007, 11:28 AM   #1
cityhawk
Fan#: 38860
What I Drive: Ford focus
FF Reputation: 1 cityhawk Good Standing Member
2000 Ford Focus. One year ago the garage did power steering fluid flush. Currently the power steering fluid level is below the minimum for ~1.5cm. It seems that it is not leaking.
What's the problem? May I add some steeing fluid to reach the line between min and max? Thanks for your help!
cityhawk is offline
Old 10-07-2007, 11:33 AM   #2
jrpasmo
jrpasmo's Avatar
Fan#: 2866
What I Drive: 02Focus ZTW, 02Focus SVT
Points 2,642, Level 31
Points: 2,642, Level: 31 Points: 2,642, Level: 31 Points: 2,642, Level: 31
Level Up 28% Completed
FF Reputation: 5 jrpasmo Good Standing Member
it can leak a little...shaft seal, high preassure line....put your hand under PS pump (touch it there) if there is any sign of fluid....high pressure line has a small seal which can be replaced....
#4208/4788 Procharged SVT 10PSI : +-270/204 by Focus-Power,
N/A ZTW, 2.2 CRDI AWD Santa Fe MMRacing tuned
jrpasmo is offline
Old 10-07-2007, 12:20 PM   #3
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Your Owner's Manual says:
"POWER STEERING FLUID
Check the fluid. Refer to the
scheduled maintenance
information for service
maintenance schedules.
1. Start the engine and let it run
until it reaches normal operating
schedules.
2. Turn the steering wheel left and
right several times.
3. Turn the engine off.
4. Check the fluid level.
5. If the fluid is below the MIN line,
add fluid in small amounts until it
reaches the correct level (between
the MIN and MAX lines).
Use only MERCON ATF.
Seriously, the first thing to do is to check the owner's manual.
If you do not have the owner's manual, you can download one for free from http://www.fleet.ford.com
penguin is offline
Similar Threads
Had a bad power steering leak read plz SVTbedson SVT Performance (2002-2004) 1 04-22-2007 03:26 PM
Can steering fluid leak onto a/c compressor? ammorgan General Technical Chat 7 06-15-2006 11:25 PM
Power steering fluid leaking tunedfocuzx3 General Technical Chat 2 05-15-2005 12:59 AM
power steering fluid Sqeejo1 General Technical Chat 1 03-30-2004 12:20 AM
