Back Seat Delete - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 09-26-2007, 04:13 PM   #1
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: 04 Forester XTi
Points 14,456, Level 78
Points: 14,456, Level: 78 Points: 14,456, Level: 78 Points: 14,456, Level: 78
Level Up 2% Completed
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
Back Seat Delete
The other night I took out the rear seats in the car and built the "back seat delete". I weighed all the seats, headrests, and hardware I stripped out and it ended up at just about 60lbs, give or take.
Many people have built this delete but no one's posted pics/tips/how....not that its all that hard, but I thought this might help. I also only built a piece to cover where the back seats were and used the stock rear deck / trunk piece. So take the template hints from here and apply it to the rear area as well, if you like.
Tools you will need:
  • Torx set
  • Circular saw
  • Jigsaw
  • Staple gun
  • Drill
  • Square
  • Pencil
  • Tape measure
  • Razor blade or utility knife
  • Trowel for carpet adhesive
Materials:
  • Sheet of 3/8" OSB or preferred material for decking
  • 2 x 4 Stud
  • Car carpeting
  • Carpet adhesive
  • Cardboard
First things first - you need to strip out the seats. I am not going to go into a step by step on this. You will need a torx set for this...have fun, lol. The bottoms come off in two pieces and the backrests as one piece. There is a hinge you need to take apart right at the base of where the backrests split, then unbolt the backrests from the hinges and then unbolt the bottom mounts of the seat belts. You should be good to pull the back rests out and then strip out the rest of the hardware.
Now to build the deck.
The first thing you will probably want to do is cut the 2x4 that is going to support the front of the deck. I measured 50 3/8" across and cut the ends at a slight angle like so /==============\ About 5 degrees is all you need.
Next, you will want to make a template for the deck. I was wondering exactly how I was going to do this since the inside panels arent exactly straight lines...and then it dawned on me how easy this actually was.
Lay your 2x4 where you plan on putting it and then lay your cardboard across the span, butted up against the side panel. Then, with a somewhat steady hand (if you are having detox shakes, get some help), hold a pencil at an angle and put the eraser against the side panel...use this as a guide to draw your line, like so:
When you are done, you should have something similar to this:
Then you want to cut it out with a utility knife / razor blade / etc and test fit it to make sure it fits to your liking. Obviously, you will want to trim it where you see fit. Here's how mine came out - first shot:
The two sides are the same, so it should fit fine on either side, but test it just for good measure anyways. Once you are satisfied, get ready to cut that sheet of OSB.
From front to back, I cut my sheet 36" long because I planned on using the existing rear deck (trying to keep the weight to a minimum) and it left enough length to use the trunk area to support the back end of the deck. I also did my piece of OSB in two pieces. I cut the first piece to just about 25" and the other half to 27". I laid both sides in there with the shorter piece laying on top of the longer - positioned the pieces where I wanted them and then traced the overlap.
Now, take the two halves and screw them together. I cut a piece of 2x4 and placed it on end like so \=====/ This not only joins the pieces of wood but also adds some support to the middle and will rest nicely in the divot where the seats used to be, keeping it from sliding forward if you ever decide it would be fun to slam on your brakes.
Drop it in and test fit:
Now you are ready to carpet this beast. Just wrap the carpet around the pieces and staple it down with the staple gun....
On the deck itself, I got some floor/carpet adhesive and troweled it on first, then laid the carpet down, wrapped the edges and stapled it down. The adhesive just ensures that the carpet wont stretch and get weird bubbles in it over time.
Once you are done, you are ready to drop it all in place and screw the deck to the 2x4.
Here is the final fit (not too shabby I must say):
Extras:
If you want to do the rear area as well, you can use the pencil/carboard technique to trace out templates for a rear sheet as well. You may also want to cover up the areas along the front, where the hinges for the bottoms were. I have seen people cut an addl sheet and carpet it to sit in front of this area. You may even use the hinges to make the deck flip up, so you can hide contraband in there, body parts, tow strap, etc.
Hope this helps.
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is offline
Old 09-26-2007, 04:32 PM   #2
wordyahurdd
coooookie monster
wordyahurdd's Avatar
Fan#: 41401
What I Drive: 13'ST, 04'SVT, 03'XB9s
Points 14,431, Level 77
Points: 14,431, Level: 77 Points: 14,431, Level: 77 Points: 14,431, Level: 77
Level Up 96% Completed
Forum Activity 9%
FF Reputation: 7 wordyahurdd Good Standing Member
Buy-Sell-Trade Rating: (16)
so nice look'n if your look'n for pure weight reduction
2013 ST(3)
2004 SVT : #55 STF (now racecar)
2003 Buell XB9S
wordyahurdd is online now
Old 09-26-2007, 04:39 PM   #3
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,223, Level 100
Points: 32,223, Level: 100 Points: 32,223, Level: 100 Points: 32,223, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
thats kinda cool lookin...you get an squeeks or rattles from it?
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 09-26-2007, 04:58 PM   #4
..:: sleestak ::..
on thin air
Fan#: 22528
Thanks. I didnt take out the seat belts on the sides out, so occasionally I hear them move...like over a decent jolt, but no new annoying sounds. I can hear the sub way better now...thats a plus
I did this for two reasons really...first was weight reduction, since I am now in Street Mod and can do it, second (and mainly) for stuffing my camping gear, snowboarding gear, etc in the back. My seat is all the way back and with the rears folded down, I couldnt really tilt my seat much at all. Besides, the hatch is a 3 seater at best.
..:: sleestak ::..
Old 09-26-2007, 05:36 PM   #5
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
hey nice write up. thankz 4 being the first 2 put it out there yet. u should see my wirte up on how-to do make the odometer any led color u want. it's in the same section (odometer led mod)
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 09-26-2007, 05:40 PM   #6
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 85,673, Level 100
Points: 85,673, Level: 100 Points: 85,673, Level: 100 Points: 85,673, Level: 100
Forum Activity 3%
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
This thread just earned a sticky status. Great work and rep points added.
Tom is offline
Old 09-26-2007, 06:50 PM   #7
..:: sleestak ::..
on thin air
Fan#: 22528
Thanks Tom
..:: sleestak ::..
Old 09-26-2007, 07:39 PM   #8
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 41,796, Level 100
Points: 41,796, Level: 100 Points: 41,796, Level: 100 Points: 41,796, Level: 100
Forum Activity 8%
FF Reputation: 27 dirtbrown Great Standing Member
looks good....been wanting to take a SAT and knock mine out just been busy doing my suspenson up slowly
dirtbrown is offline
Old 10-26-2007, 07:22 PM   #9
KS1
KS1's Avatar
Fan#: 46191
What I Drive: '04 Toreador Red Manual ZX3
FF Reputation: 4 KS1 Good Standing Member
I just finished my Back Seat Delete this weekend, I freakin love it, it fits perfectly and it looks better than sex...
Zetec Crew #159
"The road of excess leads to the palace of wisdom."
KS1 is offline
Old 10-26-2007, 07:34 PM   #10
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
Forum Activity 8%
that looks awesome.....dont like the dragon but the delete is SEX.
do you notice anything diff with handling and cornering....cause i mean its only
60 pounds......i know every pound counts but does it feel any better?
Similar Threads
Seat Replacement Questions Kalos General Technical Chat 2 08-14-2009 01:14 PM
My Rear seat delete I made Zetecrazy MK1 Interior Mods & Upgrades 20 01-30-2007 06:52 PM
zx3/svt Rear Seat Delete Kit lightweight *PICS* SVT ewx ca Archive 17 07-08-2005 11:54 PM
i would liek to find a back seat elimantion kit redfordfocussvt03 MK1 Interior Mods & Upgrades 1 04-22-2005 03:32 PM
