Does your SVT ever just die? - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2013, 10:41 PM   #131
shananigans89
shananigans89's Avatar
Fan#: 84576
What I Drive: 04 red SVT
Points 1,005, Level 17
Points: 1,005, Level: 17 Points: 1,005, Level: 17 Points: 1,005, Level: 17
Level Up 5% Completed
FF Reputation: 1 shananigans89 Good Standing Member
oh sorry, i never updated from what i did. i ended up getting my fuel pump replaced. the car sounds better and a little different tone (in a good way) now. also, i then hooked up my tuner to see what idle rpms the computer was reading, unplugged the IACV and set my idle screw the way Tom said to. i set it to around 780 - 800 rpm because when i could get it to 750-760, it wasnt stable and would bounce from 560ish back up to 750ish, nearly dying when it would go that low. ive been driving it since then and the tweaks tom made in the last tune are noticable and helpful, the car is much better to drive now.
K&N Typhoon SRI, Magstar 8.5mm plug wires, Denzo Iridium plugs, all VF Eng poly motor mounts, 2.5" Dominant Eng HFC & flex pipe, Trubendz 2.5" exhst w/ Borla muffler no resonator, SCT Xcal3 with Tom's Tune, CFM 67mm TB
shananigans89 is offline
Old 08-20-2013, 09:45 AM   #132
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
What I Drive: 2003 Red SVT
FF Reputation: 1 Dads03SVT Good Standing Member
Mine did this the other morning...had driven probably 10 minutes and when I stopped at a light it just gave no sign....just cut off. Cranked back up and went on...?? I have Randys Tune from FSWerks.
Dads03SVT is offline
Old 08-20-2013, 05:06 PM   #133
shananigans89
Fan#: 84576
is it a recurring problem? or did this just start? if it just started you could try cleaning your idle air control valve and you throttle body as best you can and see if that helps.
any throttle body mods? first after cleaning, i'd try asking whoever did your tune if they can change some settings. ask tom (1turbofocus) what he should change if your tune guy doesnt know. toms's tweaks to my tune helped a lot, especially after i installed my 67mm throttle body and set the new throttle body's idle screw properly. check out my thread on this here: http://www.focusfanatics.com/forum/showthread.php?t=322272
Old 08-20-2013, 09:17 PM   #134
wsharp
Fan#: 117557
What I Drive: 2004 silver svt/2000 jeep tj on 33s
Points 565, Level 11
Points: 565, Level: 11 Points: 565, Level: 11 Points: 565, Level: 11
Level Up 30% Completed
FF Reputation: 1 wsharp Good Standing Member
cant say mines ever died =p
wsharp is offline
Old 08-21-2013, 08:52 AM   #135
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
I'd say 10 times since I've owned the car.....had it 8 years. Used to do it most when the ac was on.
List of mod's 67mm TB, AEM CAI, ORP, UDP, MSD coil & wires, Magnaflow exhaust & Randys Tune.
Old 09-19-2013, 10:07 AM   #136
annamal
annamal's Avatar
Fan#: 67306
What I Drive: 2013 Performance Blue Focus ST1
FF Reputation: 1 annamal Good Standing Member
Sometimes in cold weather I'd have that problem. Car would start up fine, but the first time I'd come to a stop while driving the battery light would come on and the RPM would REALLY dip... sometimes the car would just stall. Always started right back up though. Ahh, the quirks of owning an SVT Focus...
annamal is offline
Old 09-19-2013, 11:10 AM   #137
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,177, Level 34
Points: 3,177, Level: 34 Points: 3,177, Level: 34 Points: 3,177, Level: 34
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 11%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
You need a new set of battery cables.
Along with the Updated Alternator pigtail and Updated Ignition pigtail.
Electrical problems are a bitch but these 3 items solve the majority of them, the only other common problem I can think of electrically is the hatchback models rear harness in the hatch can become brittle and break causing electrical gremlins, and specifically to the SVT the headlamp switchmake sure the dimmer rheostat is just below the max setting to stop the flicker of the el-glo.
qweesy is offline
Old 09-21-2013, 03:10 PM   #138
Evanc291
Evanc291's Avatar
Fan#: 117654
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 1 Evanc291 Good Standing Member
I have the same problem, I can pretty much count on it stalling if I let the rpm's drop, sometimes it's not a problem, but other times, it idles super rough. I bought the car and the previous owner definitely has has it tuned, it runs super rich at idle and also it has no cat. So unless there is a fake 02 sensor, he has tuned it.
I've done everything that could obviously be the problem. Cleaned the IAC, TB, no vacuum leaks, cleaned MAF sensor, fuel filter, air filter, and no battery or alternator problems. I did recently have a CEL for PO1131 and PO0133.. It's interesting though, every time I reset the ECU, it runs perfect, until I turn the car off. Also, sometimes it does that surge thing everyone is talking about. It feels like it's just dumping gas, and it also backfires a lot, and my miles per gallon is terrible right now. So do you think it just needs a new tune? Or maybe some fuel pressure problem.. I can't think of much else
Evanc291 is offline
Old 09-24-2013, 09:42 PM   #139
itr909
Fan#: 119078
What I Drive: 2003 red, SVTF
FF Reputation: 1 itr909 Good Standing Member
I had a similar issue with my tune however my issue was due to elevation.
itr909 is offline
Old 09-24-2013, 09:45 PM   #140
Evanc291
Evanc291's Avatar
Fan#: 117654
Hmm, that's why I was thinking, maybe it was tuned for a higher elevation.. Well thanking for confirming that could be the problem
Evanc291 is offline
Similar Threads
HOW-TO: SVT IMRC DSI Intake Manifold Upgrade FOR ZETEC!!!! focituner ZETEC Performance (2000-2004) 131 05-31-2012 07:56 AM
SVT Parts For Sale: Ontario, California jrgtrain Archive 98 02-11-2008 08:32 PM
Anybody's SVT ever die on them? svt_gEEk SVT Performance (2002-2004) 85 01-22-2007 07:39 PM
For Sale: SVT Engine Parts - Pistons/Rods and Intake Manifold zincyellowfocus Archive 6 08-21-2006 01:14 PM
