Does your SVT ever just die? - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2008, 05:22 PM   #91
athens7
athens7's Avatar
Fan#: 50571
What I Drive: 2013 Boss 302 Mustang
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 17 athens7 Great Standing Member
I think the problem is fuel related; specifically, the cars can have a tendency to lean out for several reasons. Clogged fuel filters have been mentioned, and may affect older cars. Mine was new, and the filter was as new when we changed it and cut open the old one. I have spent the last 7 months dialing in the tune on my car, with it's mostly stock engine and ancillaries (just hot cams and a 9.5 lb flywheel)) in a 1300 lb, rear wheel drive application. Along the way, the car has gone from cutting out every time I dipped the clutch from higher revs to, after my last tuning session, not cutting out a single time (yet). The PCM settings for idle air and 'rev down' are stock; what's changed is the air/fuel ratio. In its stock PCM form, the car wanted to run very lean, and even changes to the open loop air/fuel would not correct the a/f ratio. We found the MAFS map was biased to a too lean setting, and that the adaptive fuel program exacerbated this problem, making the car run leaner over time. The thought is that the emmissions driven program that cuts fuel flow off when off throttle, coupled with the too lean a/f ratio, compounded by a low mass flywheel, led to the cut off (the PCM couldn't put enough fuel in play fast enough to keep the car from dying). As no engine operating system is perfectly consistent, it is possible that occasionally, normal rich/lean fluctuations in a/f might coincide with clutch engagement and the accompanied rev drop off, leading to a Focus stalling. Even now, when engaging the clutch from higher rpms, the revs drop to 700 or so, flutter 2-3 times without dying, then settle to the 950ish idle. The PCM has never thrown a CEL relating to any of these problems. At the next tuning session we are going to fiddle with the IACV, and between now and then I'll do some data logging on a/f, o2 sensor operation, and injector pulse measurements to try to verify whether the car leans out on clutch engagement.
Brad
athens7 is offline
Old 02-18-2008, 06:59 PM   #92
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Very well explained!
Please, keep us informed on what you find.
Love the Caterham BTW!
Welcome to Focus Fanatics!
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 02-18-2008, 08:24 PM   #93
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
I do hope you can figure this out. Are you still tuning with Tom?
CaysE is offline
Old 02-18-2008, 09:22 PM   #94
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 10,848, Level 68
Points: 10,848, Level: 68 Points: 10,848, Level: 68 Points: 10,848, Level: 68
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 3%
FF Reputation: 17 kylesvt720 Great Standing Member
Yeah, let us know if you get this figured out, I'm sicking of nearly getting hit by buses!!
kylesvt720 is offline
Old 02-19-2008, 02:43 PM   #95
athens7
athens7's Avatar
Fan#: 50571
Points 266, Level 5
Because of the distance to Tom's shop, I've switched to Balanced Performance Motorsports, just outside of Atlanta. They are also Diablosport dealers with a Dynojet dynomometer.
Brad
athens7 is offline
Old 02-23-2008, 02:47 PM   #96
old&intheway
Fan#: 35399
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 1 old&intheway Good Standing Member
This seems to describe my problem exactly. Hope there is a solution!
old&intheway is offline
Old 02-27-2008, 09:32 AM   #97
hgiles
hgiles's Avatar
Fan#: 44334
FF Reputation: 1 hgiles Good Standing Member
My car does it too, but I think it's only actually died once.
03 Pitch SVTF
Tom's Tune, Taylor 8.2, CFM STS, CFM tranny mount, AEM SRI, (seeking ORP)
hgiles is offline
Old 02-28-2008, 09:39 PM   #98
jsis789
jsis789's Avatar
Fan#: 52267
What I Drive: 2003 Pitch Black SVT ZX5
FF Reputation: 1 jsis789 Good Standing Member
I've had my SVTF since november and it just started doing the same thing, when i slow for a red light the idle fumbles below 900, batt light comes on. I'd just give it some throttle and A-ok. the 4 times it happened it was the same scenario exept yesterday a Fusion next to me jumped the light had 2 lenghts before i got a chance to go, overtook him at about 80, shifted from 3rd to 6th still on the gas about 1/4 and the batt light comes on and i get a little stumble for 3 seconds and than its fine. all stock no tune just a high flow air filter.
jsis789 is offline
Old 02-28-2008, 09:42 PM   #99
pelotonracer2
pelotonracer2's Avatar
Fan#: 49917
What I Drive: 2014 Ford Fiesta ST
FF Reputation: 17 pelotonracer2 Great Standing Member
Since I've had my tune from Tom installed, it hasn't happened again. Usually it happens 1-2 times a week. Nothing so far!
Go FAST or go HOME! 2014 Ford Fiesta ST
pelotonracer2 is offline
Old 02-28-2008, 09:56 PM   #100
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
I have Tom's tune, too, though. Still happens to me.
CaysE is offline
Similar Threads
HOW-TO: SVT IMRC DSI Intake Manifold Upgrade FOR ZETEC!!!! focituner ZETEC Performance (2000-2004) 131 05-31-2012 07:56 AM
SVT Parts For Sale: Ontario, California jrgtrain Archive 98 02-11-2008 08:32 PM
Anybody's SVT ever die on them? svt_gEEk SVT Performance (2002-2004) 85 01-22-2007 07:39 PM
For Sale: SVT Engine Parts - Pistons/Rods and Intake Manifold zincyellowfocus Archive 6 08-21-2006 01:14 PM
