HOW TO: Install VF-Engineering P/S Mount - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2007, 07:23 PM   #1
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
HOW TO:
Here is how to install the NEW VF-Engineering P/S engine mount for the 2.0 and 2.3L duratec engine!
OK... first open the big box from Focussport(only supplier at this time)...
first assemble the mount onto the new bracket with the supplied bolt and hex-bolt both with lock nuts.
make sure the gold top bolt is still slightly loose so you can adjust the middle portion still.
remove the 10mm bolt at the front of the coolant tank... then take a flathead screw driver and pry on the tank from the shock tower on the back of the coolant tank to remove it from the clip/bracket.
now place the coolant tank on the intake manifold... thats where mine sat the hoses had enough bend in them and that seemed the safest place.
now... make sure you have the engine supported from underneath, i used an alluminum low profile jack with a eurethane spacer... so i didnt marr my oil pan...
jack up the engine slightly so you can see it move...
now remove the 3 15mm bolts on the black bracket... after that remove the 2 19mm nuts on the studs from the engine block...
now what i had to do so the engine mount would loosen was jack it up alittle more, because the engine mount is actually at an angle when installed...
so jack the engine up slightly and the engine mount will get loose off the studs... then lift it out... now place the new engine mount thats assembled into place...
now bolt down the 3 15mm bolts... and the 2 19mm nuts onto the studs...
i just tightened down the bolts as much as i could, but VF engineering has torque specs and so does ford... so if you want to get ahold of them from the manuals and/or the vf engineering instructions.
i used locktite on the 3 15mm bolts that go into the frame... and dont forget to tighten the gold bolt on the top of the mount!
after its all bolted down.. lower the engine with the jack/or support how ever you did it... then reinstall the coolant tank with the 10mm on the side and the clip/braket on the rear..
i have all 3 engine mounts on my car now... all VF engineering.. and after this 3rd mount was installed you can REALLY REALLY feal the engine now... its almost like when i used to ride 4-wheelers... you can feal the vibrations through the steering. feet. butt etc...
but the only bad vibrations are when the engine is slowing down from like 2100 to 1300RPMs... other than that it feals about the same...
once you get going, you can really feal the power getting down to the ground now.. i would deffinately rank this mount about as good as the rear mount! thats how much of a difference it made!
and of course it looks oh so pretty sitting under the coolant tank.
also as a side note... i did not add any pictures to this write up only because you can see all the bolts and its pretty straight forward on how to do this....
if you can change a tire you can do this without instructions.
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 09-12-2007, 07:44 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the HOW TO ARCHIVE......
Chad (S2)
S2 is offline
Old 10-31-2007, 09:44 PM   #3
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (17)
I know this is the Duratec performance area, but since this is a how-to for the P/S VF mount, I thought this would be good knowledge to those people with SPI's looking to upgrade their mounts.
The VF P/S mount for the zetec does NOT fit the SPI.
I learned this the hard way today.
The mounting bolts are farther apart on the SPI.
Here's the proof:
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 02-27-2009, 08:07 PM   #4
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
i just installed all 3 mounts from CFM. i replaced the VF in the rear.
WOW!!! i hope that the vibrations die off a bit after some time. cuz its crazy how much the car vibrates now. although now it becomes harmonic at some points while accelerating. i can hear a whining noise.
like previously mentioned, it is like driving an off-road car. the vibrations are everywhere.
ill try to update this after the mounts are "broken in"
did i mention that they look saaweeet!
scrammer is offline
Old 02-28-2009, 01:48 AM   #5
FOCUSSTDRIVER
FOCUSSTDRIVER's Avatar
Fan#: 50034
What I Drive: 2007 pitch black zx4 st SAP1
FF Reputation: 4 FOCUSSTDRIVER Good Standing Member
Buy-Sell-Trade Rating: (7)
very nice man i plan on doing this soon
07ST
ST Crew #82SAP Crew#19
FOCUSSTDRIVER is offline
Old 02-28-2009, 06:14 PM   #6
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,823, Level 59
Points: 7,823, Level: 59 Points: 7,823, Level: 59 Points: 7,823, Level: 59
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 19%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Scrammer, I've had the C-F-M rear motor mount done in mine for about 2 weeks and it still vibrates like crazy . So I can't imagine putting all the 3 in like you did .
I have narrowed my vibrations down to 2 points 1 is around my steering column somewhere and the other is in my arm rest ...
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 02-28-2009, 08:31 PM   #7
mtadd162
Proudly Daily Driven
mtadd162's Avatar
Fan#: 47890
What I Drive: 2005 Focus ST
Points 5,921, Level 49
Points: 5,921, Level: 49 Points: 5,921, Level: 49 Points: 5,921, Level: 49
Level Up 86% Completed
FF Reputation: 9 mtadd162 Good Standing Member
driver side anyone?
i plan on doing mine this summer, so if there is no write up by then, ill take the dutie
05 Focus ST-Sold but missed
-ST Crew #73 N/A FTW!
Feb. 09' ROTM
SSR - Silver Sedan Revolution Member #1
Cams Installed, great made my car into a VTAK
mtadd162 is offline
Old 03-02-2009, 09:20 AM   #8
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,197, Level 98
Points: 28,197, Level: 98 Points: 28,197, Level: 98 Points: 28,197, Level: 98
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Ive done the D/S one- just support the tranny with a jack, unbolt, install and torque it down. ive got the steeda though which is wonderful except for the fact that it was too tall for the stock battery box.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is online now
Old 03-02-2009, 02:52 PM   #9
NAD23ZX3
Fan#: 59327
What I Drive: 2004 Red Zx3
FF Reputation: 9 NAD23ZX3 Good Standing Member
the four surrounding nuts are 35lb/ft and the middle one is about 95lb/ft. How about a writeup for installing new gas into the tank
NAD23ZX3 is offline
Old 03-02-2009, 05:23 PM   #10
liquidst07
Fan#: 49552
What I Drive: 2007 Focus ST Liquid Gray
FF Reputation: 1 liquidst07 Good Standing Member
Wow and to think I'd really like to do the "dogbone" mount with urethane bushings.
After hearing about this much NVH after going to more than 1 bushing I'll reconsider. My DD is too important to me and comfort is a big factor...don't think I can handle all that vibration on a daily basis.
Nice how to though!
liquidst07 is offline
Similar Threads
How To: Install Saleen Spoiler mercuryinhell MK1 Focus 1 10-07-2008 11:21 AM
Lower mount install time? FULLBLOWN DURATEC Performance (2003-2007) 7 04-15-2007 03:39 PM
rear motor mount install on SVTF? funksilver04 SVT Performance (2002-2004) 6 11-09-2005 10:58 PM
Yet Another Custom Radar Detector Mount! FocAL MK1 Interior Mods & Upgrades 2 09-06-2005 10:23 PM
VF engineering rear motor mount install drewzx3 ZETEC Performance (2000-2004) 3 07-27-2004 08:20 PM
