03 Focus, No overdrive question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2007, 01:06 PM   #1
nekoashide
Fan#: 50156
What I Drive: 2010 Ford Focus S
FF Reputation: 1 nekoashide Good Standing Member
I have already searched for his and the failurecode is related to the Shift Solenoid C. The fluid looks dark and dirty. Would a good guess just be to replace the filter and have the transmission flushed and try resetting the PCM to see if that fixes it? Or just have the solenoids replaced and have the fluid and filter changed at the same time?
Basically what happened was i was driving along on the highway and the rpm's shot up. I discovered i had lost OD and autozone pulled the code for the shift solenoid. It drives fine without O/D but i dont want to do anymore damage.
nekoashide is offline
Old 09-11-2007, 02:10 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,561, Level 98
Points: 27,561, Level: 98 Points: 27,561, Level: 98 Points: 27,561, Level: 98
Level Up 22% Completed
Forum Activity 11%
You can try doing the filter, but lack of filter changes (every 30k miles, see your manual) could have caused the selenoid to fail if it's channel is clogged from derbis.
Eventually I hope to write a How-to on this because lately it's seemed popular, and I have a car (victim) in mind for it. However, I don't see the need in doing it before he reaches 30k.
There are 2 ways of doing this. The first is the messy way which is drop the pan in such a way that it drains from one side. You'll need a kitty litter box for either method to catch any dripping fluid. You'll also want an oil drain pan- or some other container to transport the used fluid to your local recycler station. Most auto parts stores offer fluid recycling stations, or your local service station shouldn't care much if you dump there.
Method 1- drop the pan, replace the filter. The filter either pops in place, or is held in place by 2 screws. A gasket should come with the filter, if no gasket then use RTV.
Method 2- Drain all the transmission fluid before dropping the pan to replace the filter using the transmission as a pump. Disconnect either the top hose or the bottom hose leading from the transmission to the radiator. The top hose is fluid coming from the transmission, the bottom hose is fluid returning to the transmission. If you disconnect the top hose, attatch a section of hose to the hose, if you disconnect the bottom hose then attatch a section of hose to the outlet at the radiator. To disconnect either hose: slide the collar forward, push the clip, and pull back on the collar to release the hose. Then route your attatched hose to a bucket and secure the hose as well as the bucket. Then turn on the engine and allow it to idle. Do not rev the engine during the process. The fluid will drain out very quickly, so keep an eye on it. You will need more fluid using this method because it will drain ALL the fluid in the transmission whereas the other method will only drain the fluid in the pan. Approx 7 qts for this method, and 3-4 qts for the other method. If you're using this method it would be best to warm the engine before doing this to reduce idle speed, and also watch carefully because it can damage the transmission if you allow it to run for a while after the transmission fluid is drained completely. The benefits of this method are less spillage, and a higher percentage of fluid replacement.
I hope that helps, and fixes your shift problem. Don't use any special additives, and if you do decide to use an exotic fluid- I'd only recommend Amsoil's ATF. My uncle has had good experiences with this in heavy duty mass transportation vehicles.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-11-2007, 10:47 PM   #3
nekoashide
Fan#: 50156
I got the solenoids on order, I'll just replace them at the same time. My line of thinking is dropping the pan changing the filter and solenoids and put back in enough fluid to get it to the dealership for a flush. It's most likely not the smartest way but i'll atleast have the filter and solenoids changed.
How hard is it to get them off though? I the pictures i have seen show the leads and shows them held on with 1 bolt. just that simple?
Old 09-11-2007, 11:13 PM   #4
Pistonbroke
Pistonbroke's Avatar
Fan#: 42552
What I Drive: Black 2000 ZX3 mtx
Points 1,962, Level 26
Points: 1,962, Level: 26 Points: 1,962, Level: 26 Points: 1,962, Level: 26
Level Up 62% Completed
FF Reputation: 1 Pistonbroke Good Standing Member
We just had an 02 Focus at the shop with a code 0750 -shift solenoid A.
Also neutralizes in OD. Check the resistance of the solenoids, should be between 12 and 30 ohms. This is first Focus auto we've had in with a problem.
-There is no water holier, than the sweat off a man's brow.-
Pistonbroke is offline
Old 09-12-2007, 12:17 AM   #5
nekoashide
Fan#: 50156
It will prolly be tuesday before i'm able to get under it and check the solenoids. I'm betting it's electrcal failure rather then mechanical though. I'll see about taking pic's when i do it though and what i found was wrong.
I'd hate replacing one just to see another fail in a few thousand miles though but they are expensive.
Old 09-21-2007, 05:02 PM   #6
nekoashide
Fan#: 50156
My code was Shift Solenoid A failure, I decided it was best to replace A, B, And C at the same time. In doing so i just dropped the pan and they were right there. I removed the filter and the job was amazingly simple.
A and B are held in place by a single bolt. Once you disconnect the wire remove the bolt and just pull on them till thep pop out and place the new ones in it's place and tighten the bolt back on.
C is a little more tricky. It's held in place by a bracket that also holds the other 2 solenoids on the other side. Just remove the 4 bolts and the bracket slides off. At that point the solenoid just pulls straight out. Replace it and fasten the bracket back into place.
As far as fluid goes, in all i replaced only 3 quarts when it was all done. I'll have a flush done later but the car runs and shifts fine now. In all I'd have to give this a 3 on the 10 scale of difficulty.
Old 09-21-2007, 05:06 PM   #7
Dcl2049
MyCarBreaksAlot
Dcl2049's Avatar
Fan#: 18957
What I Drive: 2002 Malibu Blue ZX3
FF Reputation: 69 Dcl2049 Excellent Standing Member
Yeah I just got a performance valve body from Lentech. Easy swap.
Yes, that is a banana in my pocket.
Dan - gumpcrew #4
[BBS][Borla][Focus Central][Hella][K&N][Koni][Lentech][Wings West]
#23 STS Wiregrass Region SCCA
Dcl2049 is offline
Old 11-09-2007, 06:09 PM   #8
afroggy69
Fan#: 51456
What I Drive: 2002 red focus
FF Reputation: 1 afroggy69 Good Standing Member
i have the same solenoid A code. I was wondering where you were able to purchase these's solenoid's. The auto parts stores I have tried say these's parts are dealer items. I would love to find them cheaper.
thank you,
afroggy69
afroggy69 is offline
Similar Threads
Question about focus seats? iantm Ford Focus & General Car Chat 3 06-06-2007 09:58 PM
Edmunds review - EURO Focus ST igor Ford Focus & General Car Chat 21 03-13-2007 04:44 PM
Question about a possible Focus purchase nozferatu DURATEC Performance (2003-2007) 17 07-04-2005 04:13 AM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
