What Ra finish is on the Zetec head?? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2013, 03:13 PM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
No problem.
FWIW, I pay about $10 per thousandth to have mine cut down.
But I have them preped prior to my machinist getting them.
iminhell is offline
Old 04-12-2013, 03:16 PM   #12
wisebag02
wisebag02's Avatar
Fan#: 106740
What I Drive: 2002 ZTS 5-speed
FF Reputation: 1 wisebag02 Good Standing Member
Prepped? What do you do to get it prepped?
Sent from my Ally using FF Mobile
'02 ZTS 5-spd, Volant CAI, CFM 65mm TB, Autolite coppercore, Steeda wires, SVT Header, 2.25" Magnaflow catback, SVT suspension, poly bushings, Steeda tri-ax short throw, 17" Enkei, Tom's tune
wisebag02 is offline
Old 04-12-2013, 04:11 PM   #13
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,109, Level 34
Points: 3,109, Level: 34 Points: 3,109, Level: 34 Points: 3,109, Level: 34
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Wet dry sandpaper on a flat surface and do it by hand............
Ed
emsvitil is offline
Old 04-12-2013, 05:04 PM   #14
wisebag02
wisebag02's Avatar
Fan#: 106740
I take that to mean for prep- so they can get a better indicator reading on it when setting it up? Or after machining it?
Old 04-12-2013, 11:47 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Um, no.
I mean that my heads are bare, no caps, dowels, springs, valves, etc. Completely bare.
iminhell is offline
Old 04-13-2013, 12:37 AM   #16
wisebag02
wisebag02's Avatar
Fan#: 106740
I do have the cams and followers out. But does it have to be completely bare? Still have the valves, springs, timing belt tensioner and idler on it
Old 04-13-2013, 02:22 AM   #17
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Yes.
You don't want metal chips hiding anywhere.
iminhell is offline
Old 04-13-2013, 02:31 AM   #18
wisebag02
wisebag02's Avatar
Fan#: 106740
Ok. .
Old 04-13-2013, 05:13 AM   #19
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
X2, also, never leave any parts on that can mysterious disappear when the machinist decides he doesn't want this or that part on, it's in the way of his work. They need the upper flat on top of head totally unencumbered to use as the register point to fasten the head down. Valves have to be out depending on depth of cut and head design.
amc49 is offline
Old 04-23-2013, 04:51 AM   #20
wisebag02
wisebag02's Avatar
Fan#: 106740
Well, I've found a shop near me that can shave .020 off my zetec head. Using the formula from the compression ratio thread, I came up with 10.15CR up from the stock 9.6. I'd be happy enough with that- I want to be able to save a little $ still run 89 octane if I want.
And the guy at the shop said I don't have to take the valves out. As long as the cams are out and valves are closed, it wouldn't be a problem. He will mill it, then use a diamond wheel to put on a finish better than 30Ra. I still did something goofy when prepping though: I put a layer of white lithium grease in the crevices around the valves just in case. Also put tape over the ports and installed an old set of spark plugs to keep chips out of there too.
All for $75. I'll keep you guys posted and hopefully have some pics of before & after.
Similar Threads
Auto journalist seeks Zetec cylinder head specs and info motorjourno ZETEC Performance (2000-2004) 2 05-02-2006 11:09 PM
Super secret focus-power head 1turbofocus Focus-Power Tuning 29 12-05-2005 07:49 PM
oem zetec head specs old_grendel ZETEC Performance (2000-2004) 12 12-03-2005 11:13 PM
The Goatmobile's new Zetec head Goat Roper ZETEC Performance (2000-2004) 89 11-24-2005 08:55 AM
springs, RARE cluster, COMPELTE Zetec head, RS rear bumper Focused Archive 16 03-01-2004 10:40 PM
