Odometer Blue led (or whatever color) conversion mod - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 09-09-2007, 04:10 AM   #1
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
i originally was going to do the "blue electrical tape trick" but it wasn't the color or brightness i was trying to get. so i thought of an idea 2 use an led bulb as a replacement, and it was the color and brightness i wanted 2 achieve all along, and it works. so ima share with y'al how to do this mod.
the end result:
supplies needed:
-400 AND 600 grit sandpaper. (u'll b lucky 2 find 600 grit sandpaper at wal mart, so the only place u can get it will HAVE 2 b at ur local auto store)
-#74 led bulb (your choice of color) off of vleds.com or ebay.com
-needle-nose pliers
-7mm socket or whatever wrench that can take out ur bolts 2 ur gauge cluster
-a small torx bit or torx bit screwdriver (lol, don't know the size exactly, sorry)
-some tape
-flat-tip screwdriver
-thin razor blade or anything with a thin, razor-sharp edge
1ST: ok, go to 2 vleds.com and look for LED 74 BULBS. it should already be on the home page. then just choose your color and proceed from there. here's the link if you should run into any problems: http://frickinbrite.com/catalog/index.php
2ND: after receiving your PAIR of the led bulbs, go to your dash and un screw the bolts from the gauge dash console with a 7mm screwdriver or whatever gets the job done,lol.
3RD:after unscrewing that, then unscrew the bolts next to the gauges with same size screwdriver (they're all the same saze bolts)
4TH: then pull the gauges towards you so that you can reach the wiring harness connected to the back of the gauges. un hook the black clip holding the harness either with your fingers or with a screwdriver, but be careful when your using a screwdriver. you don't want to hurt yourself in the process
5TH: after that, unclip the black clips attached to the gauges.
6TH: ok, now get ur torx bit screwdriver or key that will fit into the three screws holes. and just unscrew those.
7TH: now remove the gauges themselves like so.
8TH: now, gently pop out/remove the black clip surrounding the LCD screen. BE SENSITIVE WHEN DOING THIS. don't jerk on the black clip when your removing it or DON'T EVEN TRY 2 BENT THE LCD SCREEN. remember the screen is made out of glass so be sensitive to it and take your time. it's easy 2 remove TRUST ME, so don't give up if you gotten it out yet, your halfway into the process.
9TH: now this is the only tricky part out of the entire thing so follow me on this. now on the back of the lCD screen there's a white surface. now get ur thin razor-sharp edge or razor blade and get in between the glass and the white backing surface. like i've said BE GENTLE AND TAKE YOUR TIME.
now the entire LCD screen can move a little bit thanks to you removing the black clip, so you'll be able to have a little more leverage and room 2 work with when peeling off the white backing.
10TH: alright, now that you have removed the white backing now it's time to sand it down
11TH: ok now flip it to its back side and starting sanding it with your 400 grit sand paper. your should start to see some green/sliver being sanded off. if u don't see this after a while, flip it (only do this if you forgot which side is which).
now after you have sand off everything, get your 600 grit sand paper and wet it a lil' bit. now start to sand off the excess greenish color until it's white.
12Th: now go to your gauge cluster....
.....and flip it over. now look for this gray bulb holder......
and unscrew it with your pliers, fingers or whatever gets the job done.
13TH: now replace the old bulb with your new bulb.
now the bulb, which i've learned at the time, is not same size as ur tiny, old bulb thus meaning it's not going to be a direct fit. so don't push it all the way down otherwise you can't fit it back into the hole you got it from. so what you'll need to do is shove it HALFWAY into the gray bulb holder and tape it on sides to hold it on. use whatever tape is available to you. it's ok to tape it on the sides of the led bulb itself, the light isn't going to shine through that part only through the top.
(this pic is the bulb before the tape was applied on)
14TH: now you can slide in the white backing back into its place and re-attach the black clip onto the LCD screen.
15TH: now stick in the led bulb with its gray holder and twist it into place. now DON'T put everything back into place just yet. go to your car and connect back the wiring harness to your cluster as is. now turn on your headlights (you don't need to start the car or enter your keys for this). this is to test if the led blub is working. if it is, congrats now you can go back and install everything back.
*now if the bulb is not working, take it out and flip over the connector ends of the led bulb. this just only means that you connected the bulb in the wrong position (+ and -), and which is ok, nothing has gone wrong. look at the example below:
and if you can't seem to get it into place undo the tape and stick out the bulb a bit more out of the gray bulb holder so that you can get it to fit inside its hole of the gauge cluster.
16TH: after seeing your led light bulb works, now you re-attach everything back to their places and your end result should look like this, if you have the right set up:
and that's it. i tried to make this project simple and as clear as possible. it doesn't take less than a hour to do and it's really not that hard. if you have any questions just let me know. ill be glad to anwser them. also i would really like to see everyone's end results as well. so if u dont mind just post a few pics of urs on here, that would be great.
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 09-09-2007, 04:37 AM   #2
croto5000
croto5000's Avatar
Fan#: 33665
What I Drive: 2007 ST
FF Reputation: 7 croto5000 Good Standing Member
that's frickin' awesome
croto5000 is offline
Old 09-09-2007, 05:16 AM   #3
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
What I Drive: 2010 Scion XB RS7
Points 10,155, Level 67
Points: 10,155, Level: 67 Points: 10,155, Level: 67 Points: 10,155, Level: 67
Level Up 27% Completed
FF Reputation: 44 zx505focus Great Standing Member
Buy-Sell-Trade Rating: (19)
does anybody know how to do the 05 that way, i know its not the 194 bulbs but just want to know how to do it if its possible
Murasaki Warrior
zx505focus is offline
Old 09-09-2007, 07:25 AM   #4
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
What I Drive: 2005 Impreza 2.5 RS
FF Reputation: 42 miniboon Great Standing Member
good write up, but what did you take those pics with? mad blurry.
Originally Posted by viney266 View Post
I think miniboon is right on the money.
miniboon is offline
Old 09-09-2007, 07:58 AM   #5
Waffles ZX3 Kona Sport
WAFFLEY!
Waffles ZX3 Kona Sport's Avatar
Fan#: 10426
What I Drive: 2006 Fusion SE Midnight Blue
FF Reputation: 11 Waffles ZX3 Kona Sport Great Standing Member
Nice job man, good work!
But yeah, those pics are a little blurry
Waffles ZX3 Kona Sport is offline
Old 09-09-2007, 08:54 AM   #6
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Pretty sure 05 is the same.
How many LEDs do I need to do this, including the LCD?
Algorhythm is offline
Old 09-09-2007, 10:04 AM   #7
sqrly
sqrly's Avatar
Fan#: 22581
What I Drive: 2008 white coupe s
Points 2,848, Level 32
Points: 2,848, Level: 32 Points: 2,848, Level: 32 Points: 2,848, Level: 32
Level Up 66% Completed
FF Reputation: 3 sqrly Good Standing Member
Buy-Sell-Trade Rating: (4)
that makes me wanna get a white face gauge and tear into my cluster
Zetec Crew #136
Xbox Live: SqrlyZX3
sqrly is offline
Old 09-09-2007, 11:30 AM   #8
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
well my camera sucks whenever i have 2 zoom in, but im working on gettin a new 1 soon, so sorry u guys. other than that, u'll only need 1 of those led bulbs but they'll ship you a pair (who knows when u might need it). the other led bulb u can keep as an extra, it only cost me $6.28 total with shipping. thanks for the comment on my g's. and o yeh, this is the exact same way for an 05 and up, so this techique is universal. i tried this already on my friend's 06 the other day and it's still the same way.
ChuckDee is offline
Old 09-09-2007, 11:41 AM   #9
Algorhythm
Fan#: 20623
I've been wanting to do something like this, but I never knew wtf bulb it was. I was going to do blue electrical tape but didn't think it would look good.
I'm gonna order the bulbs now.
Old 09-09-2007, 11:42 AM   #10
Algorhythm
Fan#: 20623
Also, vrom vled.com do I want the super blue LED bulb or do I want the SMT high power blue?
Similar Threads
For Sale: 2003 SVT Focus Sonic Blue Supercharged Pics Inside Thero2002 Archive 7 04-22-2005 11:13 PM
Blue Heater Vent LED? svtfocusmansvt MK1 Interior Mods & Upgrades 4 12-07-2004 01:44 AM
LED Interior Mod question ouikikazz MK1 Interior Mods & Upgrades 5 10-06-2004 03:00 AM
LED vent mod complete! ceejbay MK1 Interior Mods & Upgrades 39 10-03-2004 11:40 PM
Wiring LEDs up to a switch box PreciousAngelJS25 MK1 Interior Mods & Upgrades 62 08-13-2004 05:01 PM
