Overheating Problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-03-2007, 02:57 PM   #1
JDSVT
Fan#: 49707
What I Drive: 2002 Black Focus SVT
FF Reputation: 1 JDSVT Good Standing Member
Overheating Problem
This is some weird stuff here.
Im driving along in traffic and the radiator fans wont come on,have to wait awhile stopped and car goes into the red zone so i turn on the air and then the fans start working. anyone got a clue what my problem is? Thanks
JDSVT is offline
Old 09-05-2007, 10:51 AM   #2
JDSVT
Fan#: 49707
Bump
JDSVT is offline
Old 09-05-2007, 11:07 AM   #3
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Most likely the fan resistor located in the front radiator shroud area, possibily the fan relays have a problem.
penguin is offline
Old 09-05-2007, 11:24 AM   #4
jrgtrain
jrgtrain's Avatar
Fan#: 29105
What I Drive: 2000 Dirt Brown Kona ZX3
Points 5,269, Level 46
Points: 5,269, Level: 46 Points: 5,269, Level: 46 Points: 5,269, Level: 46
Level Up 60% Completed
FF Reputation: 9 jrgtrain Good Standing Member
Buy-Sell-Trade Rating: (12)
Most likely the resistor. Instead of replacing just the resistor you will need to replace the wiring that goes with the resistor. I think they call it the "thermistor pack". I had the same problem.
The headers are so close to the wiring that after awhile it just melts them. This short makes it so that the 1st fan does not come on, causing the overheating problem.
Jr G-Train...A.K.A. Kona Gil
Straight lines are for fast cars...Turns are for fast drivers
jrgtrain is offline
Old 09-05-2007, 12:35 PM   #5
JDSVT
Fan#: 49707
Thanks, its strange usually when a car overheats you have to turn off the air and put on the heat, here i have to turn on the air to get it to cool off lol
JDSVT is offline
Old 09-05-2007, 12:41 PM   #6
JDSVT
Fan#: 49707
yeah im thinkin its the whole pack thing, it does get freaking hot right there, thats a bad location for electrical connections. Thanks
JDSVT is offline
Old 09-05-2007, 01:36 PM   #7
penguin
Fan#: 21700
That's from the old days before electrical fans, when the fan ran off the engine and it's speed was linked with the engine speed.
Nowadays when you turn on your air conditioner, you typically automatically turn on an additional electrical fan, or increase the speed of the fan.
Another change is that in the old days if an engine was overheating at idle, increasing the RPM a bit would cool it down (by increasing the fan speed). Nowadays, with electrical fans, this just makes the voerheating problem worse.
penguin is offline
Old 09-05-2007, 03:25 PM   #8
jmb3675
Fan#: 50012
What I Drive: 2001 silver se
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 jmb3675 Good Standing Member
my 2001 focus zetec started that today. the gauge goes to the red at low speed or idle. according to the scan tool both fans are coming on at 257 degrees. then it cools to 224 and the gauge goes back to the middle. and both fans turn off. it got a new thermostat housing 5000 miles ago and a new water pump 4000 miles ago. i will have to try the resistor.
whats funny is i had to replace my housing at 100,500 miles. i just did my ex-wifes focus today at 99,700 miles. and a freinds last week at 100,200 miles. sure sounds like a timed failure to me.
jmb3675 is offline
Old 09-05-2007, 08:46 PM   #9
JDSVT
Fan#: 49707
I only have 42k on my car, with the air on i have both fans, without none..??..
JDSVT is offline
Old 09-05-2007, 09:28 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
If the fans work at all, I'd say the resistor is ok. How's your temp sensor? In the old days of OBD1 Ford used two temp sensors- one for gauges, and one for the computer. I'm not sure how the SVT engine is wired, but I'd look into that.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Similar Threads
2005 ZX3 w/Hard Start Problem abilath General Technical Chat 20 04-22-2013 11:02 PM
focus ignition problem j.a.dj General Technical Chat 6 12-12-2007 06:52 PM
Replaced the PCV hose and problem still exists. HitTheNutz General Technical Chat 15 11-01-2006 09:56 PM
Problem with AM/FM reception with OEM single-CD audio system lavalfocus Car Audio, SYNC, MyFord Touch & Electronics 0 07-18-2006 01:21 PM
SVT Sub w/Alpine HU - Gain Problem shooga Car Audio, SYNC, MyFord Touch & Electronics 9 07-12-2006 12:35 AM
