Old 10-21-2008, 04:57 AM   #21
Pingouin
Fan#: 53619
What I Drive: Focus
FF Reputation: 1 Pingouin Good Standing Member
I'm not surprised: I've got a British car, so my driver door (which is the one that had the problem all along) is your passenger door (which just started having the problem) :)
I still didn't get time to take my lock out, but hopefully soon. In the meantime, I can still use the key in the driver's door, so it's not all that bad for me.
Since you are an expert, you're welcome to do the 2000 miles return trip to fix mine :p
Pingouin is offline
Old 10-28-2008, 03:21 AM   #22
Bønna
Fan#: 59691
What I Drive: 1999 Dark blue
FF Reputation: 1 Bønna Good Standing Member
Update 2: The passenger was fixed yesterday in the same manner. The microswitch on the passenger side was soaked in the same type of stiff grease, rinsed and lubricated with WD40. It now works, but the drivers door is not working any more, even in room temp.
Can some grease have moved down from parts inside the locking unit onto the microswitch again, or are we facing some kind of multiple error ?
Any tips from experts will be greatly appreciated !
Bønna is offline
Old 11-10-2008, 02:36 PM   #23
tomFS08
tomFS08's Avatar
Fan#: 60493
What I Drive: 2002 ford focus
FF Reputation: 1 tomFS08 Good Standing Member
There's a lot of talk about WD40. Anyone tried another lubricant to get the job done?
I work for Jig-A-Loo and am interested if anyone has tried the product and I'm free to answer any questions about it. It's a sillicone based lubricant and water-repellent. It can be used like WD40, but since it contains on grease, oil or wax, it's much safer and won't cause build up.
If anyone is interested, we are letting people try it out for free (to see for themselves if they want to make the switch). Head to http://www.jigaloo.com/us/e_tryonefree.php for the downloable rebate form.
Thanks,
Tom with Jig-A-Loo
tomFS08 is offline
Old 11-26-2008, 09:15 AM   #24
focus2001user
Fan#: 60849
What I Drive: 2001 SILVER FOCUS
FF Reputation: 1 focus2001user Good Standing Member
Central Locking
@Exsodius
Can the red dot (to apply the WD40) be accessed without taking the latch lock mechenism out of the door?
Originally Posted by exsodius View Post
Problem solved!
My central lock has worked fine for a month now. Even when its raining or are cold.
What i found after cleaning the lock mechanism was that it has a microswitch like in your PC mouse buttoms. In picture you see the black switch with the red dot on it. This red dot is a water proof rubber seal for the switch pin. This red seal made the switch pin hang when it was cold. In my case it was full of grease. I measured the switch with a multimeter. When pin is pushed inside the doors are locked, when the pin is out the doors are open. So what happend was that when unlocking the car the switch stayed closed. And the other doors sent a negative signal that was telling the driverdoor that they were unlocked. Then you had two negative signals making a short circuit. And then all doors stopped working. So i believe many focuses have this problem. And have probaly changed the whole unit with a new one. But that is expensive.....
Tip: Clean and spray microswitch with WD-40 if you have this problem.
focus2001user is offline
Old 05-31-2009, 04:22 PM   #25
Pingouin
Fan#: 53619
What I Drive: Focus
After one year, I eventually moved to a place with a driveway!
So I got around to take my door apart, found and sprayed clean the microswitch, and my central locking is working again!
So thanks to everyone around for the great tips
Pingouin is offline
Old 10-28-2009, 06:36 PM   #26
exsodius
Fan#: 14827
What I Drive: 2002 Silver 1.6 Wagon
FF Reputation: 1 exsodius Good Standing Member
Great! Wonder if ford has changed/ improved these microswitches in a new doorlock part today?
Ford Focus 1.6 Wagon
exsodius is offline
Old 03-22-2010, 05:35 AM   #27
Bønna
Fan#: 59691
Im afraid not, same sympthoms in my 5 year newer Mondeo this winter, below -10.
It even lock itself with the motor running ! Spooky !
Bønna is offline
Old 03-22-2010, 06:12 AM   #28
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Posted via FF MobileI worry about closing adoor with the key in for that reason!
sailor is offline
Old 03-22-2010, 01:20 PM   #29
exsodius
Fan#: 14827
In english:
This problem will come back unless you keep spraying som wd-40 on the microswitch. I have made it simple to do. Just have the lowest screw on the door unscrewed all the the time. You know the 3 torx screws at the door lock. Now i can spray wd-40 in that hole whenever i want. It works very good, i can even hear a click from the central lock while spraying. And then it suddenly works again. It would have been nice if i could find a spray that is better than the wd-40 so i wouldn't need to spray it once a month.
In norwegian:
Problemet kommer tilbake så lenge du ikke smører mikrobryteren. Jeg har gjort det så enkelt nå at jeg har den nederste skruen av de 3 skruene på låsen i døren utskrudd hele tiden. Så nå er det bare ett hull der som jeg kan spraye inn wd-40 når jeg vil. Det fungerer så bra at jeg til og med hører mens jeg sprayer ett klikk fra sentrallåsen nå den plutselig virker igjen. Det er bare litt wd-40 som skal til. Hvis jeg hadde funnet en spray som var bedre hadde jeg sikkert ikke trengt og gjort det 1 gang i mnd.
exsodius is offline
Old 03-23-2010, 08:55 AM   #30
Pingouin
Fan#: 53619
What I Drive: Focus
Yep, my fixed central locking stopped working few months ago again. I'll have to try your tip exsodius, although IIRC, the bottom screw hole is nowhere near to the switch, so I guess that you need a WD-40 flood for anything to happen :( Still worth trying since I don't fancy taking the door apart again.
Pingouin is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 09:59 AM
Central Locking System ZeDo General Technical Chat 9 01-25-2012 11:55 AM
Central Locking Lundbeh General Technical Chat 2 02-26-2006 01:06 AM
Problems with installation a remote control for the central locking system texx General Technical Chat 0 08-10-2004 11:52 AM
Focus Central Dyno Day(s) whitelighter Ford Focus & General Car Chat 25 04-07-2004 09:24 PM
