shift problem after new TPS install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2007, 09:15 PM   #1
straightjacket
Fan#: 49829
What I Drive: 2000 silver SE
FF Reputation: 1 straightjacket Good Standing Member
2000 Focus SE. 2.0L. Automatic.
CEL was on. Codes were P1120 and P0122. Went to AutoZone and asked for a TPS. The one they gave me was the thick one. The one I have is the thin one. Read another post that said the TPS from a 2002 Escape is the same as the 2000 Focus. So I special order the TPS for the 2002 Escape. Get it today and it looks identical to the one I'm replacing. It's got some different numbers on the housing, but otherwise looks exactly the same.
Install the new TPS. Reset the CEL by disconnecting battery for about 30 minutes. Take it for a drive.
I had an early shift from 1st to 2nd. Once in second it revs to about 4k RPM and then settles back down. Same problem each time I stop and go.
Get it back home and reinstall the old TPS and it's back like it was before I replaced the TPS.
So, is the TPS from a 2002 Escape really the same as the 2000 Focus SE? Even though I have the thin TPS, should I just take the thick one that the AutoZone computer is saying is the correct one?
straightjacket is offline
Old 08-28-2007, 09:21 PM   #2
captcomputer
captcomputer's Avatar
Fan#: 9409
What I Drive: 2013 Focus ST (Preferred Blue)
Points 10,721, Level 68
Points: 10,721, Level: 68 Points: 10,721, Level: 68 Points: 10,721, Level: 68
Level Up 68% Completed
FF Reputation: 37 captcomputer Great Standing Member
That is what mine was doing when Ford replaced it. Push in the clutch and wee 4grand. So I dont think the new one is any good.
Joe Cool
Social groups:
LoneStar Fanatics
(Former)Blue Focus Owners
captcomputer is offline
Old 08-28-2007, 09:52 PM   #3
straightjacket
Fan#: 49829
No good because it's not the right one? Or no good, because it could be bad out of the box?
Old 08-29-2007, 12:11 PM   #4
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
take it back and get the one it says you should have.
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 11-13-2007, 10:39 PM   #5
gregbiffle
Fan#: 51556
What I Drive: 2000 silver se
FF Reputation: 1 gregbiffle Good Standing Member
i have a 2000 se with 2.0l zetec and i have run out of ideas we were haveing shifting problems then it all of a sudden ran a code p1120 (i think you all know what that means) so to make a long story short we bought a new tps and it does the same early shifting into first and second so the guy at the garage said the new tps was bad so we went and bought another and it did the same ford says the same as all the other guys and that is that you gotta buy the whole throttle body with the tps and pig tail is this my only option or is there something i'm doin wrong please help
gregbiffle is offline
Old 11-13-2007, 10:57 PM   #6
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,577, Level 62
Points: 8,577, Level: 62 Points: 8,577, Level: 62 Points: 8,577, Level: 62
Level Up 43% Completed
FF Reputation: 17 svtguy88 Great Standing Member
::sighs::
I wish Autozone/garages/dealers knew what they were talking about. The Escape TPS is identical. The numbers are different, but the voltage readings are the same (I tested this when I did my TB/TPS). I don't remember the voltage readings at idle vs. WOT, but I can dig them up if someone wants them.
You should replace your TPS with whatever was on the car, and not what Autozone tells you. Their system is wrong. Trust me. If you need the thin one, have them page through their system until they find a year/model/engine that used the thin one, or find the Escape one that used it. They can bring up a picture of what you are buying. Or, at least Advance Auto can.
Anyway, if you have the Escape one, and it is thin, and that is what was on your car before...most likely you need to flip it 180* and reinstall it. Take the TPS off and face it in the other direction. For example, if the wiring was facing down, make it so it faces up. Usually, this is the problem. If not, then the sensor is probably faulty and you should measure it with a voltmeter.
My situation that made me learn this was kinda special. I was installing a FC 65mm TB, which, unbeknownst to me, is designed to be used with the MTX TPS (thin one), and my car had the other one. So, after trying every position on the TB and every combination of TPS you could, I measured the voltage, and realized I needed the thin one. A little "alteration" to my wiring harness later and the thin TPS later..I was good to go.
svtguy88 is offline
Old 11-14-2007, 12:26 AM   #7
stivo
Hiyadoin'
Fan#: 48389
What I Drive: 2004 Infrared SVT, EAP #1440
FF Reputation: 9 stivo Good Standing Member
Buy-Sell-Trade Rating: (6)
Yeah... you know it's company policy to put a cover on the TPS reports now. Do you have the memo?
stivo is offline
Old 11-14-2007, 12:59 AM   #8
svtguy88
svtguy88's Avatar
Fan#: 13476
LMAO.....hahahahahahahahahah. Have you seen my stapler?
svtguy88 is offline
Old 11-14-2007, 01:11 AM   #9
stivo
Hiyadoin'
Fan#: 48389
gonna burn the building down.
stivo is offline
Old 11-14-2007, 01:55 AM   #10
focusonthis420
focusonthis420's Avatar
Fan#: 30951
What I Drive: SGM 2012 5dr
FF Reputation: 17 focusonthis420 Great Standing Member
Buy-Sell-Trade Rating: (26)
PC Load Letter... What the does that mean?!
Sterling Gray Metallic 2012 5dr Titanium w/ MS3 RMM
focusonthis420 is offline
Similar Threads
ATX Shift Issues svtguy88 General Technical Chat 8 05-26-2007 10:20 AM
CAI install, ran into a problem. -Picture- PhilMayfield DURATEC Performance (2003-2007) 32 10-10-2006 11:02 PM
2003 Focus Central TB, and the TPS problem, install zGOTxBOOST2 ZETEC Performance (2000-2004) 6 09-23-2006 05:10 PM
Short Shifter Install Problem - plastic retaining clip ouikikazz ZETEC Performance (2000-2004) 7 09-14-2004 09:54 PM
New install, now a problem Lil_RedZX3 ZETEC Performance (2000-2004) 16 09-08-2003 11:31 PM
