#1 | ||||
tired of your black valve cover??
well i was so i finally got around to doing something about it. and since i couldnt find a how to on here to give a little insight i figured i would make one.
first off tools- flat head screw driver 1/4" deep sockets and ratchet hammer supplies- 1000 grit sand paper masking tape purple power(or equivalent) brake clean(carb&choke clean) primer white paint(if you used a clear primer like i did) paint of color choice clear coat shop towels ![]() ![]() heres a before shot ![]() ok to get started un plug the fuel injectors,the thing on the fuel rail, coil packs, the two sensors on top of the valve cover, and the little ground wire conn. being extra careful with this connector ![]() then you can remove the plastic wire holder to the far left of the valve cover(holds the main fuse) by snapping it off by the five tabs ![]() ![]() then pull the wires out of the way as much as possible. there is a little metal bracket in the back right corner, you need to remove the wire from it and bend it back slightly for clearance ![]() now remove the coil packs using caution you can now remove the valvecover bolts breaking all of them loose a 1/4 turn before removing one. ![]() (some of the studs on my valve cover were to long for even a deep socket to reach the nut,i tapped the socket down over the stud to reach the nut.) the valve cover should be relatively free but you tap it with a hammer lightly to pop it free. BE SURE TO COVER THE CAMS AND CHAIN WITH SOME TOWELS! ![]() here is the removed valve cover ![]() you should remove the sensor attached to it at this point too to remove the bolts from the valve cover you need to tap out the retaining sleeves ![]() to do this find a deep well socket that is the same size as them ( i used a 7mm one) and tap them out with a hammer ![]() heres what you should be left with ![]() i used compressed air to blow the bits of dirt out of all the cracks now do a real quick cleaning with the brake clean. then sand everywhere you can reach. then do a good cleaning with purple power(50/50 mix) i then dried with compress air and used brake clean to remove any remains of the degreaser. once your sure its dry (left mine in blazing fla sun for an hour) you can tape off the vent piece ![]() ok paint time!!! i used adhesion promoter which is clear so i painted it bright white first to make the blue come out MUCH brighter and richer. ![]() then i put on the blue!!! ![]() ![]() after the blue dried for a little bit i put on about 15 coats of clear to really make it shine. then you can tap the sleeves back in and reverse the removal heres the finished product!!!!!! i am getting that cover that focalpointgraphix was posting on here also should arrive anytime! ![]() ![]() ![]() ![]() and just for fun heres some pics of me and my BP teammate playing the champion of our beer pong tourny we throw at froggers every week. DEAN ROAD DESTROYERS! ![]()
Remove Advertisements |
Fan#: 1
#3 | ||||
Looks good. I'll have to give that a try. Really hads some flare to the engine compartment.
Sedan Revolution #54 Team Duratec #107 |
#5 | ||||
looks good... i wonder how the paint will hold up to the heat though.
http://www.full-race.com/r14-fire-video.html |
#6 | ||||
i have done this to just bout all my cars and have always just used regular spray paint. i have had these jobs stay looking new for about 65k miles. it is ALL in the prep(clean twice paint once). plus composite valve cover should never see more than 150 or so degrees. if you have a metal cover i would recommend high temp paint
#8 | ||||
#10 | ||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| "How To" - Replace Valve Cover Gasket and VCT Solenoid | JohnMichael | General Technical Chat | 45 | 03-10-2013 08:06 AM |
| Metal Valve Cover | isaac_in_tx | MK1 Interior Mods & Upgrades | 6 | 03-28-2007 11:50 AM |
| Question about the Duratec Valve cover.. | NIR Panther Jedi | DURATEC Performance (2003-2011) | 9 | 08-29-2006 01:00 AM |
| Valve cover gasket | blck01zx3 | ZETEC Performance (2000-2004) | 12 | 08-06-2005 07:13 PM |
| PCV Valve on teh SPI.. - finally found it. | The_good_guy | SPI Performance (2000-2004) | 2 | 06-17-2004 08:35 PM |
