clunking in front going over bumps.. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-15-2007, 09:01 AM   #1
Sid03SVT
Sid03SVT's Avatar
Fan#: 39759
What I Drive: 02 Explorer 4.6L, 02 CBR600 F4i
FF Reputation: 8 Sid03SVT Good Standing Member
Unhappy clunking in front going over bumps..
ok so i posted here because i feel like its a suspension problem, that stated...
stock 2003 svt focus with 74,xxx miles, I hear a clunking noise when going over bumps from the front end, I plan on getting under there and yanking stuff around to see if anything is loose, but I want the opinions of others,
could my suspension just be on its way out?
could it be that stupid factory rear engine mount again? (replaced 20k miles ago)
sway bar end links or bushings crapped out?
trans-axle giving up on me? (i doubt that)
let me know what you guys think, i appreciate the input, thanks!
save a cow, eat a vegan
missing my 6-speed until proven otherwise
if someone helps you out, give them a rep point
don't know how? click on the number next to "FF Reputation" and add a comment
Sid03SVT is offline
Old 08-16-2007, 11:15 AM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The end links and motor mounts are easy enough to check...have you?
Geezer is offline
Old 08-16-2007, 11:21 AM   #3
focusonthefocus
Gan-San!
focusonthefocus's Avatar
Fan#: 1411
What I Drive: 2002 CD Silver SVT Focus
FF Reputation: 5 focusonthefocus Good Standing Member
Have you replaced your control arm? Mine was bent and throwing in some performance bushings solved the issue for the most part. There is also a TSB out for the suspension... I believe Hillbish Ford would be able to give you a run down of what they're looking for.
Daniel
Focus on the Mountain
focusonthefocus is offline
Old 08-16-2007, 11:23 AM   #4
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
I am starting to experience something similar....I am worried that it might be my CV joint because it is definitely not my motor mounts as they were just upgraded.
I sure hope it's not a CV joint...
afraziaaaa is offline
Old 08-18-2007, 09:08 AM   #5
budiac
Fan#: 49467
What I Drive: 2003 Silver ZTS
FF Reputation: 1 budiac Good Standing Member
I just had this problem. It was a bad end-link.
budiac is offline
Old 08-18-2007, 01:10 PM   #6
svt0251
svt0251's Avatar
Fan#: 49483
What I Drive: 02 Svt Focus Pitch Black
FF Reputation: 1 svt0251 Good Standing Member
i would say you could have a broken coil if it is to one side or the other
svt0251 is offline
Old 08-18-2007, 03:15 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
End links clunk over bumps and after hard turns.
Loose struts (very rare, usually happens after replacing struts) clunk over bumps, and click and squeak in turns.
Ball joints clunk once just after starting moving, and just after stopping- even at parking lot speeds.
Outer CV joints clunk repeatedly first in full turns, then later in lesser turns, and finally in straight line acceleration which is when the axle should be replaced. Inner CV's don't generally clunk but will cause extreme vibration at steady speeds which disappears during acceleration.
Bad control arm bushings squeak at low speeds over bumps and in turns if any sound at all. Most of the time a loose suspension is the only indicator.
Front wheel bearings will cause vibrations in turns on the affected side, a dull roar easily mistaken for road noise, and before locking up will make a noticable rum rum rum sound at parking lot speeds.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-21-2007, 03:14 PM   #8
Sid03SVT
Sid03SVT's Avatar
Fan#: 39759
I'm going to check my end links this weekend
I'm damn sure i didnt break a spring
the motor mount is definately toast again; I'm just going to have to break down and buy a VF mount....
my CV joints are fine
not so sure about the wheel bearings although I'm feeling they aren't the issue; how long do they last on these cars? (I've never had to replace them in any other car I've ever owned, not even my 66 mustang with over 300k on it....)
thanks guys
Sid03SVT is offline
Old 08-21-2007, 05:53 PM   #9
Geezer
Fan#: 1427
MAC makes a nice rear motor mount that's a little cheaper than the VF. It may not be quite as pretty as the VF (whose going to look under there anyway?), but it comes with zerks to keep the bushings lubricated which the VF doesn't have.
Geezer is offline
Old 10-17-2007, 05:20 PM   #10
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
what is a loose strut?
bearing cap loose? or tower bolts loose? pinch bolt?
mine is doing this now after putting teins on stock struts. left side feels great, but not the right.
scrammer is offline
Similar Threads
Front License Plate Help AprilFool MK1 Focus 20 07-03-2011 11:57 PM
WTT: My SVT front 4 Your ST front RSVT170 Archive 15 11-13-2005 08:33 PM
Front End Help jbondjr MK1 Focus 7 09-03-2005 12:11 AM
For Sale: APC front and rear bumpers, and Halo head lights. DareDevil03 Archive 13 08-20-2005 12:17 PM
