2001 ZX3 rear brake squeaking (how to take them apart) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-14-2007, 04:57 PM   #1
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,806, Level 54
Points: 6,806, Level: 54 Points: 6,806, Level: 54 Points: 6,806, Level: 54
Level Up 28% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
A little while I posted here asking if anyone else has had the same issue:
-with parking brake off, squeaking sound when you let go of the brake pedal-
I went to the local mechanic to get an idea and he said: "that's easy, the sound you hear when you let go of the brake pedal are the rear drum brakes. The 'backplate' needs lubricating."
I'm wondering if it's something I can do myself (since I like to take on tasks like this) or if I should leave it to the pros. He said it would take about an hour and charge $90cdn.
Anyone know of any diagrams/instructions on the rear brakes?
thanks!
ChrisRobin is offline
Old 08-14-2007, 05:29 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
You can buy a Chilton's or Haynes repair manual at auto stores for about $15-20 U.S. It's a good investment if you do things like this yourself, as they generally give step by step instructions with photos.
penguin is offline
Old 08-14-2007, 08:21 PM   #3
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
Oh that's right! I totally forgot about that. I'll see what it has. I figure I might as well do it all myself.
Old 08-14-2007, 10:50 PM   #4
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
let me know if this helps.....
http://www.focushacks.com/index.php?modid=48
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Old 08-14-2007, 11:58 PM   #5
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
You're my hero, that's exactly what it is. Looks tricky, I'm wondering if I should just let them do it. I'll check the price of the supplies aswell.
Old 08-15-2007, 12:09 AM   #6
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
Points 6,024, Level 50
Points: 6,024, Level: 50 Points: 6,024, Level: 50 Points: 6,024, Level: 50
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
^^^ It's really not as bad as it looks. I just did my rear brakes. The four spindle bolts are something of a PITA, but the springs aren't that bad.
I bought a haynes manual and it was very helpful in disassembling the rear brakes. You might just want to do your rear brake shoes since you have a 2001, and you'll have them off anyway. it cost me all of $40 u.s. for a set of good shoes (Wagner).
My advice is to take both drums off, but only dissassemble one brake at a time. That way you can use the other brake as a reference in case you forget where a spring goes, etc.
Oh yeah, and it's an excellent opportunity to paint your drums once they're off your car.
HN #171
Black&Tan is offline
Old 08-15-2007, 09:51 AM   #7
zx32nr
zx32nr's Avatar
Fan#: 43460
if u wanna do it the easy way, when i did mine, i just pulled the drum off. then i took off the 2 shoe hold down pins and peeled the shoes up, and cleaned behing, then put grease on all the contact points and re assembled, prob took like 45 minutes.
but glad to hear that i could help
good luck bro
Zetec Crew #175
REP WHEN REP IS DUE
zx32nr is offline
Old 08-15-2007, 02:14 PM   #8
c170zetec
c170zetec's Avatar
Fan#: 49404
What I Drive: 2001 Yellow ZX3
FF Reputation: 1 c170zetec Good Standing Member
Also not sure if this helps but there's a service bulletin for a rear brake squeal, ford has updated the rear wheel cylinders, brake drums and shoes, here are the part #'s (6S4Z-2200-B) Shoe/Lining Brake Kit, (6S4Z-2261-AA) Wheel Cylinder, (8S4Z-1113-A) Brake Drum
Zetec Crew #171
“We are what we repeatedly do. Excellence, then, is not an act but a habit.” — Aristotle, 384-322 B.C.
c170zetec is offline
Old 08-15-2007, 05:37 PM   #9
felcon36
felcon36's Avatar
Fan#: 44737
What I Drive: 2003 CD Silver SVTF
FF Reputation: 1 felcon36 Good Standing Member
I had the same problem. They had to put weights on the brakeplate.
felcon36 is offline
Old 08-15-2007, 07:26 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Make sure you get the right grease. Wheel bearing grease will not work. There is a special type of grease for brakes that can withstand the extreme heat. Parts stores should sell this in a small packet for a buck and change. One packet should do it, but I'd probably get 2 if it was me.
I believe the proper name is "disc brake caliper grease", or it might be just "brake parts grease". The parts man should know what it is, if you get someone who appears confused- find someone else.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Similar Threads
Where can I get a DTM rear bumper for a 2001 ZX3? Kwizatz-Haderah MK1 Focus 2 02-06-2007 03:35 PM
How to install rear svt disc brake on a ZX3 TURBO-ZX3 Brakes, Suspension & Body Chassis 20 09-01-2006 07:13 PM
2001 Focus ZX3 Issues. YIRide General Technical Chat 7 02-19-2006 01:17 AM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
2001 ZX3 Brake Solution chenc544 Wheels & Tires 16 08-04-2004 03:52 PM
