Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 08-10-2007, 11:32 AM   #21
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Memberhonhon Excellent Standing Memberhonhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
ZEX kit usually the most recommended because it has its own computer that monitors a/f ratio and adjusts the shot accordingly... so you may not get the whole 50shot all the time... but atleast you'll still be able to drive home and not have to tow the car home from it running too lean.
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 08-10-2007, 04:11 PM   #22
netdrgoon
netdrgoon's Avatar
Fan#: 26752
What I Drive: 2005 Focus Zx3 se D20 M5 - blazing
FF Reputation: 2 netdrgoon Good Standing Member
50hp is uber safe. 75hp wet, I wouldn't worry about it with proper fuel (91 or 91/101 mix), proper plugs (one or two steps colder), and retarded ignition timing (-4* would work, -6* might be a little better).
2.3 guys need a higher window (due to their intake manifolds), so 3000 minimum to 6-6500. A 2.0 should be safe from 2500-6500.
2005 Focus Zx3 se D20 M5 - "Helios" - blazing copper
intake, header, exhaust, xcal2 tune, !CMC, cams, suspension, nitrous, torsen, spec lw flywheel and stg1 clutch
home brew turbo in the works
netdrgoon is offline
Old 08-10-2007, 04:41 PM   #23
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
wow you guys really know your stuff. so in a hatch with obvoiusly limited space (i have a strut bar in there now) how would be the best way to mount the tank? i have seen people mount them parallel with the rear bumper and with the valve end facing the seat. which is best
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 08-10-2007, 04:57 PM   #24
heelflip101
Get The Hammer!
heelflip101's Avatar
Fan#: 32770
What I Drive: 2000 Mali zx3
FF Reputation: 29 heelflip101 Great Standing Member
You want the valve towards the front of the car. You could take out the spare and put it in there
If you have choice between affording a mod or eating, buy the mod. The weight loss will only make you faster.
heelflip101 is offline
Old 08-11-2007, 09:11 AM   #25
SaleenS121
SaleenS121's Avatar
Fan#: 44037
What I Drive: 2005 Saleen S121 Focus Yellow
FF Reputation: 1 SaleenS121 Good Standing Member
you can run a 75wet shot easy on the duratecs. i ran it for quite some time. you should check out www.nitrousexpress.com they got some nice options. id look at getting a window switch, blow down pipe, and a bottle warmer to make it all the much better.
XBOXLIVE:Tommaco
SaleenS121 is offline
Old 08-12-2007, 01:22 PM   #26
strung
PIMP'N AINT EASY
strung's Avatar
Fan#: 44516
What I Drive: 06 RED ST/SAP1
FF Reputation: 34 strung Great Standing Member
question...i had planed on buying the f2 header next month but have post poned/changed my mind due to extra noise...(shit...and ive already purchased the 02 sensor disable for my xcal2)....ive ordered some heat vents for my hood instead...(my sri needs heat venting help...and yes, the vents look way cool).....anyhow....if i choose not to get a header can i still run the 50 wet shot safely....i dont know if the exhaust gas from that shit will fry my primary cat/sensor or not..(well, i guess i do have the 02 sensor disable...huh)..anyone here running nos with no header/with a cat?
ST CREW #62
put your motor where your mouth is.
strung is offline
Old 08-12-2007, 01:39 PM   #27
netdrgoon
netdrgoon's Avatar
Fan#: 26752
With that little, you will be fine. We have run nitrous on cars with catalytic converters with absolutely no issues. Just use the recommended jets for the shot, and you won't have too much fuel fouling out the cat.
The good thing about a header with nitrous is this: you will have LOTS of exhaust to move, and a header facilitates moving this gas out much easier than the stock manifold. That is to say, a car with the header would make more power with the same other mods/nitrous jets as your car. Now as far as torque..I'm not totally sure how that would be effected.
Old 08-12-2007, 01:42 PM   #28
strung
PIMP'N AINT EASY
strung's Avatar
Fan#: 44516
very cool....thanks for the response man.
ST CREW #62
strung is offline
Old 08-12-2007, 02:53 PM   #29
honhon
Fan#: 24778
if you disable the rear o2 sensor thats one less CEL you'll have to worry about...
honhon is offline
Old 08-12-2007, 08:00 PM   #30
strung
PIMP'N AINT EASY
strung's Avatar
Fan#: 44516
i hear ya....that same program also has my egr disable on it....so thats two cel lights not to worry about...hehehe............whoah!....when the hell did i pass your post count honhon??....damn....i am a post whore!
ST CREW #62
strung is offline
Similar Threads
Nitrous Questions..read here first. viney266 General Forced Induction 396 06-28-2012 11:26 PM
Nitrous and Diablo tune chad_p71 General Forced Induction 2 03-13-2006 03:28 PM
Full Nitrous kit and n2o accessories! ZEX zGOTxBOOST2 Archive 4 11-21-2005 11:51 PM
[FS] Nitrous stuff... CHEAP** flake_silver_zx3 Archive 4 04-29-2005 10:08 AM
