2002 FOCUS CODE P0750 Shift Solenoid A Malfunction - Focus Fanatics
Old 08-08-2007, 08:04 PM   #1
regis
Fan#: 49359
What I Drive: 2002 SILVER FORD FOCUS SE WAGON
FF Reputation: 1 regis Good Standing Member
Hi I'm having problems with the transmission after third shift it jumps into neutral for like five seconds then jumps hard into fourth, I purchased a OBDll CAN scaner and it read P0750 Shift Solenoid A Malfunction I cleared the code and the car ran perfect for like two days and started all over with the same code, how hard is it to replace this solenoid and witch one is it in the transmission box and do you think this will take care the problem, I went to the ford dealer and one solenoid cost $100 not bad but it shows 3 in the transmission witch one is it?, I know if I take it to a transmission shop they just want to replace the transmission to make more money, I'm a aircraft mechanic and I think I can do this but I need more information from someone thats been thru this problem before, thank you in advance for your help.
UPDATE 8/9/2007: Now the code won't clear & the engine light resets off and comes back up within 2 minutes (It's getting worst HELP)
Last edited by regis; 08-09-2007 at 08:53 PM. Reason: Condition Update getting worst
regis is offline
Old 08-08-2007, 09:05 PM   #2
tekilazo
Fan#: 49279
What I Drive: 2001 Yellow ZX3
FF Reputation: 1 tekilazo Good Standing Member
I have the same problem, let me know if you figure it out.
http://www.focusfanatics.com/forum/showthread.php?t=130821
tekilazo is offline
Old 10-15-2008, 04:57 PM   #3
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
http://www.focusfanatics.com/forum/s...ighlight=p0750
has the how to very easy to replace
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
FociBoi121 is offline
Old 10-15-2008, 07:44 PM   #4
danskool
Fan#: 59864
What I Drive: 2004 FORD FOCUS ZX5
FF Reputation: 1 danskool Good Standing Member
My problem has a bit different symptoms. Mine don't toss on the light.
http://www.focusfanatics.com/forum/showthread.php?t=176193
Your Light and Malfunction A.
5/16 socket 1/4"drive and a 2"extension. Is all you need.
An oil catch pan/Filter and 4 quarts of oil. and some rags.
Pull pan. 20 screws. SPLASH
Unplug temp sensor from filter. Plug sensor in new filter. (just pulls out)
Pull Down filter. Has oring squeeze is all. She comes out with a tug.
Unplug "a"
5/16 on solenoid.
Tug on solenoid. She slides out.
Oil up orings on new solenoid and pop back in.
Plug wire back in.
install filter
reinstall pan with gasket that came with filter.
Torque bolts to 60-70 inch pounds.
Dump in 3 quarts.
Check and add if necessary.
Shift solenoid A: P/N XS4Z-7H148-AA $45.77 same as “A,B” Just bought one two days ago.
Dan
danskool is offline
Old 10-15-2008, 08:31 PM   #5
FociBoi121
FociBoi121's Avatar
Fan#: 53573
you mean trans fluid right no oil?
ZETEC Crew #237
PS3 ID: LarkBoi189
Old 10-15-2008, 08:37 PM   #6
moenterzx3
Fan#: 53256
What I Drive: 2001 red zx3
FF Reputation: 1 moenterzx3 Good Standing Member
he may have gotten this fixed already. it was about a year ago
moenterzx3 is offline
Old 10-15-2008, 09:39 PM   #7
FociBoi121
FociBoi121's Avatar
Fan#: 53573
i kno well im going through the same problem and doubt hes an active member anymore so i thought id go through a couple posts and place the how to i found
i donno bored and frustrted i guess
ZETEC Crew #237
PS3 ID: LarkBoi189
Old 04-07-2011, 07:22 PM   #8
foxyl6162
foxyl6162's Avatar
Fan#: 84165
What I Drive: 2002 GREY FOCUS ZTW ZETEC 156K
FF Reputation: 1 foxyl6162 Good Standing Member
Dandcool tyvm for the informative diagram made things insanely easy lost O.D and thought trans would be done Thanks was solenoid A works fine after replacing it, so far drove 20m ill see how it is in a week and then celebrate hehe.
foxyl6162 is offline
Old 11-11-2011, 11:45 AM   #9
Gilbey725
Fan#: 91676
What I Drive: Grey
FF Reputation: 1 Gilbey725 Good Standing Member
Solenoid A
Thank you to everyone for the great information. My OBD reader was saying Solenoid A. Followed the other posters instructions and have no problems again. Most of the shops wanted 2 hours labour. I did it in about 2 hours myself. My 02 Focus has 261k kms. Still going strong. Also did the Thermostat Housing recently.
Gilbey725 is offline
Old 03-21-2012, 05:17 PM   #10
Davelavallee
Fan#: 96500
What I Drive: 2002 SE Midnight Grey
FF Reputation: 1 Davelavallee Good Standing Member
Old thread or not it just saved me a lot of money
Davelavallee is offline
Similar Threads
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 10:47 PM
p0750 code????? billison General Technical Chat 0 02-03-2007 04:24 PM
Body/Lip Kit Companies S2 MK1 Focus 1 12-04-2004 04:20 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 04:31 PM
Ford Focus: Parts Links hotfocus Member FAQ's & How-To Information Archive 0 10-21-2003 09:34 AM
