How are people cleaning their throttle bodies? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-08-2007, 08:21 PM   #1
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
I just tried cleaning the throttle body on my '01 Zetec at 62,000mis. It was pretty gunked up. I used paper towels soaked in Gumout throttle-body cleaner (guaranteed not to harm the teflon coating on the throttle body) to get the ridges and crud out of the throttle body where the throttle plate comes to rest at idle. The edges of the throttle plate were also awful. I have a much smoother idle now.
My question is this: there is still a lot of gunk remaining in the throttle body below the throttle plate, and on the bottom of the throttle plate itself, that I can't get at without removing the throttle body from the manifold. Is there a gasket or a reusable o-ring between the throttle body and the manifold? What are other people doing to clean the throttle body? Just spraying cleaner in there does not work on accumulations like I had. Are people successfully removing and replacing the throttle body reusing the manifold-to-throttle body seal?
drjkel is offline
Old 08-08-2007, 08:24 PM   #2
NikiterZTS
NikiterZTS's Avatar
Fan#: 28234
What I Drive: 2002 Gun Grey ZTS
FF Reputation: 5 NikiterZTS Good Standing Member
i never heard of people do this.....everyone is scared to damage that coating.....
I'm here to raise that BS flag.Ford Focus ZTS 125whp/129wtq
Subaru Impreza WRX Stage 2 Protuned On Mustang Dyno 207whp/273wtq
I have 5 points on this site :-/
NikiterZTS is offline
Old 08-08-2007, 08:29 PM   #3
drjkel
Fan#: 34025
Been doing it for years on Taurus throttle bodies with no problem. Just use the right stuff. Besides, the coating is moot when it's covered with a millimeter of crud.
drjkel is offline
Old 08-08-2007, 08:31 PM   #4
myFordPerformance.com
Fan#: 454
What I Drive: A Car
FF Reputation: 6 myFordPerformance.com Good Standing Member
Buy-Sell-Trade Rating: (29)
We talking about the stock t/b or aftermarket ?
If it's that dirty, I suspect you need to clean many other parts of your engine bay as well.
Personally, assuming you also still have the stock intake on the car, is remove the airbox assembly and tb and clean them both real good. That will give you some room to work on cleaning other parts of the engine bay as well.
Here's my how-to on removing the t/b: (part of them aftermarket t/b install)
http://www.myfordfocus.com/how-to/65mm.htm
Good luck.
Ray Dixon
IntakesAndExhaust.com / myFordPerformance.com
myFordPerformance.com is offline
Old 08-08-2007, 08:32 PM   #5
NikiterZTS
NikiterZTS's Avatar
Fan#: 28234
so Gumout throttle-body cleaner is the way to go?
oh and how often should this be done?
Old 08-08-2007, 08:37 PM   #6
drjkel
Fan#: 34025
OK - The answer is it's a gasket not an o-ring. Thank you, Ray. That means no removal without a new gasket on-hand. Stock throttle body by the way. The "sheet metal" screws into only the plastic of the intake manifold make this a higher risk endeavor than one would want.
The rest of the engine is real clean. I see this on the Taurii also. Something about the pressure drop at the throttle plate preferentially deposits crud there.
I have used the Gumout throttle-body cleaner (NOT CARBURETOR CLEANER) with success. *Your results may vary*
drjkel is offline
Old 08-08-2007, 08:42 PM   #7
Xetchx
Xetchx's Avatar
Fan#: 49113
What I Drive: 03 Silver SVT
FF Reputation: 23 Xetchx Great Standing Member
I know once apon a time when I owned a Honda Accord I took it to a auto shop ( like HI-LO or Jiffy lube) and they had a TB cleaner. was a machine or something they hooked it up to to clean it. Car ran good afterwards.
Xetchx is offline
Old 08-08-2007, 08:46 PM   #8
Fan#: 454
What I Drive: A Car
Can't tell you how many times I had the stock and 65mm t/b on and off and on again and re-used the gasket over and over. You just got to be careful not to tear it.
The screws into the plastic manifold, always a concern. Cross thread them more than once, or go to tight and crack the stock t/b mount and your screwed.
Ray Dixon
Old 08-08-2007, 08:49 PM   #9
drjkel
Fan#: 34025
"The screws into the plastic manifold, always a concern. Cross thread them more than once, or go to tight and crack the stock t/b mount and your screwed." - I see you have lived a long time, sir.
drjkel is offline
Old 08-08-2007, 08:51 PM   #10
Fan#: 454
What I Drive: A Car
Please. don't remind me :)
Ray Dixon
Similar Threads
Cleaning the throttle body jmargush General Technical Chat 1 05-30-2007 11:29 AM
WANTED-65mm throttle body ><}}}}}*> AC21365 Archive 4 09-16-2004 02:03 PM
Throttle Bodies Sonicbluezx3 ZETEC Performance (2000-2004) 3 07-11-2004 08:47 PM
College Bodies...or Throttle Bodies.... mconant ZETEC Performance (2000-2004) 20 09-24-2003 10:05 AM
BBK Vs. FC Throttle Bodies silverfoci ZETEC Performance (2000-2004) 9 09-17-2003 11:51 PM
