HOW-TO: build your own O2 cheater - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2014, 07:01 PM   #111
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,394, Level 75
Points: 13,394, Level: 75 Points: 13,394, Level: 75 Points: 13,394, Level: 75
Level Up 36% Completed
Forum Activity 99%
http://www.focusfanatics.com/forum/showthread.php?t=161467
This is a link to the Duratec "cheater" fix sticky. Same trick mentioned by ferret15.
Don't know if the Zetec electronic "cheater" from that thread has been made to work on a Duratec. Def. wasn't written for a heater code cheater.
Which O2 you're working on wasn't mentioned.
Do you have an O2 mounted further up the header? First O2 is the one that would give a "lean" code.
Is this a new install? or have you been running it a while.
Lots we can't guess from the initial post, tryin' to read between the lines from the symptoms mentioned.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-03-2014, 09:30 PM   #112
seraniko
seraniko's Avatar
Fan#: 121529
What I Drive: svtf svtf civic tacoma valkyrie
Points 261, Level 5
Points: 261, Level: 5 Points: 261, Level: 5 Points: 261, Level: 5
Level Up 22% Completed
Forum Activity 2%
FF Reputation: 1 seraniko Good Standing Member
Did the spark plug fouler cheater this weekend on sensor 2 but the cel lighted up after a few miles...now what? Just had anew sensor 5k ago? Bad cat?
seraniko is offline
Old 02-03-2014, 09:43 PM   #113
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Originally Posted by flatgreyfofo View Post
So I did this because my heater circuit for my o2 sensor was bad, it cleared that code but now I have a code for the car running lean, p2195. Is my resistor too big? I checked the fuse and the fuse for the o2 runs 12 volts on one side, 8 volts on the other, I tested wither the fuse out.
First off. whatever you're trying to cobble together, is wrong.
Stop.
The 'cheater' it to fool the ECU into thinking the second O2 sensor is reading normal.
It has nothing to do with the heater circuit.
Stop trying to do the 'hack' on the first O2 sensor.
If the fuse is good, there's power to the fuse and continuity from the fuse to the connector, then the sensor is dead. Replace it with anything but Bosch.
Again, stop dicking with fooling the ECU and fix it correct.
iminhell is offline
Old 02-04-2014, 12:20 PM   #114
flatgreyfofo
Fan#: 139545
What I Drive: 2006 Grey zx3
FF Reputation: 1 flatgreyfofo Good Standing Member
Yeah the fuse has power, and none of the wires are frayed. Guess I'll have to break down and get a new sensor.
flatgreyfofo is offline
Old 02-04-2014, 12:24 PM   #115
flatgreyfofo
Fan#: 139545
I've been running the header for almost a year. The sensor went bad two or three days after I got the tune to remove the cel related to the sensors from the old header. Drove it about a week with the header without a tune.
Old 02-04-2014, 09:47 PM   #116
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
New Sensor & use the tune sounds like the best fix.
"Rubber Side Down"
Old 02-04-2014, 09:52 PM   #117
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Just what CEL is the first question.
Why you did the "cheater" would be another.
What brand Sensor could help as well, seen poor life from some from reports in the Forum.
Luck
"Rubber Side Down"
Old 02-11-2014, 12:49 AM   #118
seraniko
seraniko's Avatar
Fan#: 121529
Points 261, Level 5
Forum Activity 2%
Oem (motocraft) 2nd sensor failed in 3 mo or 5k. Installed bosch with 1 yr warranty from autzone. 1st sensor was also bosch and so far so good after 5k.
seraniko is offline
Old 04-27-2014, 10:39 PM   #119
stable_46
Fan#: 142281
What I Drive: 2002 Black ZX3 SVT
Points 196, Level 3
Points: 196, Level: 3 Points: 196, Level: 3 Points: 196, Level: 3
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 2%
FF Reputation: 1 stable_46 Good Standing Member
Used it today...really appreciate your docu post!
stable_46 is offline
Similar Threads
how to build a rally focus loverpig ZETEC Performance (2000-2004) 21 11-03-2008 08:52 AM
will o2 cheater help me pass emmissions chris_watkins87 General Technical Chat 10 08-13-2007 06:55 PM
FS/FT: Down Pipe & O2 Cheater SuperFlea Archive 8 02-15-2006 07:00 PM
how to orp cheater o2 shaunq SVT Performance (2002-2004) 11 05-05-2005 10:19 AM
o2 sensors + o2 cheater y2kpedo ZETEC Performance (2000-2004) 2 04-18-2005 12:08 PM
