no harmonic dampener? - Page 8 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 03-06-2008, 11:34 PM   #71
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by Pistonbroke View Post
Uhh, balance shafts aren't used for "vibration control."
Uhh, that's the sole purpose of balance shafts...to cancel out vibrations
I have little one cyl. R.C. airplane engines and they don't use it...
Yeah...because a RC airplane engine is exactly the same as a car engine...and I'm sure disassembling a RC airplane engine is equally as difficult and time-consuming as taking even a relatively simple four-cylinder apart to replace internal parts. Based on that assinine analogy, I'm going to remove my fuel injectors and the ECU, as well as the alternator and oil filter because my lawnmower's single-cylinder engine doesn't have them either, which means they aren't necessary
SkaAddict is offline
Old 03-06-2008, 11:49 PM   #72
Pistonbroke
Pistonbroke's Avatar
Fan#: 42552
What I Drive: Black 2000 ZX3 mtx
FF Reputation: 1 Pistonbroke Good Standing Member
You're right about the balance shafts.
-There is no water holier, than the sweat off a man's brow.-
Pistonbroke is offline
Old 03-06-2008, 11:55 PM   #73
SkaAddict
Fan#: 1690
Read: http://en.wikipedia.org/wiki/Balance_shaft
...a balance shaft is an eccentric weighted shaft which offsets vibrations in engine designs that are not inherently balanced
Balance shafts cancel out vibrations caused by an engine being unbalanced. Almost all I4s are imbalanced, no matter how hard you try you cannot build a perfectly balanced I4. Which is why the Zetec has dampening material on its stock idler pulley - to give the vibrations a way out of the engine without going through the main bearings or other sensitive internal parts.
Old 03-07-2008, 12:02 AM   #74
Pistonbroke
Fan#: 42552
Ya, I thought balance shafts were there to help balance. I learned something new today.
Old 03-07-2008, 08:02 AM   #75
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Some of you guys crack me up!
All this talk about balancing and no one word said about Harmonics , why is this debate allways taken into left field about Balance and not much if anything said about what it balances
It is a HARMONIC balancer and nothing to do with how it balances the engine
The HARMONIC balancer is there to help take out the HARMONICS the engine makes from the firing on the rotating assy as well as the HARMONICS the accesories try to take into the engine a balance shaft help this some as well
Ford could of saved ?? guessing $1.50 to 3.00 by not putting that little piece of rubber in the balacer and there was what ? roughly 25 million Foci built , You do the math, It wasent put there for looks
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-07-2008, 11:55 AM   #76
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: 13 stang
FF Reputation: 90 goinloco1 Excellent Standing Member
Originally Posted by killer ZETEC View Post
so like i said above you, why not make a stock size pulley out of aluminum that has the rubber bushing? the lighter weight will let it rev a bit faster. but the accessories wont be slowed down. not to mention its easier to find belts and parts if something happens
aluminum has totally different expansion and stress characteristic properties than does steel.
creating a harmonic balancer out of aluminum would subject it to stresses the metal cant withstand.
goinloco1 is offline
Old 03-07-2008, 10:14 PM   #77
Pistonbroke
Fan#: 42552
There is much to learn about engine harmonics, balance, vibration etc. It's pretty deep engineering. It's one of the "boring" things about engines.
Old 03-07-2008, 10:23 PM   #78
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
haha that depends who you talk to, my dynamics prof gets pretty animated about that stuff LOL
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-08-2008, 03:29 PM   #79
Pistonbroke
Fan#: 42552
What engine do you guys think is the easiest to balance or the most naturally balanced? What configuration and number of cylinders?
Old 03-10-2008, 07:42 PM   #80
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
You know what, all this theorizing you guys are doing would be great if the resonate frequencies would flow in one direction, towards the crank pulley/"dampener". Sadly they don't. As with any wave, it will radiate equally in both directions, reach an endpoint and reverse direction at a lesser amplitude.
So, what does this rubber O-ring in the stock pulley do? Like I said, it may dampen the accessories from the crank, that is it.
If you don't believe me, why isn't there some type of dampener on the flywheel side? The harmonics of the transmission can go right through the clutch and to the crank, or vise versa.
iminhell is offline
Similar Threads
UDP's rockthezx3 SVT Performance (2002-2004) 24 04-04-2007 01:31 PM
UDP Vote-Worth it or Worthless? TainOE ZETEC Performance (2000-2004) 65 01-13-2006 04:44 PM
UDP with Harmonic balancer QuickSilverSVT SVT Performance (2002-2004) 7 02-17-2005 04:59 PM
UDP with harmonic balancer preston77 SVT Performance (2002-2004) 28 01-07-2005 08:51 AM
underdrive pulley, dampener? whetman ZETEC Performance (2000-2004) 5 07-22-2004 09:12 AM
