Air in power steering line, How to flush/bleed it? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-01-2007, 09:50 PM   #1
DFv2
WWTPD?
DFv2's Avatar
Fan#: 42684
What I Drive: 2008 Lightning Red STi
FF Reputation: 31 DFv2 Great Standing Member
Buy-Sell-Trade Rating: (12)
As per my stupid mistake in this thread:http://www.focusfanatics.com/forum/showthread.php?t=129879
I lost all the power steering fluid in my system. I replaced the hardline I cut, and bolted everything back up nice and snug. Now the problem.
I filled the reservoir with fresh fluid, and started the car. The car seems to suck up all the fluid in the reservoir when running, and then returns the fluid to the reservoir when stopped. Im assuming the air in the line compresses when on.
ANYWAYS if you read all that, thanks. If not, heres the question. How can I BLEED the PS line to get air out? Has anyone done this before?
The only thing I can think of is to loosen the hardline fitting on the rack while having someone keep the reservoir full until it runs through. Any suggestions?
DFv2 is offline
Old 08-01-2007, 10:10 PM   #2
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
IIRC, to bleed the PS rack you need to jack the front end of the car up, start the engine and then turn the wheel to just before the stop and hold it for a minute, and then repeat in the opposite direction until the pump quiets down (meaning the air in the rack has been worked out of the system.) I think there's a how-to thread about it somewhere on here...
SkaAddict is offline
Old 08-01-2007, 11:21 PM   #3
DFv2
WWTPD?
DFv2's Avatar
Fan#: 42684
Update, did what you said and it worked. Damn that was easy, I was getting ready to start unbolting shit. Thanks!
DFv2 is offline
Old 08-02-2007, 01:54 AM   #4
Toolman00
Toolman00's Avatar
Fan#: 2744
What I Drive: 2000 Ford Expedition XLT 4x4
FF Reputation: 3 Toolman00 Good Standing Member
I bet the guy in your avatar doesn't even need a wrench!
Give the toughest job to the laziest man and he'll find the easiest way to get it done.
Toolman00 is offline
Old 03-09-2012, 04:21 PM   #5
fordcrazi
Fan#: 86801
What I Drive: 2003 white Focus
FF Reputation: 1 fordcrazi Good Standing Member
i tryied this and it still wont make my power steering stop whining
fordcrazi is offline
Old 03-10-2012, 11:00 AM   #6
daidie
daidie's Avatar
Fan#: 70867
What I Drive: 2003 maroon red 3 dr hatchback(zx3)
FF Reputation: 7 daidie Good Standing Member
just turn the wheel full lock one way to full lock the other a few times. just keep an eye on the pas fluid in the reservoir. no jacking required.
red focus zx3, stainless from cat back, the big 3, k&n, anti carjack mod, in dash dvd with jbl sub and custom 5x7's, ghia interior light mod.
have you repped someone helpful today
daidie is offline
Old 03-10-2012, 12:09 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,329, Level 75
Points: 13,329, Level: 75 Points: 13,329, Level: 75 Points: 13,329, Level: 75
Level Up 20% Completed
Forum Activity 99%
While jacking isn't REQUIRED, it makes life easier & reduces wear on the tires etc..
Since you have to turn the steering back & forth quite a few times to get most of the air out....
I just had to do this TWICE on a Chevy Monte Carlo with a damaged cooler line, once for the initial "emergency" repair & again when I replaced the damaged cooler assembly for a friend... It wasn't COMPLETELY bled till after a good test drive as well.... THAT got the last bubbles out of the system, though it was close to OK before I drove it..
Patience & a LOT more wheel twisting than you expected to need to do is the key, when it doesn't work right away it'll worry you a bit - just give it more time to circulate. The system doesn't work well at all on air, and it takes a while to get it all out...
Luck!
sailor is online now
Old 03-20-2012, 03:11 AM   #8
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
A tip. Sometimes the air is fixed finely with the fluid itself, especially if you let it run empty for a bit. Purge the lines left/right to lock as said then let car sit 10-15 minutes for fluid in reservoir to de-aerate. You may have to do it a couple of times. Later on the noise miraculously has disappeared.
amc49 is offline
Old 10-06-2012, 05:25 PM   #9
frednumber15
frednumber15's Avatar
Fan#: 83585
What I Drive: 2003 2dr ZX3
Points 1,671, Level 23
Points: 1,671, Level: 23 Points: 1,671, Level: 23 Points: 1,671, Level: 23
Level Up 72% Completed
FF Reputation: 5 frednumber15 Good Standing Member
You need to watch the level in the res as you run it and turn the wheel...mine only stopped foaming after I filled the res almost to the top and turned it back and forth...also let it sit idling turned all the way left and right. It was picking up and recirculating foam.
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s
...and I am unanimous in that position.
frednumber15 is offline
Old 10-08-2012, 05:21 AM   #10
amc49
Fan#: 96610
Forum Activity 40%
You can damage parts by leaving the steering at full lock left or right for a long period.
It's GOING TO recirculate foam, motion tends to trap air. The only way to stop it is stop engine and let foam come out in reservoir, you have to repeat since foam in the rack cannot get out until it's in the reservoir also.
Done correctly you can install fluid with almost no aeration at all. The system is almost instantly self bleeding, the trick is to get the new fluid in there quick enough so that the pump can never run out and pull air. Once pump starts whining say when you are uncapping the second bottle of fluid to put in you have already screwed up.
amc49 is offline
Similar Threads
Power Steering Cutoff focusedintentions General Technical Chat 10 10-10-2006 03:09 PM
Power Steering Pump-Is it hard? ouikikazz General Technical Chat 4 02-28-2006 09:01 PM
Power steering leak Springbuck General Technical Chat 5 01-20-2006 08:46 PM
Power steering problem on an 04? Toolman00 SVT Performance (2002-2004) 6 11-27-2005 11:02 PM
WTB: Power steering line bartlomiej Archive 0 06-10-2004 05:35 AM
