Spring rate equivalence - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 08-01-2007, 03:38 PM   #1
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Springs come rated in pounds per inch or in kilograms per milimeter. In essence, this is the amount of weight needed to compress the spring one inch or one mm. Naturally the more weight it takes the stiffer the spring is.
To convert a spring that is measured in kilograms per milimeter, simply mutiply by 55.99745 to get lbs per inch.
Example a spring is rated at 2.2 kg/mm
2.2 x 55.99745 = 123.194 lbs/in
This may help should you purchase springs from overseas where most measurements are in kg/mm.
Geezer is offline
Similar Threads
SVTF Stock Spring Rate? 2004SVTAutoXer Brakes, Suspension & Body Chassis 2 12-25-2005 08:06 PM
what spring rate? hurleythewurley Brakes, Suspension & Body Chassis 7 08-24-2005 12:16 AM
Fk highsport coilover SPRING RATE? CEM_GT Brakes, Suspension & Body Chassis 0 08-10-2005 05:26 AM
Rear spring and shock hell!! Adkhunter Brakes, Suspension & Body Chassis 3 07-20-2005 12:54 AM
Testing Spring Rate Foci_Fosho Brakes, Suspension & Body Chassis 3 02-15-2005 09:32 PM
