Wont start after replacing clutch master cylinder - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-29-2007, 10:46 AM   #1
sgatepunk
Fan#: 27470
What I Drive: '02 ZX3
FF Reputation: 1 sgatepunk Good Standing Member
Heres the scenario: A week ago a "pin" on my clutch pedal broke its weld, and since I did not realize what had actually happened at the moment (I was driving the vehicle after all). Somehow I managed to break the little plastic piston rod on the clutch master cylinder. After replacing the cluctch master cylinder my car wont start, I have power, but the car does nothing, it wont turn over, nothing.
I had the battery completely disconnected for a few hours while replacing the clutch master cylinder, does anyone think that has anything to do with anything? If so, do I have to take the car into the dealership to have it "reprogrammed" or is there some way to do a factory reset?
I have already tried the trick where you disconnect the neg. battery terminal for an hour, and that didn't change anything.
sgatepunk is offline
Old 07-29-2007, 10:57 AM   #2
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
did u disconnect any wiring harness just to get them out of the way??? like the MAF or TPS. doing the master cylinder (i dont believe) would effect the ignition. just try to re-check all the connectors
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Old 07-29-2007, 12:00 PM   #3
sgatepunk
Fan#: 27470
I will check again when I get home.
Old 07-29-2007, 12:02 PM   #4
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Sounds like it could be the clutch safety switch.
Egz is offline
Old 07-29-2007, 12:29 PM   #5
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Yeah... I'll bet it is that.
Often wrong but never in doubt.
Blurvfocus is offline
Old 07-29-2007, 12:42 PM   #6
sgatepunk
Fan#: 27470
I am assuming thats the little plastic switch down there that gets pushed in when the clutch is pressed. I am really going to kick myself if I forgot to plug that back in. Thanks for the knowledge, I will check into it when I get home.
Old 07-29-2007, 02:41 PM   #7
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
^^^ Yeah, that's it!
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 07-30-2007, 07:13 AM   #8
sgatepunk
Fan#: 27470
Checked it out when I got home, and it was the clutch safety switch. Looks like I bent the mount a little when I was working down there and it wasnt being pushed all of the way in now. If I actually press the button all of the way in, the car starts fine. Thanks a million guys!
Old 07-30-2007, 10:25 AM   #9
nomad327
Fan#: 19440
What I Drive: red 2002 svt focus
FF Reputation: 13 nomad327 Great Standing Member
there's a spec in the manual for the length of the pushrod on the green, grey and black switches(all three have a different extended length). I don't have it here, but the purpose for giving you a length spec is that you have to forcibly pull the plunger out of the three switches before reinstallation, and it takes a bit more effort than you would normally feel comfortable with applying to get them out that 1/4" or so extra. (red for clutch top of travel is not adjustable), You then assemble the switches in overextended condition, and the first time you push on the pedal, they auto adjust. Getting them just so was a bit scary at first, and took more time than most of the rest of the job until I was satisfied with them.
nomad327 is offline
Similar Threads
clutch slave cylinder line... jrc0210 General Technical Chat 0 12-18-2006 08:11 PM
There went the clutch...WTF BONOMAN5064 SVT Performance (2002-2004) 51 12-17-2006 12:21 PM
clutch master cylinder leaking? Moe-van1 General Technical Chat 6 03-15-2006 07:10 PM
How much for a clutch master cyl. ? sleepyboy ZETEC Performance (2000-2004) 3 01-23-2006 03:19 AM
clutch master cylinder part number? bartlomiej ZETEC Performance (2000-2004) 0 07-02-2004 04:20 AM
