How To: Ram Air Duct w/ Pipercross style add on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2007, 06:57 PM   #1
c9ollie
Fan#: 45701
What I Drive: 2002 Infa Red SVT
FF Reputation: 5 c9ollie Good Standing Member
Time
1-2 hours depending on experience and acess to tools
Materials and Tools
Ram Air Duct
1. sheet steel or aluminum
2. metal shears, sawzall, cut off wheel... etc
3. vice
4. 4 very small nuts and bolts
5. L bracket
6. silicon bathroom caulk
7. torch *opional*
8. bench grinder or file
1. 3 feet of 2.5-3" tubing
2. funnel or velocity stack
3. 3" pipe clamp
4. drill
5. matching hole saw (3" pipe use a 3" hole saw)
6. small peice of sheet metal
Plans
Procedure
1. measure out and draw the given dimensions onto a peice of cardbord. these 2 peices will become your templates.
2. go to the car and remove the radiator cover. undo the screws then pop the plugs out and it the cover comes off.
3. test fit the carboard peices and mark out the places for the holes and where to bend the metal. the line on my plans that doesnt have a measurement is the line i used to judge the bend.
4. trace your templates onto your sheet metal. make sure to take note the the postion of the holes and the bend line
5. when cutting the metal it is always safer to cut a little bit bigger than your actual dimensions. you can always grind it down.
6. now clamp the cut out peice into the vice at the fold line. this is where a torch might come in handy if you are using a beefy stock of metal. but begin to bend the peice. bend it a little then check it on the car just keep going back and forth. this is also a good time to grind and perfect the fit of the duct.
7. the little triangular peice is very tricky because it is cruved in 2 dimensions. so its curved and twisted. the only real way to get this is by trial and error so be prepaired to spend alot of time going back and forth from the car to the vice.
8. at this point you should have something that resembles this but without the
9. to make the bracket i just took a L bracket and bend it to the same angle i wanted the triangular peice. drill some holes and bold them together.
10. run a beed of caulk where the 2 plates meet
11. put the now completed duct into the correct location. now go get the radiator cover and try to put it on. draw a ling on the cover where it needs to be cut, like i said before its better to be a little bigger. so cut it bigger then you can shape it perfectly
12. put everyhitng back together and YOUR DONE!
1. remove the airbow and cut the resonator sleeve thingy off. once its cut off drill a hole with the diameter of the pipe you are using.
2. cut a small peice of metal that will fint inside the airbox that will completly cover the hole. now trace the hole you drill in the airbox onto the metal
3. drill the metal out and test fit.
4. run the pipeing down to the grill area
5. install your velocity stack of choice to the end using a hose clamp
6. ziptie to the grill
7. then seal the metal plate with more silicone caulk.
8. YOUR DONE
2002 SVT Focus
ITG filter - RT offroad pipe - 25mm progressive swaybar - CFM adjustable sts - CFM dogbone w/ race bushings - Toyo proxes 4s
c9ollie is offline
Old 07-28-2007, 07:04 PM   #2
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
i have the bottom setup with it piped to the volant box hole. I love it. I do need a cone on the front though.....I should go but a funnel.....
HaveBlue83 is offline
Old 11-12-2007, 02:58 PM   #3
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
instead of chopping up your air deflector, add this!
scrammer is offline
Old 11-12-2007, 03:35 PM   #4
Head
Fan#: 51156
What I Drive: 04 SVT Focus & 06 Scion tC
FF Reputation: 1 Head Good Standing Member
can we get that here?
Head is offline
Old 11-12-2007, 03:39 PM   #5
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
Nice little write up. Finished piece looks cool to. I just took my OE scoop, mounted it on the bottom of the radiator and ran ducting to the bottom of the air box.
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 11-14-2007, 09:56 AM   #6
scrammer
scrammer's Avatar
Fan#: 26570
the site to get the piece is printed on the picture.
scrammer is offline
Old 11-14-2007, 12:08 PM   #7
Head
Fan#: 51156
I poked around there and could not find it plus it is in the UK. I was curios if there a US supplier.
thanks
Head is offline
Old 11-14-2007, 02:49 PM   #8
scrammer
scrammer's Avatar
Fan#: 26570
CLICKY
they ship to the US
scrammer is offline
Old 11-14-2007, 03:18 PM   #9
yoda9899
Fan#: 51409
What I Drive: 2002 SVT Focus CD Silver
FF Reputation: 1 yoda9899 Good Standing Member
if you buy a cai does that destroy the point of doing this or can it still help?
yoda9899 is offline
Old 11-14-2007, 03:50 PM   #10
scrammer
scrammer's Avatar
Fan#: 26570
this is for stock boxes. if you buy an aftermarket intake, there is no point in this mod.
UNLESS
you buy a SRI (short ram intake) this keeps the filter in its current location but it includes a conical filter and a tube to replace the intake-maf section.
then this mod will allow more fresh air to reach the SRI than from stock if you were to leave the snorkel in place.
scrammer is offline
Similar Threads
Basic Bolt Ons: Intakes And Induction focaltech ZETEC Performance (2000-2004) 108 08-01-2014 07:39 PM
Ram air hood RED_187 MK1 Focus 16 06-28-2007 03:45 PM
For Sale: used AEM short ram cold air kit quickfocus Archive 0 03-15-2005 01:44 PM
Pipercross Induction Systems –Euro focus Import- focaltech Ford Focus & General Car Chat 36 06-26-2004 04:26 PM
Ram air awebb Ford Focus & General Car Chat 2 09-13-2003 12:36 AM
