Quick writeup on my LC-1 wideband install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-24-2007, 03:22 PM   #1
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
I finally got around to finishing up this install. I don't have much free time, and tend to make things more complicated then they should be. I fabricated a patch panel so I can tap directly into the LC-1 from my laptop without any dangling cables, as well as allowing me to recalibrate it. That took a good portion of time, and is 90% what I pictured.
I just finished installing the sensor. I had a bung welded onto my Cosworth flex pipe, which placed the sensor just aft of the front cross member, which is a good thing, since you need to remove the sensor from the exhaust when you recalibrate it. It also puts it right next to the shifter, so you dont' have to run cables every where.
Yes, you see 4 ground wires. I tried to separate the grounds as much as possible to reduce any error coming over the signal wire. Had a small snafu wiring it, and found my mistake, but I wasn't sure if I fubar'd the unit yet.
I was going nuts trying to figure out the problem. I was getting 4 volts at the plug (which I programmed it to do), but SCT was recording 0.9. Dug around, found some bad solder joints in the cable I made, but that didn't fix it. Dug around on SCT's website, and found out there is a glitch in the new Xcal2 units (the backlit models), and I had to do a multiplier to fix it. Tested it out again, and got 4 volts on my computer.
Now I can do some datalogging, and fine tune the program. Then I should be on the dyno with numbers.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 07-24-2007, 05:35 PM   #2
Tony D
Fan#: 7018
What I Drive: 01 ZX3 Yellow/03 SVT Red
FF Reputation: 6 Tony D Good Standing Member
Buy-Sell-Trade Rating: (17)
Egz,
Nice work and write-up!
Tony D
www.newedgeperformance.com. Your one stop Focus parts headquarters!
Tony D is offline
Old 07-24-2007, 09:59 PM   #3
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
thats cool egz... did you drill that hole in the tub where the shifter is to pass those cables or is that an unseen plug?
and sinse your messing around with the sct and excal...
i have the 93oct tune from FS cossie cai, f2header and 2.24inch exhaust... i think i saw you post one time about changing the timing alittle on the excal2... what would you recommend? thanks!
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 07-24-2007, 10:20 PM   #4
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
I drilled that hole there. Actually its 2 holes, since its double layered.
And I haven't messed with any timing with the Xcal2 yet. So I don't have any suggestions.
Egz is offline
Old 08-30-2007, 08:54 AM   #5
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,974, Level 74
Points: 12,974, Level: 74 Points: 12,974, Level: 74 Points: 12,974, Level: 74
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Excellent pics! I'm about to install the LC-1 unit on mine tomorrow and will probably follow your example.
Are you happy with the ground location?
That seems to be a touchy issue with the widebands and where people seem to mess up.
Are you currently using it and how is it working out?
Did you perform the open-air calibration?
Also what source did you use for your switched 12v power? Pic? Color wire?
Did you add an inline fuse?
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 08-30-2007, 10:53 AM   #6
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
I was really surprised with the results with the ground offsets. I had almost nothing. I separated almost all of the grounds so they all had their own, which must have helped.
I haven't datalogged it much lately, but when it was on a dyno, the results were spot on. In fact, the dyno's wideband was actually slipping a little; each following run it read a couple of points richer, while looking at the datalog, it stayed really consistant.
An open air calibration was done. Kind of a pain with the heat sheild, and that dang plug into the control unit. Unpluging the sensor (so I can unscrew it) is always hard for me for some reason.
Power comes from a add-a-circuit fuse. I forget which fuse I used; I probed around until I found one that was switched. I'll check when I get home.
Egz is offline
Old 08-30-2007, 01:20 PM   #7
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Thanks! I plan on starting tonight and tearing stuff apart.
By morning I should be ready to drill/splice/mount etc.
Old 08-30-2007, 06:31 PM   #8
honhon
Fan#: 24778
hey egz... the holes you drilled have they gotten any surface rust on them yet?
honhon is offline
Old 08-30-2007, 07:19 PM   #9
strung
PIMP'N AINT EASY
strung's Avatar
Fan#: 44516
What I Drive: 06 RED ST/SAP1
FF Reputation: 34 strung Great Standing Member
ok....someones gotta play the cluless dum ass in this thread.....what is a LC-1 wideband?
ST CREW #62
put your motor where your mouth is.
strung is offline
Old 08-30-2007, 07:50 PM   #10
honhon
Fan#: 24778
high tech A/F ratio system to data log etc...
http://www.innovatemotorsports.com/products/lc1.php
honhon is offline
Similar Threads
need quick help! fishman1324 MK1 Interior Mods & Upgrades 3 03-24-2006 11:35 PM
Transmission noise need help quick! saagz87 ZETEC Performance (2000-2004) 6 03-05-2006 11:46 AM
sct quick tune software rankinc22 SVT Performance (2002-2004) 4 01-01-2005 03:04 PM
2002 Focus Owners Manual & Quick Guide carguymb Archive 1 08-27-2004 04:39 PM
