sporadic's Turbo Duratec build thread - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2007, 10:52 PM   #61
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,168, Level 91
Points: 21,168, Level: 91 Points: 21,168, Level: 91 Points: 21,168, Level: 91
Level Up 64% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
4k sounds about right, lol
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 08-06-2007, 02:51 AM   #62
DareDevil03
Across the Pond
DareDevil03's Avatar
Fan#: 13938
What I Drive: 2001 Nissan Primera (UK Spec)
Points 5,254, Level 46
Points: 5,254, Level: 46 Points: 5,254, Level: 46 Points: 5,254, Level: 46
Level Up 52% Completed
FF Reputation: 1 DareDevil03 Good Standing Member
Buy-Sell-Trade Rating: (18)
As far as your wheel hop issue, try getting the motor mounts for you car. Helps out a lot on the zetecs.
Full boost should be achieved at around 3500-4000 RPM. A smaller turbo would yield faster boost but less HP.
Proudly Serving
Ask me about UK parts.
DareDevil03 is offline
Old 08-07-2007, 11:50 AM   #63
Ted B
Fan#: 49312
What I Drive: 2003 EVO 8, 500whp / 1986 Must SVO
FF Reputation: 1 Ted B Good Standing Member
Originally Posted by sporadic View Post
I hit just under 10psi (9.5 I'm assuming) in gears 1-3!
It takes up to 4k rpm or so to get there, so I'm still scratching my head about that.
I figured I'd hit full boost much lower, perhaps as low as 2k rpm.
Maybe the Tbird guys will chime in here.
Taking until ~4k rpm to get 10psi indicates something isn't right. This would be fine for a GT3071R, but not the tiny T-bird IHI.
I suspect you have a leak, possibly at the WG. If so, you're losing a great deal of turbo efficiency.
2003 Mitsu EVO 8 - 500whp
1986 Mustang SVO - Work in progress . . .
Ted B is offline
Old 08-07-2007, 12:02 PM   #64
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,991, Level 74
Points: 12,991, Level: 74 Points: 12,991, Level: 74 Points: 12,991, Level: 74
Level Up 36% Completed
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I'll be performing a pressure test on my IC piping soon, and I'm also looking for a new wastegate actuator.
It takes longer than 4k to hit full boost.. more like 6k, so I know there's an issue.
I'll keep everybody updated on what I find.
I'm also looking into a wideband, probalby the Innovate LC-1.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 08-07-2007, 12:05 PM   #65
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
lol. yeah 6k is to high. i shift at 6
Turbo Turtle Garage
Old 08-07-2007, 12:18 PM   #66
Ted B
Fan#: 49312
The Innovate LC-1 is an excellent, accurate wideband O2. It's what I use, all I use.
The easiest means of pressure testing the intake system is right at the mouth of the turbo, using an appropriately sized silicone coupler and PVC pipe cap, with a quick connect fitting screwed into the cap. With a bit of compressed air and a slow twist of the regulator, it's easy to hear any leaks whistling.
If you're losing that much pressure, you'll most definitely notice a difference when you get it resolved. With that turbo, you should be getting full boost by ~3k rpm.
Ted B is offline
Old 08-07-2007, 12:56 PM   #67
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
here is mine
Turbo Turtle Garage
Old 08-07-2007, 01:00 PM   #68
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Originally Posted by tls_bmx View Post
here is mine
Nice, thanks for the pic.
A buddy of mine with an EVO has done this before, so I'm going to bum his and see if it will fit my turbo inlet elbow.
Old 08-07-2007, 01:15 PM   #69
Ted B
Fan#: 49312
A setup like this is a bit easier to handle because it requires no hands. It allows you to slowly raise the pressure from zero to full without needing to keep a hand pressed onto a schrader valve.
Ted B is offline
Old 08-07-2007, 02:42 PM   #70
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
an electric tire pump that hooks on works with out hands lol
Turbo Turtle Garage
Similar Threads
Custom turbo build jamfrank General Forced Induction 17 06-02-2008 12:07 PM
Duratec oil sending unit thread size sporadic General Forced Induction 1 07-24-2007 12:36 PM
duratec turbo kit for 2k????? for real!!! brandon0133 General Forced Induction 4 04-30-2007 01:35 AM
500hp Zetec Turbo Build, 180mph target. ukfoc General Forced Induction 30 10-08-2004 09:39 PM
