sporadic's Turbo Duratec build thread - Page 24 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-29-2009, 06:52 PM   #231
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,994, Level 91
Points: 20,994, Level: 91 Points: 20,994, Level: 91 Points: 20,994, Level: 91
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 9%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
water would not have hurt your engine unless it is enough to hydro-lock it. small amount of water will be instantly evaporated. there will not be any water in the intake manifold because water under a vacuum will instantly boil away.
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 06-30-2009, 12:38 AM   #232
bmylez
bmylez's Avatar
Fan#: 64637
What I Drive: 2003 350Z Track
FF Reputation: 23 bmylez Great Standing Member
How are you so well-versed in the ways of science? Heh...
1992 Eagle Talon TSi - sold (POS)
2002 Mustang GT - sold
2002 SVTF - sold
2008.5 Mazdaspeed3 GT - cursed
2003 350Z Track - basically stock, and it runs
bmylez is offline
Old 06-30-2009, 12:47 AM   #233
focusboy5
focusboy5's Avatar
Fan#: 50002
What I Drive: Four Wheels
Points 8,173, Level 61
Points: 8,173, Level: 61 Points: 8,173, Level: 61 Points: 8,173, Level: 61
Level Up 8% Completed
FF Reputation: 31 focusboy5 Great Standing Member
Buy-Sell-Trade Rating: (13)
Is it still a d20?
focusboy5 is offline
Old 06-30-2009, 01:17 AM   #234
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
I didn't know pressure made water boil. Interesting...
afraziaaaa is offline
Old 06-30-2009, 09:15 AM   #235
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,870, Level 74
Points: 12,870, Level: 74 Points: 12,870, Level: 74 Points: 12,870, Level: 74
Level Up 5% Completed
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by focusboy5 View Post
Is it still a d20?
Yep still a D20. See post #222.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 06-30-2009, 10:29 AM   #236
bmylez
bmylez's Avatar
Fan#: 64637
Yep, it's why water boils at 161* F when you're on top of Mt. Everest. Less pressure means lower boiling point. Why your blood boils in a vacuum...like out in space. So in Space Odyssey: 2000, when the guy gets the plug on his suit pulled, it wouldn't have been a pretty scene if they showed what really would have happened.
2002 SVTF - sold
bmylez is offline
Old 07-01-2009, 09:00 PM   #237
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
pressure doesnt make water boil. lack of pressure makes water boil. like under a vacuum.. when you are in boost the water has a higher boiler point than it other wise would... but the temp in the combustion chamber is still much higher... unless there is enough water to hydro-lock the engine then it wont hurt.
Turbo Turtle Garage
Old 07-01-2009, 11:00 PM   #238
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Update. The engine is in the car and axles in.
Most everything is hooked up but still have at least another day(evening) of small stuff.
I'll be running with the wastegate partly open to stay out of boost for a while to break in the engine a bit more.
A couple months ago I port-matched the turbine inlet to match the T3 port.
While the IHI turbo has a T3 bolt pattern, the actual inlet isn't matched the the square pattern.
I used a die grinder with carbide burrs to do the porting:
This time while I had the turbo off I noticed it cracking in a typical point where the IHI cracks, so I took some time to repair it.
I ground down the crack, welded it, ground it, repeat until it looked how I wanted and was stronger:
Old 07-04-2009, 08:24 PM   #239
gemini47
Fan#: 66625
What I Drive: Duratec Focus
FF Reputation: 3 gemini47 Good Standing Member
whew long thread! i am probably going turbo too, but i think i will buy a kit since i can't make all this stuff. good job!
gemini47 is offline
Old 07-16-2009, 09:38 PM   #240
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
The new engine is in and running fine.
I had a couple minor oil leaks initially but they have been fixed.
Overall it took longer than I expected, but it always does.
I took the time to make a solid passenger side motor mount, but after only 25 miles put the stock one back on due to insane vibration.
The wastegate is adjusted so it's slightly open so it does not build more than a couple psi of boost for now. (and that's trying)
I'll run it without boost for a little while. I'm not sure how long.
Soon I'll tear down the old engine to see just what happened.
I'm expecting to find worn rings and a bad head gasket.
Similar Threads
Custom turbo build jamfrank General Forced Induction 17 06-02-2008 12:07 PM
Duratec oil sending unit thread size sporadic General Forced Induction 1 07-24-2007 12:36 PM
duratec turbo kit for 2k????? for real!!! brandon0133 General Forced Induction 4 04-30-2007 01:35 AM
500hp Zetec Turbo Build, 180mph target. ukfoc General Forced Induction 30 10-08-2004 09:39 PM
