sporadic's Turbo Duratec build thread - Page 20 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-02-2008, 01:31 AM   #191
07FocusST
07FocusST's Avatar
Fan#: 49661
What I Drive: 2007 Focus ST
FF Reputation: 2 07FocusST Good Standing Member
I also noticed on your dyno graph that the choke point of the turbo is around 5250RPM. That has me concerned since you are running a 2.0L and I have a 2.3L. Or is that because of the wastegate opening? Your A/F jumped a little at 3,000RPM... weird?
Turbo ST (Soon Again)
Boosted Crew Member #115
SAP Crew Member #17
Originally Posted by hypnoticracing View Post
foci's came without rear brakes? i guess mine is special with its drums
07FocusST is offline
Old 11-02-2008, 09:25 AM   #192
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,849, Level 73
Points: 12,849, Level: 73 Points: 12,849, Level: 73 Points: 12,849, Level: 73
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 7%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
It's pretty lean right now in general driving.. 14-15 AF and when I stomped it on the non-loaded dyno it did spike lean until the turbo spooled up.
I wouldn't typically stomp on the gas at 2K rpm in 4th gear on the street anyway.
Comparing a FS dyno chart to my own, it has really started to sink in how small this IHI turbo is and how I should have gone with a larger T3 or equivalent.
The FS turbo makes power all the way to redline where mine chokes at 5200 rpm.
If I had to do it again I wouldn't have used this IHI, but I don't regret it either.
Part of me knew it wouldn't make power much past 5500 rpm, but I didn't realize it would drop off quite so quickly afterwards.
07FocusST, with you having a 2.3 I might reconsider the IHI if I were you before you get too far into the project.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 11-02-2008, 09:51 AM   #193
kauffersZX5
kauffersZX5's Avatar
Fan#: 57100
What I Drive: 2007 infra-red ZX5
FF Reputation: 1 kauffersZX5 Good Standing Member
amazing job!!!!! someday i hope to put together something like that
Currently :MBRP catback, steeda CAI, F&R sway bars, strut brace
Coming: OBX race Header, SCT XCAL Tune, 2inch drop, Throttle body, focussport turbo
LOTH # 82
Team Duratec #182
kauffersZX5 is offline
Old 11-02-2008, 05:23 PM   #194
07FocusST
07FocusST's Avatar
Fan#: 49661
Already considering it... I might just atrt with the IHI to get the project off the groud. All I would have to do later is change the Downpipe flange and maybe the oil line fittings... Not that big of a deal. Of course change the tune too... I would rather start small and work to a bigger turbo. Just my opinion. Appreciate the info!!! You did pickup around 70WHP from the small turbo...
SAP Crew Member #17
Old 11-02-2008, 08:14 PM   #195
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
I believe the stock 2.0 dyno's around 115whp, so I picked up closer to 90whp. :)
Old 11-02-2008, 08:21 PM   #196
polarisman14
polarisman14's Avatar
Fan#: 30127
What I Drive: 2001 Liquid Grey ZX3 S2
FF Reputation: 3 polarisman14 Good Standing Member
Keep in mind if you had an electronic boost controller or something you can work out the sensitivity so that it holds boost better on the top end (if you have money to play with but still dont want to buy a manufactured kit).
--Matty--
"Unfocused1"
polarisman14 is offline
Old 11-02-2008, 10:16 PM   #197
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
The boost is holding fine. The issue is the small turbo is just blowing hot air at that high RPM and out of it's efficiency range.
Old 11-05-2008, 05:26 PM   #198
07FocusST
07FocusST's Avatar
Fan#: 49661
how quickly are you hitting full boost? I plan on sticking to 10PSI like you are, but I calculated on the RHB52 compressor map that I would hit 9PSI @ 1,000RPM under WOT... This can't be right! I also calculated that the 2.0L would hit 8-8.5PSI @ 1,000Rpm. If you could give me a rough idea of how your car builds boost thru the RPM range that would be a great reference for me. Something like this:
RPM Boost
1k - 6PSI
1.5K - 8PSI
2K - 9.5PSI
a layout like that would be great.
SAP Crew Member #17
Old 11-05-2008, 07:26 PM   #199
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Full boost is about 3.2k rpm, starting at 2.5k rpm. You can see where it hits full boost on the dyno graph and the torque really jumps.
I don't think I've every tried to go from < 1K rpm in WOT. I'm not sure why I every would either. :)
You're calculations are way off, but I won't be any help with the compressor map.
Old 11-28-2008, 05:36 AM   #200
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
THAT was a fun read man, thanks. Learning more and more on the Dtec and turbo'ing it. cool stuff.
HaveBlue83 is offline
Similar Threads
Custom turbo build jamfrank General Forced Induction 17 06-02-2008 12:07 PM
Duratec oil sending unit thread size sporadic General Forced Induction 1 07-24-2007 12:36 PM
duratec turbo kit for 2k????? for real!!! brandon0133 General Forced Induction 4 04-30-2007 01:35 AM
500hp Zetec Turbo Build, 180mph target. ukfoc General Forced Induction 30 10-08-2004 09:39 PM
