Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 07-24-2007, 09:29 AM   #11
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2007 F150 XLT
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
wow... you spent a LOT of time on this... you must got some patience. great job man
keep us updated.
nov173 is offline
Old 07-24-2007, 09:45 AM   #12
focusedaddiction
2focusedracing
focusedaddiction's Avatar
Fan#: 23787
What I Drive: 2003 sangria red 5spd. ZX3Turbo
FF Reputation: 4 focusedaddiction Good Standing Member
Buy-Sell-Trade Rating: (14)
great write up so far, I'm getting excited to start mine this fall . luckily I have a zetec though so routing the exhaust & int. cooler pipes will be a little easyer. glad your posting over here, i'm here more often then tc.com!
ya got some mad welding skill going on there too, well done.
_/\_/\_SCCA_/\_/\_SM #74_/\_/\_BRING ON THE CONES!...zetec crew #74
ZX3..underpressure
tuning by TOM
focusedaddiction is offline
Old 07-24-2007, 11:34 AM   #13
Focus_3XZ
Fan#: 35439
What I Drive: SVT
FF Reputation: 8 Focus_3XZ Good Standing Member
Buy-Sell-Trade Rating: (16)
Omg I dont even know what to say. Good luck though.
Focus_3XZ is offline
Old 07-24-2007, 12:18 PM   #14
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (24)
very nice looking project, good luck on it and keep us updated
what size maf housing did you say you were looking for? if you are looking for 2.5 you could use a ebay intake for the maf pipe. that is what i did and they are pretty cheap.
Turbo Turtle Garage
facebook.com/turboturtlefabrication
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 07-24-2007, 12:27 PM   #15
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
FF Reputation: 60 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I could fairly easily make a new, larger MAF housing, but my tuner recommended using the stock MAF housing and a Diablosport MAFia so that's what I'm doing.
I know other tuners use a larger MAF housing, but I'm doing what my tuner recommends.
2006 sonic blue zx5 GT2871r turbo.
sporadic is offline
Old 07-24-2007, 07:31 PM   #16
Turbo Turtle
Fins Up!
Fan#: 32772
yeah 2.5 is fine. the reason a 3" is used is to extend the range of the maf. but unless you plan on making a lot of power there isnt any need for it.
Turbo Turtle Garage
Old 07-24-2007, 09:48 PM   #17
sporadic
sporadic's Avatar
Fan#: 12724
Day 8
Start time: ~6:45pm
End time: ~10:15pm
Today was another short weekday.
I cleaned and painted my oil catch can.
It was originally chromed, but I personally don't like chrome and it didn't match anything under the hood and stood out like crazy.
I ground off any loose chrome and cleaned it using mineral spirits.
I painted it satin black, which shouldn't really stand out but look nice.
I mounted my MAFia to the battery tray with velcro.
Part of that is so it can be removed to adjust when necessary, and I may go to a lightweight battery later on so no need to permanently mount it to the battery tray.
I installed the 55lb injectors.
Aside from having to huff a lot of gas fumes, this was one of the easiest things I've done so far.
Two 10mm bolts hold in the fuel rail.
Each injectors has a small metal clip that easily pops off using 2 flat head screwdrivers.
That metal clip goes on the new injectors.
I also removed all the stock spark plugs and coated the threads with anti-sieze and then reinstalled them.
I don't want any suprises when I go to get my car tuned, and siezed spark plugs definitely fit that category!
I gapped the Autolite 103 plugs to .035" and set them in the passenger seat so I won't forget them when I go to get my car tuned.
Finally tonight I installed one of the -3AN reusable, swivel hose ends to my oil feed line.
I then ran a test route for the line, screwing the one mounted hose end to the oil sending unit.
This way I can get a clear idea of how much line I have to trim from the 6' section it comes in.
I'll install the other hose end after I trim of the excess.
PICS
Catch can before painting:
Catch can after painting:
Autolite copper plugs gapped at .035"
Stock injectors:
55lb vs stock injectors:
55lb injectors installed with wire adapters:
The 55lb injectors have a plug that works for the Zetec, but requires and adapter for the Duratec.
Oil feed line:
Blurry pic of the day.
Directions on how the hose ends are installed: Aeroquip reusable hose end pdf
sporadic is offline
Old 07-25-2007, 11:21 AM   #18
cayres
cayres's Avatar
Fan#: 35184
What I Drive: 03 Comp Orange EAP SVT, 06 ZX3 SES
FF Reputation: 8 cayres Good Standing Member
did you mig your manifold? And did you purge it at all with argon?
cayres is offline
Old 07-25-2007, 11:24 AM   #19
sporadic
sporadic's Avatar
Fan#: 12724
MIG, but all welds are with flux core wire. No gas.
I'm quite happy with the penetration even without gas.
There weren't any suprises. Everything is steel-steel and flows together nicely.
sporadic is offline
Old 07-25-2007, 11:35 AM   #20
dds78910
dds78910's Avatar
Fan#: 49038
What I Drive: 2004 Silver SVT Focus 5dr
FF Reputation: 1 dds78910 Good Standing Member
You only need to do that if you are welding a header made out of Stainless steel. No need to on mild steel.
Looks like a fun project, and looks good also!
dds78910 is offline
Similar Threads
Custom turbo build jamfrank General Forced Induction 17 06-02-2008 11:07 AM
Duratec oil sending unit thread size sporadic General Forced Induction 1 07-24-2007 11:36 AM
duratec turbo kit for 2k????? for real!!! brandon0133 General Forced Induction 4 04-30-2007 12:35 AM
500hp Zetec Turbo Build, 180mph target. ukfoc General Forced Induction 30 10-08-2004 08:39 PM
