#1 | ||||
HID Blowing Fuse????
Hello everyone,
My passenger side HID is blowing the fuse I've changed it twice already. First off it has a broken clip in the back so moisture gets in. A few days ago there was a flash flood in my city and I drove through some deep water to get to work. When i took the light out and opened it up I noticed the broken tab, then I tilted it up and water all over my face. Why is my light blowing the fuse when I turn them on? When I turn my lights on I hear a slight buzzing kinda sound and then it blows the fuse. Any help is appreciated guys thanks. |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
ballast or u have a power wire exposed touching the body or frame just take a saturday and take it all appart and check it out, and incase u havent taken the headlight houseing out here is a list of things u need to take off first
1.black cover over ur grill 2.grill 3.headlights |
#3 | ||||
Could be the ballast or ignitor (black box that screws onto the back of the bulb.) I bought a new set of Mach HIDs and they arrived with both ballasts shot and a bad ignitor...the ignitor on the one kept blowing a fuse every time I'd turn it on. You could try swapping the ballast/ignitor from the known good headlight and see if it works. Or remove the headlights and plug the good one into the bad one's harness and see if the fuse still blows (isolate the problem to the headlight or wiring.) In electrical troubleshooting its typically a good idea to check your wiring by substituting a known good component and see if it fixes the problem, and then narrow down the issue from there. So if you plug your good headlight into the bad one's harness and it doesn't blow the fuse then you know the problem is in the headlight, and if it does blow the fuse then there's a problem with the wiring.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Keep blowing Fuse 32 | jhowton | General Technical Chat | 11 | 11-29-2007 01:00 PM |
| My A/C fuse keeps blowing! | SVTORNG | General Technical Chat | 4 | 05-15-2007 03:43 PM |
| Electric Issues (Fuse 32, 44) | Happenedtoyou | General Technical Chat | 3 | 08-20-2005 12:24 AM |
| Arghh! keep blowing fuse # 50! | EuroZX3 | Car Audio, SYNC, MyFord Touch & Electronics | 7 | 11-16-2004 01:05 PM |
| Power locks..fuse keeps blowing | solkp | General Technical Chat | 8 | 07-21-2004 11:20 AM |
