Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 07-21-2007, 01:08 AM   #31
stivo
Hiyadoin'
stivo's Avatar
Fan#: 48389
What I Drive: 2004 Infrared SVT, EAP #1440
FF Reputation: 9 stivo Good Standing Member
Buy-Sell-Trade Rating: (6)
Did you happen to catch the Grassroot Motorsports story about the VW new beetle deisel that was tuned to make 400ft lbs of torque? Incredible! I think the combo was big injectors and a tune.... and it still got 40 mpg! I have seen those cars handle very well.
Experience and skill are a lot more important than the car for sure.
stivo is offline
Old 07-21-2007, 08:40 AM   #32
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member03OrangeSVT Excellent Standing Member
I'll bet my last dollar that the VW had alot more done to it than that...... 400wtq isnt going to be had on a otherwise stock VW engine.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 07-22-2007, 09:22 PM   #33
stivo
Hiyadoin'
stivo's Avatar
Fan#: 48389
I'll try and find the article. I have it around somewhere, but it was amazing how little he did to his car.
stivo is offline
Old 07-22-2007, 11:24 PM   #34
LazarusZX3
LazarusZX3's Avatar
Fan#: 41107
What I Drive: 2002 Malibu Blue Focus ZX3
FF Reputation: 1 LazarusZX3 Good Standing Member
I think I may experiment between runs at the next auto cross. I have a little pressure pump that plugs into my cigarette lighter.
We admit to the truth; we are the best at what we do.
LazarusZX3 is offline
Old 07-22-2007, 11:32 PM   #35
stivo
Hiyadoin'
stivo's Avatar
Fan#: 48389
I actually have an air tank that I fill up at the gas station. I forgot exactly where I bought it, but I think you can get them at an auto parts store, or tool shop. This one will hold up to about 120psi and is great for making pressure adjustments at the track.
If I remember correctly it was about $50 from the local tool shop.
stivo is offline
Old 07-23-2007, 12:40 PM   #36
stivo
Hiyadoin'
stivo's Avatar
Fan#: 48389
So I found the article about the 400 torque VW TDI new beetle. This is in the December 06 issue of Grassroots Motorsports, the guy is running an UPsolute Stage II chip and Fratelli Bosio Powerplus 520 injectors and a boost control valve.
This combo gives him about 16psi of boost. He's done other mods to his car, but this on an otherwise stock motor is producing 123 horsepower and 412 lb. ft of torque... and 40mpg!
stivo is offline
Old 07-23-2007, 01:31 PM   #37
tua03332
tua03332's Avatar
Fan#: 37555
What I Drive: 2000 Silver Sedan
FF Reputation: 1 tua03332 Good Standing Member
just to add another opinion on the origional topic here, I have svt springs and kyb dampers, spc camber plates up front, and rt-615's. I have had my car aligned to zero for camber, caster, and toe. Then when i go Ax'ing i simply use the camber kit to dial in as much negative camber up front i can get. I run the azenis without the reinforced sidewalls so the pressures are a bit higher. front 55 rear 37. The car is a tad oversteery in corner entry for the average driver but for me is perfect because left braking followed by throttle on will plant the rear as soon as i am straightened out and i literally launch out of the corners without losing momemtum and thus bogging 2nd.
34 STS
Funded By: My Back Pocket
tua03332 is offline
Old 07-23-2007, 02:25 PM   #38
stivo
Hiyadoin'
stivo's Avatar
Fan#: 48389
How is it to drive on the street with that alignment? 0 camber, 0 caster and 0 toe?
stivo is offline
Old 07-23-2007, 03:44 PM   #39
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
What I Drive: 2003 SVTF, 2003 G35, 2001 Audi S4
FF Reputation: 5 DirtyDeeds Good Standing Member
What do you have your dampers set to front and back? I'm taking a guess that yours are adjustable.
DirtyDeeds is offline
Old 07-23-2007, 07:06 PM   #40
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
FWIW.. I run a ground Control coilover kit with Eibach 500# springs on all 4 corners with Koni Yellows (set all the way up), a 22mm front bar and a 25mm rear with Kumho 711's
I run -2.1* camber on all 4 wheels with about 1/8th inch tow out both front and rear.. I dont remember what the caster was.
I was really surprized at how good it really does handle... the car has very good rotation but at the same time it feels very planted in the curves ..... almost like a slot car.
[/b]
Similar Threads
SVT owners: what brand of tire, and do you like it? SVT4ME Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 46 01-26-2011 04:03 PM
hahaha...tire place mixup and near scare PARKINGLOT Ford Focus & General Car Chat 21 06-10-2007 08:26 PM
Alignment Probs Kpaisner Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 7 12-07-2005 08:21 PM
New tire equal alignment problem?? 2000FordFocus Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 5 10-17-2004 05:00 PM
morale of the story...... GET AN ALIGNMENT DONE!!! whiteboyslo Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 4 07-23-2004 04:23 PM
