HELP Somethings draining my battery - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-14-2007, 12:34 PM   #1
ligardner
Fan#: 32567
What I Drive: 02 Focus LX; 05 Focus ZX4; 02 Wago
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 ligardner Good Standing Member
Exclamation HELP Somethings draining my battery
This 02 Focus has developed a battery draining problem that I cannot solve. Back in early May I installed A1Electric keyless entry on this car. It took about 4 weeks because I worked on it part time, and had to install a horn relay and remote trunk relay. So the car sat without being run for better part of a month. But the battery is only about 1 yr. old.
Then about 3 weeks ago I tried to start the car and it was 100% dead--no clicking, no power doors, nothing. I thought maybe a light had been on so didn't worry too much. Then it happened again, and then again, even though the car was being driven. I bought a digital voltmeter on Monday to see if I had a "parasitic" drain problem. Hooked up the 10 amp side of the DVOM in series to the unhooked neg. battery terminal and read 4.7 A (this might be 470 mA?). In any case, this is 3 times the reading I get on my 2005 Focus, which is about 1.2 to 1.4.
So I followed the suggestions from some of the parasitic drain posts that recommended pulling out fuses to see what electrical component is pulling power from the battery. I have pulled out every single fuse in the fusebox and in the engine compartment fusebox and with fuses removed (in groups of 4 to 8) NOTHING CHANGED the parasitic drain reading. Then I pulled the power connector from the A1electric main relay, and connector to the keyless electronic brain box--and with these removed, the result again is NO CHANGE.
I am stumped. the alternator seems fine. Autozone checked both it and the battery on their machine--said they were good. When I run the car for 10 min. the battery pumps up to about 12.4 volts. Then left overnight, it drops down to 11.5 volts or lower. I pulled the neg. battery cable off last night and let car sit overnight like that--and it did not drain down (duh!).
Any ideas on what to try now?
- is there a piece of test equipment that would help?
- battery saver relay be checked or replaced?
Any suggestions that would help isolate this maddening problem would be appreciated. Even something as basic as determining whether the problem is under the hood or in passenger compartment would help.
ligardner is offline
Old 07-15-2007, 01:19 PM   #2
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
put a voltmeter on it for about 5 minutes and wait for it to drop a little, and the start pulling fuses. when u pull one and the volts jump back up, u will know in what direction to look in
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Old 07-15-2007, 06:16 PM   #3
DURATECoftheDesert
Subcompact Fanatic
DURATECoftheDesert's Avatar
Fan#: 43017
What I Drive: 1997 Ford Aspire White
FF Reputation: 9 DURATECoftheDesert Good Standing Member
How many times U check the voltage on the battery?
U maybe just have a bad connecting wiring to the battery to the alternator.
Finally peace and quiet...
DURATECoftheDesert is offline
Old 07-15-2007, 08:54 PM   #4
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
There's a fairly heavy red wire that goes from the alternator to the battery (+) terminal. Disconnect this from the alternator, and see what happens.
Your alternator may have bad diodes. These act like a check valve in a pipe, allowing current to flow from the alternator to the battery but not vice-versa. So if one goes bad (there's usually 3 in there), when you turn the car off the windings in the alternator just sit there and draw current like a stalled electric motor.
This circuit may have a fuseable link, but it has no actual fuse, so that would explain why you have no luck pulling fuses.
Often wrong but never in doubt.
Blurvfocus is offline
Old 07-15-2007, 09:56 PM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,745, Level 78
Points: 14,745, Level: 78 Points: 14,745, Level: 78 Points: 14,745, Level: 78
Level Up 74% Completed
Forum Activity 10%
FF Reputation: 90 goinloco1 Excellent Standing Member
did you pull the fuse panel loose and check the fuses and relays on the back of it?
goinloco1 is online now
Old 07-16-2007, 09:34 AM   #6
ligardner
Fan#: 32567
[I]
Great suggestion. The alternator is charging the battery while driving. Would the alternator still drain battery overnite yet do its job when engine is running (shows my lack of knowledge of alternators!)
I will disconnect this big alternator wire and let you all know what happens.
Thanx-I did check all fuses in the panel, then pulled the panel to make certain relays were in tightly. But I have not checked the relays--what are U suggesting I do to check the relays??
Old 07-16-2007, 10:17 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Not to be an ass, but this is what I would do.
Disconnect the keyless entry system, and see if the problem disappears. IF so, look very closely at what you did, and you could find the problem. If you don't find a problem, then you should contact the manufacturer and get a replacement because something is amiss.
90% of the time when I installed something on a vehicle, and a problem surfaced shortly after- it was a result of what I'd installed. Not that I'm an idiot, or I think you are- but it's human nature to screw up.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-16-2007, 11:07 AM   #8
ligardner
Fan#: 32567
Good suggestion--was exactly what I was thinking right after battery died for a third time. So I did the following: 1. Disconnected the main keyless relay so door motors are out of loop--NO CHANGE. 2. Disconnected horn relay and trunk relay for keyless system--NO CHANGE. 3. Removed the in-line fuse that protects the entire keyless system and powers all 3 relays and the eletronic keyless box--NO CHANGE. I think there is nothing wrong with this keyless entry.
Don't know if I mentioned that I pulled all the large fuses out of the under-hood fusebox and still found NO CHANGE in the drain. This was a big surprise as I assumed yanking those disables the individual component circuits. (I am guessing this--I certainly am a novice on automobile electrics). I plan to test the alternator tonight per the above. -Lytt
Old 07-16-2007, 01:55 PM   #9
cookiemonster52
Fan#: 48118
What I Drive: 2004, Liquid Gray, ZTS 2.3L Duratec
FF Reputation: 4 cookiemonster52 Good Standing Member
Do you have an aftermarket stereo system? If so, you could try pulling any fuse that's NOT located in the fuse box, such as the feed to an Amplifier? If the remote line isn't making contact, your amp could be stuck on, and that'll definately kill your battery.
That's if you have an amp of course :)
$_COOKIE['monster'] = "Team Duratec #89";
I need some interior trim pieces for 00-04. PM me if you have any!
cookiemonster52 is offline
Old 07-16-2007, 04:15 PM   #10
ligardner
Fan#: 32567
Don't got an amp. I did pull the weird in-line fuse that came with the aftermarket door locks. That didn't change anything. I am really really hoping its the alternator.
(my first car was a 55 Dodge hemi. Car amps are a generational thing :)
Similar Threads
Please HELP - Battery light VR6guy General Technical Chat 11 02-06-2007 08:56 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
2nd battery, asking for helpful advice sc0tty8 Car Audio, SYNC, MyFord Touch & Electronics 0 10-22-2005 10:17 AM
battery issues chad_p71 General Technical Chat 3 05-06-2005 11:10 AM
battery light and ground problems natdog General Technical Chat 0 01-19-2005 11:36 AM
