#1 | ||||
Seat replacement questions
I know do a search. I did. No conclusive answers to my questions. Here it goes:
1) Are seats with side air bags clearly marked on the seat? Mine do not have any markings, but when inspecting the seat I noticed two wires going up the side of the seat from the seat harness, also two other wires leaving the harness and terminating in a plastic piece attached to the seat rail. 2) To avoid the dreaded srs light from blinking, do I need to cut the harness from the orginal seat and attach to the aftermarket seat? 3) And finally, what kind of bolts/nuts should I be using to attach the aftermarket bracket/seat belt receptor/seat rails to each other? Thanks for your help. Ed |
Remove Advertisements |
Fan#: 1
#2 | ||||
Hmm i dont think they have side airbags, but when I changed to aftermarket seats i jsut took the waires/harness and put it on the bottom of the new seats. It is basiacally the SRS sytem and the light shouldn't come on i dont believe.
For the belts i used the original bolts that were on the original seats. not usre if that is what you are talking about and i used the ones that came on the seats to bolt them to the bracket etc. all original hardware.
Mustang driver now! but i still love FF so much! |
#3 | ||||
JFoucs82:
Seats with side airbags are clearly marked from the factory, with either a tag sewn into the seat, or with an embossment on the side AFAIK. If you don't have the tags, you likely don't have SABs. If you bought your car used, I suppose they could've deployed, and been replaced with a non-SAB cover. Or perhaps the supplier put the wrong covers on. Feel along the side of the seat (press your fingers into the fabric)...You can probably feel the hole in the foam for the airbag, or the airbag itself. --Otter |
#4 | ||||
Dehawkified
i cant answer the airbag question any better, but as for the rest...when you get a new seat, it won't come with the seatbelt clip. On the focus, it is attached to the seat, so you will have to unbolt it and remove it. It will have some wires running from it to the bottom of the seat, and into a little electrical harness. Just unplug it and seperate it from the old seat. the new seat probably wont have anywhere to attach it (mine didnt) so i just bolted it onto the rear right mounting point, under the seat mount. It's a little PITA, but it works. Just plug the wires back into the harness and you are set with the seatbelt. Depending on the type of seat you got, most companies will sell a hardware kit (seperately from the seat) that includes all the hardware needed to install a seat (and its high quality stuff). I bought that with my seat, but you should be able to just use the factory bolts if you want.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2005 SVT Seat Swap (Part 2) -- sucked! | snobrdrdans_sedan | Focus SVT | 52 | 03-28-2007 02:39 PM |
| Seat install questions | FocusVet | MK1 Interior Mods & Upgrades | 8 | 01-15-2007 03:57 PM |
| Questions about seat Height? | JD2020 | MK1 Interior Mods & Upgrades | 20 | 02-16-2006 09:34 PM |
| Replacement Headunit questions | svt_gEEk | Car Audio, SYNC, MyFord Touch & Electronics | 6 | 08-08-2005 11:01 PM |
| SVT audiophile 9006 replacement questions | Iceboy9191 | Car Audio, SYNC, MyFord Touch & Electronics | 2 | 05-22-2005 11:51 AM |
