Too much transmission fluid - ATX - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-09-2007, 07:53 PM   #11
icanrace
Fan#: 51447
What I Drive: 2006 Red ZX4
FF Reputation: 1 icanrace Good Standing Member
Originally Posted by FordZX32000 View Post
Ok here's what I did on my 2000 ZX3 to get rid of some of the fluid.
Ispi
Hay FORDZX32000 With a gasket in place the next pan drop should be a much easier If a leak does develop then we can re torque, up to 10 ft.lb. if necessary, right? I did consider a DIY tranny flush as suggested by others on this forum: Pull the upper cooler hose, run the car in neutral until 3 qts is pumped out, refill and repeat. This is supposed to be safe, especially as a way to flush the torque converter after a pan drop. May do this at the 90K pan drop.
So from there here's what I did.
1. I pulled the car up onto the car ramps.
2. Took a look at the pan bolts and then looked at the tranny cooler lines.
3. I went for the tranny cooler lines as they appeared to be the easy route.
4. There are two tranny cooler lines that run into the tranny cooler located in the front of the car behind the radiator fans. (A) Top cooler line is the supply line. (B) Lower cooler line is the return line.
5. On my car the top cooler line had a rubber hose that connects to a metal line that runs into the cooler. The rubber line was connected with a hose clamp.
6. I unscrewed the hose clamp and slid the rubber hose off.
7. I had a bucket there to catch any fluid.
8. I put the car in neutral with the parking brake on.
9. Had a friend start the car while I'm directing the gushing fluid into the bucket. FYI, Once the car is started it will pump that fluid out real quick!!!
10. I let it pump out about 3-4 qts of fluid and then shut the car off.
11. I reconnected the hose and added 2-qts of new fluid.
12. Back the car off the ramps and let it get to operating temp as well as shifting thru all of the gears.
13. I then added fluid as needed until I had the corrrect level.
I can tell you it was not a bad job to do in order to remove the overfill of fluid.
However I would advise being careful as not to mess up your tranny by pumping all the fluid out of the T/C which is what I did not do. I don't know if it could screw something up or not with the car running with all of the fluid out of the T/C.
Anyway I hope this will help you and others.
Good luck!!!!
Here's the full thread.
http://www.focusfanatics.com/forum/showthread.php?t=124533
this happened to me and had to endup pulling the pan back loose. I had some sort of plastic clip / clamp thing on my hose and I couldn't figure out how to get the stupid thing unhooked. P'd me off! lol
icanrace is offline
Old 11-11-2007, 11:22 AM   #12
Bar
Fan#: 34266
What I Drive: 2006 green zx4
FF Reputation: -7 Bar Poor Behavior Needs Improvement
I've had trouble getting the fluid level right, myself. According to the specs from this site, it takes 3.2 qts. to fill it back up from a pan drop. Next time, I think I'll just add 3 qts. 7 oz. and be done with it.
Bar is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 07:18 PM
atx transmission fluid xbox4414 General Technical Chat 27 04-18-2007 03:25 AM
ATX fluid change with RP? Mr.Bergner ZETEC Performance (2000-2004) 6 02-08-2007 06:01 PM
Mobil 1 synthetic ATX fluid? 2000FordFocus General Technical Chat 7 11-09-2004 08:35 AM
