Too much transmission fluid - ATX - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2007, 03:56 PM   #1
lduran
lduran's Avatar
Fan#: 18554
What I Drive: '02 ZX5
Points 2,853, Level 32
Points: 2,853, Level: 32 Points: 2,853, Level: 32 Points: 2,853, Level: 32
Level Up 69% Completed
FF Reputation: 1 lduran Good Standing Member
Buy-Sell-Trade Rating: (6)
I recently checked the level of the trans fluid and it needed a little bit. My brother was with me and he added the fluid, but he added a little bit too much. Is there a way to drain the fluid without dropping the pan?
2002 Sangria Red ZX5 with ABS, Moonroof, K&N Air Charger, Borla Cat-back exhaust, Edelbrock header, Random Tech Cat, Bosal Flexpipe, Magnaflow Resonator, SVT Suspension, Auto tranny
lduran is offline
Old 07-04-2007, 08:52 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Find someone with an oil extractor (used to change oil via the dipstick), a vacuum bleeder (mity vac is one brand), or a suction gun (used to suck the oil out of rear ends on RWD vehicles). With any of these and a long length of small tubing, you can suck the fluid out via the dipstick tube. Don't do it with the engine/transmission too hot, as there might be a risk of melting the tubing, depending upon what type of small tubing you are using. I suppose you could rig up something with a turkey baster, duct tape, and small tubing as well, but I'm not sure you'd get enough suction to get much, if any, out using that "handyman's special" approach.
penguin is offline
Old 07-04-2007, 08:57 PM   #3
penguin
Fan#: 21700
Oil Extractor: http://www.griotsgarage.com/catalog.jsp?&SKU=10122
Suction Gun: http://www.amazon.com/Plews-Suction-Gun/dp/B0008D6O7C
Vacuum Brake Bleeder: http://www.amazon.com/MityVac-MV6815...3597020&sr=1-6
penguin is offline
Old 07-04-2007, 11:02 PM   #4
FordZX32000
Fan#: 33469
What I Drive: 2000 black ZX3
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 FordZX32000 Good Standing Member
Ok here's what I did on my 2000 ZX3 to get rid of some of the fluid.
Ispi
Hay FORDZX32000 With a gasket in place the next pan drop should be a much easier If a leak does develop then we can re torque, up to 10 ft.lb. if necessary, right? I did consider a DIY tranny flush as suggested by others on this forum: Pull the upper cooler hose, run the car in neutral until 3 qts is pumped out, refill and repeat. This is supposed to be safe, especially as a way to flush the torque converter after a pan drop. May do this at the 90K pan drop.
So from there here's what I did.
1. I pulled the car up onto the car ramps.
2. Took a look at the pan bolts and then looked at the tranny cooler lines.
3. I went for the tranny cooler lines as they appeared to be the easy route.
4. There are two tranny cooler lines that run into the tranny cooler located in the front of the car behind the radiator fans. (A) Top cooler line is the supply line. (B) Lower cooler line is the return line.
5. On my car the top cooler line had a rubber hose that connects to a metal line that runs into the cooler. The rubber line was connected with a hose clamp.
6. I unscrewed the hose clamp and slid the rubber hose off.
7. I had a bucket there to catch any fluid.
8. I put the car in neutral with the parking brake on.
9. Had a friend start the car while I'm directing the gushing fluid into the bucket. FYI, Once the car is started it will pump that fluid out real quick!!!
10. I let it pump out about 3-4 qts of fluid and then shut the car off.
11. I reconnected the hose and added 2-qts of new fluid.
12. Back the car off the ramps and let it get to operating temp as well as shifting thru all of the gears.
13. I then added fluid as needed until I had the corrrect level.
I can tell you it was not a bad job to do in order to remove the overfill of fluid.
However I would advise being careful as not to mess up your tranny by pumping all the fluid out of the T/C which is what I did not do. I don't know if it could screw something up or not with the car running with all of the fluid out of the T/C.
Anyway I hope this will help you and others.
Good luck!!!!
Here's the full thread.
http://www.focusfanatics.com/forum/showthread.php?t=124533
FordZX32000 is offline
Old 07-04-2007, 11:35 PM   #5
lduran
lduran's Avatar
Fan#: 18554
Thank you so much for all who replied. I think I am going to try your method FordZX32000, it sounds like the easiest way to do it with the tools I have on hand.
lduran is offline
Old 07-05-2007, 01:13 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Don't look in the bucket while the car is on- it might be a better idea to disconnect the coil or the inertia switch and just crank it.
Best of luck!
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-05-2007, 10:01 AM   #7
FordZX32000
Fan#: 33469
You can do it . Take your time when doing this. It's a lot better than dropping the pan again!!!
Old 07-08-2007, 08:40 AM   #8
hotfocus
Fan#: 12
What I Drive: OLD: '00 Black ZX3, New: Pontiac G6
FF Reputation: 1 hotfocus Good Standing Member
Too much fluid can cause your seals to burst...drain it to the right level before driving.
Add yourself to the FF map
hotfocus is offline
Old 07-08-2007, 09:49 AM   #9
FordZX32000
Fan#: 33469
lduran,
Did you get the fluid drained yet ? Be sure to post back up to let us know how it went once done.
Old 09-14-2007, 02:59 PM   #10
lduran
lduran's Avatar
Fan#: 18554
I forgot about this thread. I did get it drained out. Thanks to all who helped.
lduran is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 07:18 PM
atx transmission fluid xbox4414 General Technical Chat 27 04-18-2007 03:25 AM
ATX fluid change with RP? Mr.Bergner ZETEC Performance (2000-2004) 6 02-08-2007 06:01 PM
Mobil 1 synthetic ATX fluid? 2000FordFocus General Technical Chat 7 11-09-2004 08:35 AM
