Timing belt problem - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 07-01-2007, 07:29 PM   #1
matthewsvt
Fan#: 34275
What I Drive: 2002 SVT 3 door
FF Reputation: 2 matthewsvt Good Standing Member
Timing belt problem
So I am replacing my timing belt. Very easy, until the whole "timing" part comes into play.
How do you time the svt focus? (or any focus) I TDC the crank, use my flat edge on the rear of both cam's, and slide the belt on. The crank turns and then its out of time. Even if I don't see it turn, I rotate the engine a few times, and re-check. Both cam's are out.
So what is this "pully blanking plug?" I see a T55 torx on both cams. I removed the intake one, and see an external torx inside. Is it possible to turn the cams with the belt on, then tighton them up so the crank doesnt move? Im allmost done! Any help would be great! I just can't get it timed right!
matthewsvt is offline
Old 07-01-2007, 08:11 PM   #2
DURATECoftheDesert
Subcompact Fanatic
DURATECoftheDesert's Avatar
Fan#: 43017
What I Drive: 1997 Ford Aspire White
FF Reputation: 9 DURATECoftheDesert Good Standing Member
Might take it a while to get it right.
DOHC models are a bitch to get it right, but I never owned one.
My brother does Machanical work and had trouble with timing on DOHC models than SOHC.
Finally peace and quiet...
DURATECoftheDesert is offline
Old 07-01-2007, 09:09 PM   #3
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,634, Level 78
Points: 14,634, Level: 78 Points: 14,634, Level: 78 Points: 14,634, Level: 78
Level Up 46% Completed
Forum Activity 3%
FF Reputation: 90 goinloco1 Excellent Standing Member
leave the gears slightly loose, then follow these directions...
http://www.focushacks.com/index.php?modid=17
goinloco1 is offline
Old 07-01-2007, 10:58 PM   #4
matthewsvt
Fan#: 34275
So both cam gears need to be loose? I couldnt get the exhaust side loose. I will try an impact on it. So the T-55 bolts are what loosen's the cam's? I can see what you mean by being a prick. I put my vice grips on the cam gears so they cant turn. (as well as my flat edge) should that be enough?
How can I keep the crank from turning? Is it possible to turn the cam's without the gears moving, then tighton the gears?
Old 07-02-2007, 01:26 AM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 3%
If you look between the lobes on the cam between cyl 1&2 you'll see a place the cams can be held.
DO NOT use the bar in the end of the cams for this.from experience i can tell you a new cam is 140 bucks. i snapped the end off of mine.
hold it with a crescent wrench where i said to tighten and loosen the cam gears.
and yes, both gears must remain loose till everything else is set up and aligned. then simply snug them, then torque.
Old 07-02-2007, 02:15 AM   #6
matthewsvt
Fan#: 34275
ok thankyou very much! first thing tommorw morning:)
Old 07-02-2007, 09:26 AM   #7
localcpuguy
Fan#: 48244
What I Drive: Shit-Green Nizmo
FF Reputation: 1 localcpuguy Good Standing Member
Another awesome find. go with that
localcpuguy is offline
Old 07-02-2007, 11:01 PM   #8
matthewsvt
Fan#: 34275
I was able to get the exhaust cam gear to spin free, but not the intake. I can move the cam a little bit, but its fighting me to spring in either direction. It doesnt sit nice like the other one. Im thinking because of the VCT? I took both T-55's out. Whats with the "E-torx" beyond the plug on the intake cam. I couldnt get it loose. Should I? That cam will NOT turn without the gear! Makes things harder.
Old 07-02-2007, 11:34 PM   #9
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 3%
yes, the etorx has to be loosened,its actually the cam bolt.
Old 07-02-2007, 11:35 PM   #10
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 3%
what state are you in by the way?
Similar Threads
Timing Belt cspangg General Technical Chat 4 04-05-2007 08:38 AM
Opinions on timing belt, alternator Black&Tan ZETEC Performance (2000-2004) 1 03-21-2007 09:22 PM
To Change or Not to Change the Timing Belt? focus4free ZETEC Performance (2000-2004) 2 02-21-2007 01:17 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
tension on timing belt lg03focus General Forced Induction 3 01-19-2006 07:09 AM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
