fuel return set-up - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2007, 12:52 AM   #11
focuzed1
focuzed1's Avatar
Fan#: 10722
What I Drive: 2002 liquid grey zx3
Points 10,847, Level 68
Points: 10,847, Level: 68 Points: 10,847, Level: 68 Points: 10,847, Level: 68
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 16 focuzed1 Great Standing Member
Buy-Sell-Trade Rating: (15)
yes. sorry, i fixed the post i realized what you were talking about after i posted it hope the new info helps...
Too Fast For Me... TONS OF WHP... GOBBS OF WTQ......
Go ahead put your car where your mouth is....
focuzed1 is offline
Old 07-01-2007, 12:58 AM   #12
1turbozx3
Fan#: 15014
FF Reputation: 1 1turbozx3 Good Standing Member
Buy-Sell-Trade Rating: (20)
so i remove the check valve it dosnt go back on so i can just use one hose to go from the pump to the top of the pump right
1turbozx3 is offline
Old 07-01-2007, 12:58 AM   #13
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,969, Level 91
Points: 20,969, Level: 91 Points: 20,969, Level: 91 Points: 20,969, Level: 91
Level Up 24% Completed
Forum Activity 11%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
THANKS!!!
So you drilled 4 holes in the bottom canister of the fuel pump? can you explain what these do. and where exactly they are at.
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 07-01-2007, 01:01 AM   #14
1turbozx3
Fan#: 15014
they let more fuel in for the pump im guessing there on the front so under hard take off the fuel stays in tom talked about this long ago
Old 07-01-2007, 01:02 AM   #15
focuzed1
focuzed1's Avatar
Fan#: 10722
Originally Posted by tls_bmx View Post
THANKS!!!
when you remove the check valve it no longer has anything to put the fuel back into the canister.. this whole check valve item is kinda like a return sytem just not as good. by drilling the holes it allows for fuel to get into the canister and I belive that is where it gets some of its fuel from. I drilled these holes on the front side of the canister about 1-1.5 in from the bottom side by side as many as i could fit (on the front half of the canister)
focuzed1 is offline
Old 07-01-2007, 01:03 AM   #16
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 11%
I thought the check valve was to keep the fuel pressure up (keep it from bleeding down) when the engine was shut off, that way it wouldnt have to prime every time you started the car.
and what was that black line that you plugged with a bolt? the righting on that thing is SMALL
Turbo Turtle Garage
Old 07-01-2007, 01:05 AM   #17
1turbozx3
Fan#: 15014
look to be the old evap line ;)
Old 07-01-2007, 01:06 AM   #18
focuzed1
focuzed1's Avatar
Fan#: 10722
ok makes since. and what was that black line that you plugged with a bolt? the righting on that thing is SMALL
Yeah i noticed that after i posted it and tried to fix it but couldnt... that is the factory evap line. Just cut it plug it and move it out the way you dont need it any more....
focuzed1 is offline
Old 07-01-2007, 01:08 AM   #19
1turbozx3
Fan#: 15014
so u did this at your house and then drove to toms did u have to do any tuning before u got to toms for the new fuel setup i just check i will be doing this next weekend ;)
Old 07-01-2007, 01:08 AM   #20
focuzed1
focuzed1's Avatar
Fan#: 10722
Could be.... like i said im not sure exactly its job i just know it puts fuel int the canister and without it you need holes itn the canister.... you are probably right....
focuzed1 is offline
Similar Threads
Help! 2000 Focus - no fuel - need wiring diagram thebigreddog! General Technical Chat 7 09-21-2013 10:19 AM
Fuel PSI , Boost-A-Pump , Fuel PSI issues 1turbofocus General Forced Induction 76 03-27-2009 11:59 PM
Fuel Problems on this forum. DURATECoftheDesert General Technical Chat 3 06-02-2007 10:58 PM
return fuel system besthaticouldo General Forced Induction 6 04-29-2007 03:57 PM
Fuel Sender problem reader21 Ford Focus & General Car Chat 7 05-03-2004 06:43 PM
