fuel return set-up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-30-2007, 11:43 PM   #1
focuzed1
focuzed1's Avatar
Fan#: 10722
What I Drive: 2002 liquid grey zx3
Points 10,971, Level 69
Points: 10,971, Level: 69 Points: 10,971, Level: 69 Points: 10,971, Level: 69
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 16 focuzed1 Great Standing Member
Buy-Sell-Trade Rating: (15)
fuel return set-up
Ok i have been aske to show pics of my budget fuel return set-up so i hope this works
Ok now for the explination of how... It was real easy first you need a parts list.
airmotive boost sensative adjustable regulator...$168.79,
#6 braided hose 6ft prob only need about 3ft..$30.67,
steeda fuel rail...$99.95,
fuel pressur gauge..$23.99,
2 #6hose ends..$12.56.
plus shippin $30.00.
you will need to modify the fuel pump a bit (all you do is take the check valve off the fule pump and put a piece of efi fuel line in its place careful not to kink it. And drill a few hole into the side of the canister about 4 or 5
So total price $385.96
Now the how I already told you how to modify the fuel pump now for the fuel system.
remove the factory evap system.(you will need to tune this option out so you dont ket a engine code) cut the factory platic part of that line and plug it i use a sealant and a bolt works great.... this line now becomes your fuel return line.With the steeda fuel rail all you have to do is hook up the fuel supply line exactly how you removed it. then with the fitting that you got you can hook up the line on the other side of the rail to the fuel regulator. then hook up a peice of 3/8 efi line to the evap line from your fuel regulator and clamp it. the on the other side of this metal line back by the fuel tank you take some more of the fuel line and find a spot towards the top of the tank to go into for the fuel to go back into the tank. I just drilled a hole at the top corner and put a 3/8 90 degree fitting in it and clamp my fuel line to it..... Bam! you now have a full return system real easy and real cheap. Oh start the car and make sure you have no leaks. Btw AGAIN I STATE USE EFI FUEL LINE NOTHING ELSE!!!!! If you dont you will be doing this over because other line will not hold the pressure you need it to TRUST ME!!!! I KNOW.....lol
Too Fast For Me... TONS OF WHP... GOBBS OF WTQ......
Go ahead put your car where your mouth is....
focuzed1 is offline
Old 07-01-2007, 12:03 AM   #2
1turbozx3
Fan#: 15014
FF Reputation: 1 1turbozx3 Good Standing Member
Buy-Sell-Trade Rating: (20)
and tom tuned this for u
im guessing u tuned the pump to stay at wide open at all times
1turbozx3 is offline
Old 07-01-2007, 12:04 AM   #3
1turbozx3
Fan#: 15014
have any pics of where to drill holes nice write up ;)
any pics of
"I just drilled a hole at the top corner and put a 3/8 90 degree fitting in it and clamp my fuel line to it"
Old 07-01-2007, 12:09 AM   #4
focuzed1
focuzed1's Avatar
Fan#: 10722
Forum Activity 2%
I dont think so. we did it with the voltage.the voltage goes up with the boost pressure controlled by the ecu. (I think ) I do remember him stating that he did not want to do that with mine so we worked around it. Tom could you help here?
I put the pump in (For placement knowledge) and put the holes on the front half of the pump (facing the front of the car) becareful not to drill into you fuel pump
when you drill these holes...(I almost did)
focuzed1 is offline
Old 07-01-2007, 12:14 AM   #5
focuzed1
focuzed1's Avatar
Fan#: 10722
Forum Activity 2%
any pics of
Sorry cant get pics of that with out dropping my tank. just get your fitting that you are gonna use (I got mine from autozone) with your tank dropped push it up in place and look for a spot that your fitting will fit. Mine is on the top passanger side corner of the fuel tank and it fits just right.
focuzed1 is offline
Old 07-01-2007, 12:19 AM   #6
1turbozx3
Fan#: 15014
ok how about a pic of the spot u cut the hole in the back floor like so i can see the spot its in ill talk to tom via AIM
Old 07-01-2007, 12:32 AM   #7
focuzed1
focuzed1's Avatar
Fan#: 10722
Forum Activity 2%
That pic is already up there U see the one with the antifreeze bottles in it that is it. I removed the back seat and pulled away the carpet and follow the wires because the fuel pump is right under those wires...
focuzed1 is offline
Old 07-01-2007, 12:40 AM   #8
1turbozx3
Fan#: 15014
so whats controling the voltage to teh pump now still the ecu
can u get a write up on the wiring u did
and i ready where u said u replaced the two hose on the pump with the EFI line to right do they pull right off or did u have to cut those
Old 07-01-2007, 12:48 AM   #9
focuzed1
focuzed1's Avatar
Fan#: 10722
Forum Activity 2%
As far as i know it is still the ecu controlling the pump voltage. no special wiring. all you have to do is cut a small slit in the clear plastic hose where it attaches to the top and it wil pull right off. as for the side on the pump there are 2 little screws holding the check valve on. take those out and it slips right off.
focuzed1 is offline
Old 07-01-2007, 12:49 AM   #10
1turbozx3
Fan#: 15014
yes yes on the evap line i see i was refaring to the ones on the pump the ones in this pic do i replace the two lines in the pic as well
Similar Threads
Help! 2000 Focus - no fuel - need wiring diagram thebigreddog! General Technical Chat 7 09-21-2013 10:19 AM
Fuel PSI , Boost-A-Pump , Fuel PSI issues 1turbofocus General Forced Induction 76 03-27-2009 11:59 PM
Fuel Problems on this forum. DURATECoftheDesert General Technical Chat 3 06-02-2007 10:58 PM
return fuel system besthaticouldo General Forced Induction 6 04-29-2007 03:57 PM
Fuel Sender problem reader21 Ford Focus & General Car Chat 7 05-03-2004 06:43 PM
