Rough Idle - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2012, 03:16 PM   #21
GeeGee
Fan#: 100943
What I Drive: 2008 Black Focus SES Leather!!!!!
FF Reputation: 1 GeeGee Good Standing Member
I recently purchased a 2008 Focus SES and it has a rough idle. If you all noticed most of the intake parts are plastic....ya! So I started looking at the connections and found one of them appeared to be secure but it was actually cracked and loose. Fortunately it had a male type plug so I wrapped tape around the outside and inserted it back into the manifold and wrapped wire around it to hold it in place....It idles Great!. I couldn't believe how easy that was...you all might want to check for cracked fittings!
GeeGee is offline
Old 09-08-2012, 04:03 AM   #22
ditscheit
Fan#: 103597
What I Drive: 2001 red zx3
FF Reputation: 1 ditscheit Good Standing Member
focus
Ive got a 01 with ztec 259648 miles same idle il be fixing but first battery causea weak batt willcause alot of problems shuttin stuff off. I will be lookin for leak as well thanks for yhis helpfull thread
ditscheit is offline
Old 10-02-2012, 10:28 AM   #23
zx003
zx003's Avatar
Fan#: 104291
What I Drive: 2003 Red ZX3
FF Reputation: 1 zx003 Good Standing Member
Originally Posted by ChaosWarlord26 View Post
I actually had 2 bad hoses. Has anyone heard of crank case ventalation? Well this was the real bad hose. It goes the crank case on the top of the motor to the back of the intake mani. It has a hard plastic core with rubber elbows one on each end. One of my rubber elbows was in real bad shape So I replace it with High temp Silicone tubing. and has been runing great ever since. Hope this helps out a lot of people.
Is there a crank case ventilation on a 2.0 Zetec DOHC? And if there is one, where is it?
zx003 is offline
Old 10-02-2012, 04:03 PM   #24
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
Yes. It's called a PCV hose. Do not ask for a crankcase ventilation hose. You'll get the wrong one. I went through a hassle with rockauto because they had it listed in the wrong category and I got stiffed with the wrong one. You want this.
It's the newer version. It's mounted under the plastic intake manifold on the back of a Zetec. They wear out and collapse, or just split altogether. Do a search and you'll see plenty of pics. https://www.google.com/search?num=10....1.Gp0CtY_4Hhc
TerryB is offline
Old 10-03-2012, 08:40 PM   #25
evilmonkeytamer
Fan#: 102654
What I Drive: 2002 silver zx5
FF Reputation: 1 evilmonkeytamer Good Standing Member
im having a horrible miss in my engine. replaced the plugs, wires, and coil. took the injectors off and checked them and they were all spraying good. any more ideas? the car only has 80,000 miles. 2000 model split port 2.0
evilmonkeytamer is offline
Old 10-05-2012, 05:43 PM   #26
ChaosWarlord26
Fan#: 48372
What I Drive: 2006 Dodge Ram 1500
FF Reputation: 3 ChaosWarlord26 Good Standing Member
Have you read the entire thread? Because it sounds like you have checked everything but the possible vacuum leaks the thread is about.
Zetec Crew #248
Sedan Revolution #112
ChaosWarlord26 is offline
Old 08-05-2014, 11:14 PM   #27
bac512
Fan#: 87149
What I Drive: 2003 gray SE
FF Reputation: 1 bac512 Good Standing Member
Hmmm, I see the heat shield which is suppose to protect the hose, but the part that goes bad is the elbow on the left, which is not protected by the heat shield... sooooo Is this really an improved version? (And yes, I know this post is very old...)
bac512 is offline
Old 08-08-2014, 05:08 PM   #28
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Hey, when that's all they make what're you gonna do??? If me you make up the whole thing out of conventional bulk hose so at least when it fails again you can replace it at 1/4 the normal cost. I no longer use the steel tube in the middle, rather custom bent/cut steel brake line and short adapter pieces of hose on the ends.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 12-15-2014, 06:10 PM   #29
beyond_theft
Fan#: 167514
What I Drive: 2002 Red ztw
Points 110, Level 2
Points: 110, Level: 2 Points: 110, Level: 2 Points: 110, Level: 2
Level Up 20% Completed
FF Reputation: 1 beyond_theft Good Standing Member
I'm going to check for this cause i have the same problem and done the same thing you have except ive had a timming belt issue
beyond_theft is offline
Old 01-29-2015, 04:34 PM   #30
Jevik
Fan#: 83497
What I Drive: 2000 red Sedan SE
Points 64, Level 1
Points: 64, Level: 1 Points: 64, Level: 1 Points: 64, Level: 1
Level Up 28% Completed
FF Reputation: 1 Jevik Good Standing Member
Thank you so much! After struggling with a p0171 and rough idle and bad misfiring in wet weather, this helped me pin down the problem to the pcv hose.
Jevik is offline
Similar Threads
Rough Idle and SES Codes chkpnt General Technical Chat 3 08-25-2007 01:14 AM
Rough Idle - 2002 ZX5 Zetec bajadog General Technical Chat 4 06-08-2007 12:30 PM
Rough Idle with AC on tminer250 General Technical Chat 1 06-05-2007 12:33 PM
JRSC rough idle with FC TB? dBlast General Forced Induction 5 04-18-2005 02:11 AM
rough idle CowsGoMoo ZETEC Performance (2000-2004) 9 10-16-2003 04:11 PM
